01-17-2016, 12:23 PM | #51 | |
Happy to be here
Re: Refining "Sierra"
Thank you sir
The amp has a wired controller, power, ground, turn on, and input wires. This made for a pretty big bundle to try to add to the wires in the door channel. If you factor in speaker, cargo light, dome light, and seat belt buzzer wires, the channel on the drivers side is already full. That meant we would have another big bundle on the passenger side that would have to go all the way across to the receiver. I dont really like running wires under carpet, but it was my only option. We cut a channel in the bottom of the box for the wires to exit from and run under the carpet. We used black duct tape to ensure that it lays flat and ran it straight forward to come out under the dash. The turn on and input wire went to the receiver, the ground to a bolt in the firewall, and the power wire exited the cab at the fuse block and went direct to the battery. We added a fuse holder near the fuse block for ease of access. The wired controller will reside in the glove box, attached with velcro. In the second pic I am soldering wires. We eliminated about a dozen crimp connectors. I prefer to solder wires and cover with shrink tube when possible. We added plug in connectors in locations necessary to make future service easier.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-17-2016 at 12:32 PM. |
01-17-2016, 08:12 PM | #52 |
Happy to be here
Well that escalated rather quickly. We pulled the hood off to replace the insulation and clean up the bottom of it. With the hood off I could see a lot of things, I didnt want to see. Even though I had degreased and pressure washed the motor, it was still pretty dirty. Over the years as maintenance was done, many things were not reconnected correctly or the wrong bolts were used. Chris and I decided to dive in deep, so here we are. We stripped most of the accessory brackets to expose a dirty mess. Lets see if we can make this all pretty again.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-18-2016 at 12:06 PM. |
01-18-2016, 12:03 PM | #53 |
Master Hater
Great job, Im down here in Temple,TX and Im in the market for a CCLB either SRW or dually , I've had a few of these trucks , but always wanted to really make the interior nice. Great work, Any blueprints for the rear seat compartment?
1997 C1500 ECSB 4.3/NV3500 8.5 3.42 "This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors |
01-18-2016, 12:13 PM | #54 | |
Happy to be here
2. I ran the ground to a bolt under the dash. Not really necessary, but I just like it better that way. 3. Your 79 will have different threshold trim than the plastic piece on this 84. You can get a decent amount of wires under it, but not enough to do this install. I made so many changes along the way, I did not document them. This was design by demand. You will need to determine what components you plan to use, then build around them.
01-18-2016, 12:18 PM | #55 |
Frequent Flyer
Isn't that funny how it always works like that... Looking good!
01-18-2016, 01:11 PM | #56 |
It'd be a good time to go to the 88-98 Serp setup. Yay, no more belt squeaks!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
01-18-2016, 01:24 PM | #57 |
Happy to be here
My wife just laughed when I showed her. I hate smarty pants know it alls.
I have considered that option. If I were going that route it would have an 97+ Vortec motor attached to it.
01-18-2016, 02:50 PM | #58 |
Looking great Ken!! That is a very nice truck!!
Houston and Dallas Autorama Show Chairman ///Relaxed Atmosphere 1969 Chevrolet C10 1972 Chevrolet 2WD Blazer 1987 GMC Sierra |
01-20-2016, 11:12 AM | #59 |
Happy to be here
Thanks Steve. Hopefully I will have it back together by Lonestar Throwdown.
01-20-2016, 11:20 AM | #60 |
Happy to be here
I "thought" I was done inside the cab, but the dash pad was bothering me. It looks great till you examine it closely and realize it has hairline cracks in the speaker grills. Most people wouldn't notice, but its one of the first things I check when looking at a squarebody truck.
I know I can get a premium quality GM replacement pad from Capt Kaos at www.73-87chevytrucks.com but I have been really trying to maintain a budget on this build. I put a call out that I was looking for an NOS pad and ran across a great find. This NOS GM replacement pad was bought new and stored for 15 years. The guy I got it from installed it for a short period, then decided to fiberglass his old dash pad. He needed some quick cash, and we struck a deal. I'm not sure how well it shows up in the pics, but the condition is mint. I will have to dye it to match, but its going to be the cherry on top of my interior rebuild.
