01-19-2016, 09:42 PM | #3151 |
laying low
Re: What did you do to your truck today? Chapter II
You too? Man, I thought it was just me.
01-19-2016, 10:58 PM | #3152 |
RAT1968 '68 Cab/'71 Parts
Right after I read this, I decided to take a nap. Worked out nicely.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
01-20-2016, 01:27 AM | #3153 |
Got the front clip off today.
1972 Blazer CST Dark Olive, am/fm, tilt, tow hooks, tach dash 1972 SWB C-10 Highlander Blue/White 1972 Canadian 2wd Jimmy light olive 1970 SWB 4x4 4 speed 307 |
01-23-2016, 03:52 AM | #3154 |
New wipers put on tonight. Arms and blades.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
01-23-2016, 09:33 AM | #3155 |
Bought and delivered both cab corners to body shop. Progress being made.
01-23-2016, 11:28 AM | #3156 |
What are your plans for heat/air ?
01-23-2016, 11:32 AM | #3157 |
Vintage Air. The fresh air vent orifices were totally rotted out, so I opted to cut them off outside and patch the holes to smooth the kick panels for a cleaner look and better watershed from the cowl.
01-23-2016, 11:46 AM | #3158 |
I think you will be happy with that ,if you have not bought it yet check out Nsane Hotrodz ,he hooked me up with a good deal.
01-23-2016, 11:54 AM | #3159 |
01-23-2016, 12:02 PM | #3160 |
I was supposed to pick up my 72 truck from him today ,this damn snow messed me up ,now I hope to get up there a week from tomorrow .I have not met him in person ,just on the phone but he has done me right .I will definitely use his shop in the future .
01-23-2016, 12:39 PM | #3161 |
01-23-2016, 12:49 PM | #3162 |
made use of the old washer hose holes, added two more holes to add engine bay lighting. 0.3 watt leds will never kill the battery
01-23-2016, 06:42 PM | #3163 |
My father in law helped me weld up all the exhaust joint leaks while the bed is off. Currently painting my heater box components to get the heater working again.
01-23-2016, 08:18 PM | #3164 |
did a little more patching on the fender... out with the bondo filled rust holes and in with a new patch... Ill finish up on this one tomorrow...
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
01-23-2016, 08:20 PM | #3165 |
Completed install of Fitech EFI and took a crappy cell phone vid...
https://m.youtube.com/watch?v=zIqaVJEVBXY
71 C10: Crush10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=650510 |
01-23-2016, 08:46 PM | #3166 |
possmgut your really kickin but on that truck.
it wasnt too bad looking when you first got it but your really showing us what we couldnt see. keep it up. i'll be doing most of the same patch work as econman on this cab i just picked up to build for my 4x4. yesterday i figured before the snow came i would hit a few jys in the area too see if anything new came in....no trucks but i did find a good light harness off a 71-2 smashed front clip since it was only part of a harness i got it for $4. when i got the 4x4 it only had 2-3 lugs on each wheel so i got 32 matching lugs and a set of 67-68 c30 emblems. and another vac advance mech for the kids truck.it seems he needs one once a year idk why it keeps going out and creating a vac leak. of course i came back and put my lugs on to go for a short ride around town in my pile.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
01-23-2016, 08:49 PM | #3167 |
Installed the washer reservoir and bracket that I recently bought. Cleaned up the valve cover, cleaned my air box, found the float on the fuel sender to be full of fuel, adjusted the rocker arms, oh...and installed new seat belts. Passenger seat belt was literally hanging on by a thread.
Ordered a new valve cover gasket and fuel float thing. |
01-23-2016, 08:56 PM | #3168 | |
01-23-2016, 09:01 PM | #3169 | |
your welcome,oe steel is the best too use but sometimes the patches are just easier. i'm fortunate to have a few yards close by and lots of time at this point.
01-23-2016, 09:31 PM | #3170 |
Replaced all 6 cab mounts. My jack wasn't high enough for the two under the radiator but my engine hoist got it lifted just enough to swap out the worn mounts.
Hooked up the heater hoses to see if the heater core leaked... And what would you expect? It leaked... Then followed it up by not popping the cap off the radiator before popping the heater hose off the manifold
71 Long bed C10 w/68 front clip, 350 SBC+HEI, TH350 06 Yukon XL Denali - Stock |
01-23-2016, 09:55 PM | #3171 |
Played with aluminum tubing today. This was my first attempt ever bending he stuff. Turned out pretty good I think. A tip for those ever wanting to try this. A bend consumes 1 1/4" of tubing in a 90* bend. I assume different benders differ. I'm waiting on a ridged bender to come then I'll tackle the front lines.
01-23-2016, 10:21 PM | #3172 |
01-24-2016, 12:46 PM | #3173 |
Placed an ordered for a disc brake conversion kit with ECE.
01-24-2016, 06:03 PM | #3174 |
Hello, looks like everyone is busy on the truck, me too. I got the front sway bar installed. Used all grade 8 bolts and nylon nuts. Took her out for a ride and my grin got bigger, handles great.
Next is tackling the leaky oil pan, then...on and on. Tom
1972 GMC C1500 350/350 1965 Mustang 2+2 289 4spd, show-car 1965 Mustang Coupe 289 4spd, stoplight racer 1/2 dozen Wheelhorse Tractors |
01-24-2016, 06:18 PM | #3175 |
Did a little header and exhaust work to clear the steering shaft.
Brad handshoe |
