Old 01-09-2016, 05:51 PM   #1
74CustomK20
74CustomK20's Avatar
Question Front Shackle Angle Q's
Alright everyone this is the front shackle of my k30 frame. Is this going to be good once I get the weight of my body engine etc etc on it, or will it bottom out and hit the frame first? What do I need to do if this is wrong? Help!
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 01-09-2016, 07:17 PM   #2
nvrenuf
Re: Front Shackle Angle Q's
I don't see a pic (but I barely have a signal right now).
John
'91 Blazer, full top, bbc, 4spd, Doubler, 1 tons, 40's
nvrenuf is offline   Reply With Quote
Old 01-09-2016, 07:27 PM   #3
74CustomK20
It's not loading the pics, and I have no idea why. I'm on wifi and have 4G as well... hmm... know the pics not that big either...
Big Nate
Old 01-09-2016, 07:54 PM   #4
74CustomK20
More
Big Nate
Old 01-09-2016, 10:07 PM   #5
324matt
324matt's Avatar
your front springs look too long. Are those the original shackels? I have the ORD front Shackles and they are almost verticle. I think your going to hit the frame
1985 GMC K2500. 350/TH400/208. 4:10's. stock.
1987 Chevy V30. 454/TH400/205 4:10's. Stock SOLD.
324matt is offline   Reply With Quote
Old 01-09-2016, 10:09 PM   #6
74CustomK20
Those are 52's out of a 1989 k20. And 7.25" or shackles.
Big Nate
Old 01-09-2016, 10:15 PM   #7
324matt
324matt's Avatar
um, assuming that you mean 52's (rear leaf springs) out of a 1989 k20, there is your problem. they are too long. your definately going to hit the frame. You need the correct spring length, as well as the correct spring height.
Old 01-09-2016, 10:18 PM   #8
74CustomK20
My bad 324matt. I forgot to add that I'm doing the b52" spring swap.
Big Nate
Old 01-09-2016, 10:20 PM   #9
324matt
324matt's Avatar
looking at your bottom photo, I can tell that they are rear leaf springs from the thick bottom flat spring in the spring pack. Front springs are narrower and much shorter that rear leaf springs. Im not saying that what you are doing cannot be accomplished, but, There is such a thing as the mysterious "death wobble". You would be miles ahead to have your original springs re-arched, or add the ORD 1" zero rate spring in the front, or buy the correct springs.
Old 01-09-2016, 10:24 PM   #10
324matt
324matt's Avatar
read this thread. there is some good info on what your trying to do and it has great pics!
http://www.pirate4x4.com/forum/chevy...-question.html
Old 01-09-2016, 10:36 PM   #11
74CustomK20
Trying to do thr 52" spring swap, and also achieve more flex. My superlift 8" springa are MUCH MUCH too stiff and are like a log truck.
Big Nate
Old 01-09-2016, 11:21 PM   #12
74CustomK20
Thoughts, as my 52's are staying. If my suspension droops, it'll straighten the shackle out... so ok there. But compression is my concern. If I put my mount back In the original spot won't that put the mount FACING forward, and will give me much much more room to compress when I soak up bumps?
Big Nate
Old 01-10-2016, 01:54 AM   #13
nvrenuf
It's always hard to tell with no weight on the chassis but the springs will flatten out some so the shackle will move back. That said, I started with 7.25" shackles and they had my caster all wacked out causing death wobble. I swapped to 6" shackles and brought my caster back into spec and the angle is still good.
I'd probably hold off on any more changes until you get at least most of the weight on it but I bet a short shackle is the answer.
John
Old 01-10-2016, 02:58 AM   #14
74CustomK20
The thoughts are, as it compresses, it will only go as far back (bottom of shackle) until the spring flattens. Once it goes past that the spring will negative arch and the shackle will come back away from the frame right?
Big Nate
angle, shackle, shackle angle