01-20-2016, 06:21 PM | #61 |
I'm just glad to be here!
I do too...
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
01-20-2016, 09:23 PM | #62 |
Happy to be here
It WILL be there. It may not be to my satisfaction, but it will be there.
My pleasure.
01-20-2016, 10:46 PM | #63 |
I saw that pad for sale too. Even though I have a 74, I almost contacted the guy just so I could hoard it for a later sale.
01-22-2016, 11:19 AM | #64 |
Happy to be here
I didnt hesitate. Once I got pics to confirm condition, I drove an hour and a half to go pick it up.
01-22-2016, 11:29 AM | #65 |
Happy to be here
Since I saved myself some money on the purchase of the mint GM dashpad, it left some room in my budget for another purchase. At least thats what I told my wife (insert sarcastic eye roll here) and shes all like "Whatever!".
Combine that with a super 50% off sale at OC Auto Carpets and I loaded up my cart. I have new carpet, mats, and door panel inserts being custom made. I could not find anyone that duplicated the GM mahogany carpet, so I opted for a saddle color. I feel it compliments the interior colors and brightens the cab up.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-22-2016 at 11:31 PM. |
01-22-2016, 07:03 PM | #66 | |
01-22-2016, 11:02 PM | #67 |
Happy to be here
Yes I did, and they weren't even close to the color I needed. The mahogany interior appears to be rather rare.
01-22-2016, 11:28 PM | #68 |
67-72 parts collector,…
I guess I have never seen the mahogany interior.
I thought yours was the faded version of my '86 maroon interior color. (like this one pulled from the internet) It will be nice to see yours restored.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-22-2016 at 11:34 PM. |
01-23-2016, 10:14 PM | #69 | |
Happy to be here
As mentioned Keith, since no one makes an exact match for the carpet, I decided to go with a color that compliments the remaining colors instead.
01-23-2016, 10:18 PM | #70 |
Happy to be here
Sometimes you have to go a lot deeper in to a project than you anticipated. Combine that with having OCD, and the effect snowballs. As I started removing accessory brackets from the motor I discovered an oily mess. The PO had told me he had spent a lot of money having the truck serviced. One thing done was replace the valve cover gaskets. The shop did a nice job of replacing the gaskets, but not cleaning the residual mess left behind from long term leaks.
This is what greeted me when I stripped away the top of the motor. Its not pretty.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 01-23-2016 at 10:28 PM. |
01-23-2016, 10:34 PM | #71 |
Happy to be here
While Chris test drove my new bead blasting cabinet on a dozen or so brackets and small parts, I cleaned and scraped a few thousand miles worth of baked on motor oil from the front of the block and top of the manifold.
I discovered that Harbor Freight carries brake cleaner a few dollars cheaper than the parts store so I loaded up while I was there. I also bought a few of their cheapo wire brushes and lots of paper towels. Combine all that with a few hours of elbow grease, and I can now see a nice clean motor. At least the top and front anyways. The rest will come later.
01-23-2016, 10:40 PM | #72 |
Happy to be here
While I was in there, I decided to replace the water pump. If your going to remove the old one, you may as well install a new HD unit with a lifetime warranty. I blasted it down with some cheap brake cleaner and covered it the Duplicolor high temp brushed stainless paint. I looked at several different choices, but really like the satin sheen of the brushed stainless.
01-24-2016, 11:32 AM | #73 |
I know the pieces fit
Ken, sorry for asking the obvious, Auto Custom Carpets didn't have that color? I thought they had everything. Beautiful detail work.
01-24-2016, 06:58 PM | #74 |
Looking good.
It's funny, I bought a replacement seatbelt assembly off of EBay that I thought was maroon. However, I'm pretty sure it's the same color as your interior. |
01-24-2016, 10:22 PM | #75 | |
Happy to be here
If its a color somewhere between maroon and brown, thats probably what you bought.
