#101 |
![]() Join Date: Aug 2011
Re: GMC paul door seals are great!
Anyone mind ordering a set of these and shipping them up to Canada for me? Us Canadians need the good stuff too.
'72 K10 '94 K2500 |
#102 | |
"Fear makes the wolf look bigger" http://67-72chevytrucks.com/vboard/s...d.php?t=305629 |
#103 |
What is the part number for my 78 Silverado door glass ( L & R) rubber/felt not including the vent side just the door window pieces.
I have looked at your site and it is a bit busy for a old man! It would be nice to look at some pictures to make my decisions. Thanks
#104 |
![]() Join Date: Apr 2006
I just installed the push on door seal on my passenger side and Ill have to say while they are nice and go on easy it is substantially harder to close the door. I cut the V shape in it and it didn't make a difference. It seems the door begins to grab the seal up front when closing it. I have to slam it to get it to close all the way. Hopefully they loosen up a little over time.
Kirk 72 Blazer CST 4wd highlander |
#105 |
Got a response from GMC Paul's with some possible issues. I'll try to fix it as I think it's my door adjustment.
#106 |
How long do they take to break in if the doors are real hard to close after installing?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
#107 |
![]() Join Date: Nov 2011
I have the same thing happening to my truck. The drivers door closes fine meanwhile the passenger side I have to slam. The door adjustment is not an option but I read somewhere that letting the truck sit in the hot sun for a period of time seems to relax the rubber. Now after repeated time in our 90+ degree summer heat I don't have to slam it as hard. So I would imagine over time the new rubber will give.
#108 |
![]() Join Date: Jun 2012
I have had these on my truck for over a year and it has set in over 100 degree temperatures on occasion. I still have to slam my doors! I have realigned them 100 times and I just finally took them off. I forgot how nice it is to shut the door and it close without slamming it! I'm currently looking for a new solution.....
Quick update... I took a large hammer and a crescent wrench and moved the door seal lip inwards and got the doors to shut without slamming them. Glad i didn't go back to those stupid glue on ones!
"ALWAYS SOMETHING" 1968 Chevy C10 SWB 383 SBC, TH350 Porterbuilt, Accuair suspension Last edited by Holliday; 02-16-2015 at 12:04 AM. |
#109 |
![]() Join Date: Nov 2014
What do you use to get the old glue off the doors?
#110 |
![]() Join Date: Mar 2000
We now have a NEW Push-On door weatherstrip that has been refined to deal with the 10-15% of the trucks that the owners had to slam their doors when using new glue on or push on door seals. These seals are made specifically for all 67-72 Trucks. They use a softer compound to eliminate the hard closure of the door while still retaining the resiliency of the original seals so that they seal correctly. These have had the mitered corners added to them so that the seal itself better resembles the original OEM glue on seal.
We have also added a 60-66 Push-On seal designed specifically for the 60-66 trucks these also use a softer compound and have the OEM style mitered corners. You can find both of these seals available for immediate shipping in our Rubber & Weatherstrip pages under the appropriate year group. Paul @ GMCPauls |
#111 |
Do you have a stock # ?
I have the old style, and would love to try the new ones. |
#112 |
I pasted the answer in your question.
#113 |
We had the old version that I bought a month ago and experience the problem. Today I just installed the new version on our `68. It's slightly better, but we still have the same problem. I was looking at it, and it's all about the front leading edge. Most of the door pushes flat up against the seals. All that is fine. The front edge (from bottom of window down), though, catches them from the side and pushed forward rather than smashing against the seal. The problem is all in that area. I'm considering cutting them a bit to allow them to just fold, but it's for sure still not right.
Truck has never been in any wreck or had the doors moved or off. Getting kind of tired of trying to make new seals work on this thing. |
#114 | |
My son has suggested that with the upper door hinges having the door stop check on them only that when ever the door has been allowed to swing forward in the past that every time the door check stops the door at it's maximum allowed travel the doors momentum and weight slowly over type distorts the front door jamb area and flange so that slowly over time the flange it's self begin bending outward as the center section of the pillar slowly tries to twist in this area. So while the seal is off I'd also check the flange you are attaching it to and make sure it's straight and not angled outward if so a small bending of the flange can make a remarkable difference in that area. Finally 8iyou only used your hand to push these on instead use a hammer to knock them into position as if the seal not fully seated on the flange it will cause a problem with the seal protruding to far into the door opening. Paul @ GMCPauls |
#115 |
Thanks Paul. I will go over these things and see what can be found. Hopefully it will improve things.
#116 |
Loves all GMC trucks
![]() Join Date: Jul 2010
I ordered and put these on a truck today. It's gonna be on the road Monday so I can give some additional feedback then but first...
1. The newest seal GMC Pauls is selling, I bought. 2. Door closes well. Still takes some effort but they have only been on 1 day. Much easier than the previous set I bought elsewhere. 3. Length was perfect I didn't have to cut anything off it. 4. The GMC Paul's seals (bulbous seal part) actually "feels" different than the soft seal ones you an get at at autozone. (That's because the soft seal ones are too big that autozone sells and so you have to slam your doors) 5. Lastly...I'm already happy with the effort to close the doors, the look, fit and feel of these new seals. I will be ordering another set for another truck! Great product... Just my 2 cents! Mike
Mike If your helping someone and expecting something in return... your doing business not kindness! Last edited by Cash3481; 01-15-2016 at 10:52 AM. |
#117 |
Awesome! Mine came in yesterday. Will put on this weekend.
#118 | |
Paul @ GMCPauls |
#119 |
do any of you guys have a phone number for GMC Paul's? I have some of the door seals ordered and they are on backorder, I can't get anyone to give me a ship date through email and can't find a working number. Thanks in advance. mark
#120 |
All back orders have been shipped and these are in stock again. Thanks! Paul Jr. @ GMCPauls
#121 |
I have your seals I bought and installed a 2-3 years ago. What improvements did you do to your new version? I see that they have Mitered corners at the wing, were there any other inpovements. Mine currently have attendancey to pull away in the upper corner above the door latch.
1970 C10 Short Stepper with 71/72 front clip….gave to my son in Goodyear AZ. |
#122 | |
Where yours are pulling loose there must either be a bind, damaged door lip they attach to or damaged gripper on the seal in that area. Pull on it to remove that section and look at wide & straight the lip is that attaches in that area and check the rubber grips inside the seal lip for damage. If both appear good try wiping that section with Armor All or similar and see what happens. If it's improved then look to see if the door latch on door or striker area on door are deformed to find what's causing the bind in that area. Paul Jr. @ GMCPauls |
#123 | |
#124 | |
Paul Jr @ GMCPauls |
#125 | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
