Old 01-22-2016, 11:05 PM   #26
SuperCtruck
SuperCtruck's Avatar
Re: Crankcase ventilation using old tins???
Ive done alot of digging and found what Brad_54 was talking about. Good stuff here.
http://www.stl-vettes.com/65Vette/re...z4/pcv/pcv.htm
1949 Chevrolet 5 window
1970 C10 CST swb, fleet side
1964 C10 swb, bbw
1968 Camaro coupe
1968 camaro convertible (cream puff)
1972 K10 swb 4wd SuperCheyenne
SuperCtruck is offline   Reply With Quote
Old 01-22-2016, 11:42 PM   #27
SuperCtruck
Originally Posted by 65 C20 View Post
http://67-72chevytrucks.com/vboard/s...ht=dino&page=8
Go to post 178 to see how Dino did it.
Thanks to 60-66
That looks real nice thanks for sharing
1964 C10 swb, bbw
1968 Camaro coupe
Old 01-24-2016, 01:22 AM   #28
raylube
raylube's Avatar
Dont know if it is possible but take a look at the gmc v6 305 design.
POSITIVE CRANKCASE VENTILATION:*is provided by using manifold vacuum to draw fresh air through the engine. Air enters through a*replaceable paper-element breather, travels up through the crankcase to the cylinder head covers,*then through air flow regulating valves directly into an intake port of each head, carrying with it,*into the combustion chamber, harmful sludge-forming fumes and moisture laden air. Bearings and*other precision parts last longer . . . maintenance is less . . . engine life is extended.
Maybe can try to drill and tap bottom of intake or each head and install these pcv and filter at back.
raylube is offline   Reply With Quote
