07-04-2015, 08:23 AM | #51 |
Re: Arizona Steel 46
07-04-2015, 09:01 AM | #52 |
Well that is what the guy told me!
Yes one of them had a heat shield. We removed it and ground off the attachments and had them coated Old Yelr may have something KW is where my family is from, 4 generations, I have been down South West for the past 65 years, don't get back much anymore so I guess this is home for me We don't shovel sunshine and the cars don't rust, and it is a dry heat in June!
07-04-2015, 09:41 AM | #53 |
Yeah,,, "Dry Heat".... Kinda like most peoples Ovens...
07-05-2015, 05:10 PM | #54 |
well ya know ...some of us have to cook !
07-25-2015, 01:01 AM | #55 |
Yes it is out of paint, and progress is being made daily !!
07-25-2015, 01:06 AM | #56 |
looks like light at the end of the tunnel
07-25-2015, 01:17 AM | #57 |
Along with a lighter wallet
08-06-2015, 02:45 PM | #58 |
Moving along with final assembly............... slowly
08-06-2015, 04:28 PM | #59 |
OHhhh.... Its got to get exciting now... LOL
Is that a Huge Tranny cooler in front of the radiator I see? |
08-06-2015, 04:56 PM | #60 |
It is the A /C condenser
08-06-2015, 06:07 PM | #61 |
Looks good! Final assembly is really rewarding....and often a bit stressful, at least for me.
08-21-2015, 12:55 AM | #62 |
Well lets see if I can find where all the wires go!
He says he wants to drive it for his birthday on Sept 11 He may be able to drive it out of the shop but it will still need more work
08-21-2015, 07:48 PM | #63 |
Looking awesome, love the color. What kind of deal is that for powering the E-brake?
"Fear makes the wolf look bigger" http://67-72chevytrucks.com/vboard/s...d.php?t=305629 |
08-22-2015, 12:39 AM | #64 |
Home made !
200# and two inch stroke electric, enough to tighten the Wilwood parking brakes
08-22-2015, 07:54 AM | #65 | |
Truck looks great. |
08-22-2015, 09:02 AM | #66 |
I have slept too many times , don't remember what brand, I think it was a late nite Amazon shopping spree!!
09-08-2015, 05:26 PM | #67 |
Well we drove it out of the garage and on to the trailer under it's own power and today we took it to the front shop for alingnment to correct the spec instructions on the upper
A arms. it came with O camber and 6* castor but the shop said it had 1 1/2* N camber and 4* castor by the instructions my toe was bye "eye balling" so that did not count!
09-08-2015, 05:44 PM | #68 |
Under LS power !
09-08-2015, 05:44 PM | #69 |
Right on solid! You must have sent some of that AZ heat up here! Frig it's hot. You must be pumped seeing it's on it's own power.
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 |
09-08-2015, 05:54 PM | #70 |
Thanks Sid, Yes now I can get on with the next project
We do not want to hog all of the 100* days, we like to share!
09-08-2015, 06:24 PM | #71 |
Great News...
I wish I was closer I just wanna ride in that for a little bit... I'm sure there's still some details to work out but it's got to make you feel good to be done by Sept 11th |
09-08-2015, 07:51 PM | #72 |
Truck looks great! Vette on the lift does too. Been way too hot here too...killer with the humidity. Dreaming of ac in the shop.
01-07-2016, 01:43 PM | #73 |
Well still sorting out the break issue...................Can not stop with Wilwood brakes!
Everything is brand new Willwood at the wheels double 7" booster 1" master cylinder Solid peddle no air in system, even with HOT pads I am not able to slide the tires
01-11-2016, 01:37 PM | #74 |
Hey the build looks great.
Would you be able to post any photos of how you mounted the seat? |
01-11-2016, 02:11 PM | #75 |
I do not have a pic of the hinge but it was a simple hard ware store door hinge welded to the seat frame and the bolted to the front of the existing seat riser.
his would let you fold the back part and then raise the seat forward to access the cavity under the seat. The seat was from a Dodge Caravan third seat
