04-02-2002, 12:06 PM | #1 |
'72 e-brake pedal ass'y in a '67?
What would it take to put a '72 e-brake pedal assembly in a '67?
------------------ '67 Chevy C20 Custom Camper 327/TH400/4.57 '92 Chevy K1500 XCab LWB 350/NV4500/3.73 Aggieland, TX
Ben '68 Chevy C10 Custom LWB 327/TH400 2nd owner '16 GMC Sierra 1500 SLE Dblcab 4wd 5.3 |
04-02-2002, 01:24 PM | #2 |
fab work, not bolt in.. why would you want to do that for ?
------------------ Randy- Lincoln, IL randy@ccaonline.com -71/C-10(thx teeitup and crews!)350 4+4/CH465(thx 71Chev, GMCPaul, and CPNE)longfleet bed(thnx meathead95)!very apart and not driveable still..... -'84 Z28 H.O. 305 L69 700R4 GT4 3.73 - 1984 Firebird SE 2.8L T-5 GT4 3.73 -1981 Cutlass Supreme, dunno what im gonna do with it yet... -79 G20 pass van, 350/th350/10bolt *Paint is overrated © RSS Enterprises 2000 |
04-02-2002, 03:31 PM | #3 |
Several reasons:
- Pedal is more out of the way than the lever. - I have a reflex for emergency braking that is using a pedal instead of the lever. - In an emergency I'd rather have both hands for steering, gear jamming, etc. - Can put more tension on the cable pushing with your foot than pulling with your arm. - Why did GM go to the pedal, anyway? Please give more details--exactly what kind of fabricating is required? Just drilling holes in the firewall and lower dash is all I can think of.
04-02-2002, 04:17 PM | #4 |
I also would be interested in some input on this conversion.
If anyone out there has done this, and can speak from experience, let us hear from you. I would also like to install a later model (69-72) floating gas pedal. This issue was recently addressed and determined to require some metal fabrication and or firewall modifications. The reasons given above sound justifiable to me. I am not a diehard original restoration person but mild upgrades can add to the overall enjoyment and functionality of these vehicles. These are product enhancements, which GM engineers worked out for us.
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
04-02-2002, 04:35 PM | #5 |
cough* camaros, cough* vegas* cough cavaliers* cough cough
at leasxt the 67 68 truck handbrakes have alot longer handbrake handle length and therefore lots more leverage to aplpy the brake with, and at least they always work unlike later model ones. 67 and 68 rule they shoulda never changed them, IMO tip: depressing service brake handle firmly while applying parking brake helps to apply them alot stronger ------------------ Randy- Lincoln, IL randy@ccaonline.com -71/C-10(thx teeitup and crews!)350 4+4/CH465(thx 71Chev, GMCPaul, and CPNE)longfleet bed(thnx meathead95)!very apart and not driveable still..... -'84 Z28 H.O. 305 L69 700R4 GT4 3.73 - 1984 Firebird SE 2.8L T-5 GT4 3.73 -1981 Cutlass Supreme, dunno what im gonna do with it yet... -79 G20 pass van, 350/th350/10bolt *Paint is overrated © RSS Enterprises 2000 |
04-02-2002, 04:50 PM | #6 |
I was considering going to a pedal too in my '67. I just like the looks better. But I'm interested in hearing about the change too if anyone has done this.
04-02-2002, 04:55 PM | #7 |
Fast, I'm not asking you to go out and convert all of your trucks to pedal e-brakes. If you can enlighten us on the procedures for the conversion I would appreciate it. Otherwise, you can start your own thread to educate the world on the evils of the pedal-operated e-brake.
04-02-2002, 07:14 PM | #8 |
how do you adjust the e-brake...mine doesn't engage enough to stop the truck....i haven't messed much with it yet...just wondering if anyone could give me some pointers before i start tearing into it.....
1968 C20 long bed http://home.earthlink.net/~yup00 |
04-02-2002, 08:59 PM | #9 |
I adj. mine by the bolt under the drivers side floor board the 2 cables come together.You can adj it at 1 end it takes alot of slack out
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
04-02-2002, 11:07 PM | #10 |
Has anybody done this who can give us the info?
04-02-2002, 11:43 PM | #11 |
I have done the emergency brake conversion. You need to make a pattern from a 69-72 firewall. Cut it out and make you a template. Then lay it up there and you will see what you will have to move around. I think you will have to weld up the 67-68 fusebox hole and I think one of the large holes for the speedo, I think. Then draw it out and cut new holes. Measure twice and cut once. Not to bad of job. Just take your time. You can use your fusebox, but turn it the other direction. The insulation for the 67-68 is different than the 69-72. So you will have to change it. I think i still have my old template, if you get in a bind. Try to make one when you get the brake assembly. I sure I missed something, but it all falls into place. Makes a cleaner interior.
55 Chevy original swb (big back window) 61 Chevy bubble top (427-5 speed) 67 Chevy stepside (Krusty) 68 Chevy swb fleet (Lola) 68 Chevy swb fleet 71 Chevy swb fleet ( future PB project) 97 crew cab power stroke 07 SS Trail blazer |
04-03-2002, 01:20 AM | #12 |
STP67-72 Thanks for the input.
I've now got a good idea of what it will take to make it happen. I will admit that it helps to have the 71 as a guide. I also have a spare step brake to play with. I know what you mean about those cuts to the firewall, you really need to get it right the first time. ------------------ John Hutchison Grapevine,Texas 76051 71 1/2 ton swb 307 pg 69 Jaguar XK-E 4.2 Roadster
