#576 |
Re: My 52 GMC Build
Yes it is. Lots of parts I know are GTG.
Thanks AD. Nice to hear it run again. Thanks Diesel. It sounds a little different now that the exhaust is wrapped and intake pipe is on now. In a good way. Thanks I'm really looking forward to driving it this spring when the snow is gone.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#577 |
Re: My 52 GMC Build
Nice. That video is cool.
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 ![]() |
#578 |
Re: My 52 GMC Build
Your truck is sounding sweet. i'll bet you're hoping for an early spring.
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
#579 |
Simple? What's simple?
![]() Join Date: Apr 2007
Re: My 52 GMC Build
Sounds good! Is that bracket under the exhaust part of your scraper, or is it the running board bracket?
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) |
#580 |
![]() Join Date: May 2007
Re: My 52 GMC Build
its alive!
#581 | ||
Re: My 52 GMC Build
Thanks Sid there will be some longer vids when it gets on the rd.
Yes Yes it is. Now gauges and lights, sounds easy. ![]()
#582 |
Re: My 52 GMC Build
Pure awesomeness right there lowers!!
SHAKE N BAKE BABY, SHAKE N BAKE.... http://67-72chevytrucks.com/vboard/s...d.php?t=686729 |
#583 |
Re: My 52 GMC Build
Thanks Chance
Last night got some more done. Got the 7 pin trailer plug wired and installed. Also got my reverse lights wired and installed. Then the amount of beer that I was drinking told me I should stop before I F something up. But I did hot wire the reverse lights to see them on. They are very white but have a yellow halo. The last pick shows my water proof electrical box for the wiring at the back.
#584 |
Re: My 52 GMC Build
My friend Joe just sent me the invoice for when we painted my '52 where he works.
WOW THANK YOU Joe for all your help. ![]()
#585 | |
Re: My 52 GMC Build
#586 |
Re: My 52 GMC Build
Thanks Coach
I ran some wire and installed my box tube end lights. They are LED dual element (run, brake) really bright D.O.T. approved. I will have them wired in the same as my tail lights.
#587 |
GMC's n H.D.'s too!
![]() Join Date: Oct 2010
Re: My 52 GMC Build
My son and I have been following your build for a while. We both think you are doing an amazing job!
Do you have a part number and or manufacturer on the lights you put in the end of the bed rail? I've seen them before, but was worried that they would be too dim. And possibly the ones for the the reverse lights also. Thanks, and keep up the great work!! |
#588 | |
Re: My 52 GMC Build
#589 | |
Re: My 52 GMC Build
Thanks Coach This weekend I get a pick of the red lights on. Red bed lights http://www.ebay.ca/itm/2-Custom-Mini...52b19b5&_uhb=1 White reverse lights http://www.ebay.ca/itm/111429850236?...%3AMEBIDX%3AIT
#590 |
Re: My 52 GMC Build
Hey Lower. Could I get info on who you had make your rad?
#591 |
Re: My 52 GMC Build
Redi rad Waterloo Ont.
Bob
#592 |
Re: My 52 GMC Build
Thanks for the links. Those have the resister built right in making wiring easy.
I found the link below for another cool source of LED's. http://www.oznium.com/ |
#593 |
Re: My 52 GMC Build
Thanks Bob. Nice touch with the LED's
#594 |
Re: My 52 GMC Build
Nice LEDs!
I might steal those back up lights from you.... Thanks!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#595 |
Re: My 52 GMC Build
No Problem guys.
On the weekend I took the fam out for a walk in the local wrecking yard. My GF likes going and my 2 boys had a blast. I think they went in every car there. Got a wiper motor from the tailgate of a '97 blazer and a vent from a mazda 3. I am using the vent for my heater.
#596 |
Re: My 52 GMC Build
I want to see this blazer wiper motor work, I have heard of it before. those mazda vents are good looking and shut all the way, I had a speed 3
#597 |
Re: My 52 GMC Build
I used a similar motor, only out of a ford. 48panel made me an adjustable linkage for it. Its a bit of fiddling with but if you got the time can be better than dropping 250 for a kit.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#598 | |
GMC's n H.D.'s too!
Re: My 52 GMC Build
Thanks!!
#599 |
Re: My 52 GMC Build
Tonight I made some stainless steel brackets to mount my LED tail lights. I used a 3/8" stainless street elbow to direct the wire down. I got the wires ran and hot wired them on.
#600 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: My 52 GMC Build
More great work! The lights are looking great!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
Tags |
bagged, build, diesel, gmc, hot rod |
