Old 01-21-2016, 01:59 PM   #1
C30Seenemall
HydroBoost to Vacuum Assist?
Anyone know if it is feasible to convert my 75 Chevy C30 lousy hydro-boost setup to a vacuum assist setup?
The hydro-boost is giving me nothing but trouble!
It has always made the most horrible gurgling, squishy sounds and braking while turning has provided some hairy moments!
Then I accidently over-filled the power steering pump and the noises went away except if I use the brakes now while steering, the power steering capability drops to ZERO!
I'm 64 and trying to steer this beast in tight places is aging me fast!
truck is a Scottsdale Camper Special and I never intend to run a camper or tow anything major with this truck in the foreseeable future.
Any suggestions?
Thanks!
Wayne
C30Seenemall is offline   Reply With Quote
Old 01-21-2016, 03:50 PM   #2
SCOTI
SCOTI's Avatar
Re: HydroBoost to Vacuum Assist?
I did this swap for my 89 crew-cab dually so yes it can be done.
Like yours, my hydra-boost never worked properly & leaked everywhere. I based my vacuum system off of a similar year model 3/4 ton suburban. The brake booster has to be swapped & you'll need the correct pedal for a vacuum set-up.
While it may not be 'as good' as a 100% new
hydra-boost set-up, it works much better than what was there.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-21-2016, 03:59 PM   #3
C30Seenemall
Thanks for the response!
Would a vacuum booster for a Scottsdale of the same size and year work?
I already have a new one of those.
What is different about the pedal? Or is it the rod from the pedal?
(I'm proving this is my first mid-70's pick up)
Wayne
Thanks!
Old 01-21-2016, 09:21 PM   #4
SCOTI
SCOTI's Avatar
Wayne
Thanks!
The pin for the pedal is located in a different place (vacuum brakes require a different ratio vs HB). The rod from the pedal can be re-used. For my dually, Hydra-boost was the JB8 brake system. I sourced parts for a JB7 system.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
