#901 |
Re: 48 Burb, bagged, 5.3, 20 year wait
I'm liking the progress. nice job on the hinges. those things are noooot cheap if you buy repros, so fixing them is def worth it.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#902 |
![]() Join Date: Jul 2012
Blake, yes the cabs are the same.
#903 |
Thanks 99. Didn't need the bushings amazingly enough. The pins were siezed up though and I guess the doors didn't get much use. They were probably never lubed.
#904 | |
![]() Join Date: Mar 2011
The bag of 100 are called Tee Nuts, used in wood alot. I used them in many builds, also more to weld too. I've used them up to 3/8", not sure if they make them in larger sizes...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#905 | |
Sorry Mark, I was giving Jim credit for the flanged nut idea. Works really well! One of the benefits of spending time here is learning from each other. Here is a link to tee nuts. https://www.fastenal.com/products/de...ee%20Nuts%22|~ |
#906 |
No worries my friend!!
Things like this get passed down from generation to generation AKA Hot Rodding ![]() Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
#907 |
Nice work AD. I like your tank and compressor location. What kind of lines are you running?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#908 |
Thanks Lower, nothing trick on the lines. Just using the dot stuff that came from Ridetech is my plan. Except for the final run to the front bags, where I have a steel braided set up to make use of. And I am always open for suggestions.
#909 | |
Hey Marc, here is the crossmember I mentioned in the PM. I took it out for fuel tank clearance. |
#910 |
Then I threw the body back on the frame to measure for a fuel tank. This one was a custom piece that was in the 56 Chevy when it had the irs and is 4 inches shorter. I think the unit from Tanks will work really well, if it will fit. There is room between the frame and body for the fill to go through the lower body behind the left tire, then turn up and exit through the fender. A friend has one for his current 52 Buick build so I will probably borrow it for test fitting before buying one.
I was also pretty happy with the fit of the tanks and pumps, not so happy with the battery box location. It clears the body well, though with the running boards on I don't know that I can service the battery. Ha on me....restoration guys are pointing and laughing. ![]() |
#911 |
Moving to the other end of the vehicle in figuring out what fits, a friend found this ac compressor mount at Vintage Air. Looks like it will provide clearance to the right inner fender and works with the truck accessory drive. It might interfere with a thermostat housing that points straight forward.
http://www.vintageair.com/2015%20Cat...talog%2068.pdf |
#912 |
And if the 56 tank won't work....it might be too long front to back....the 53 / 54 tank from Tanks is a possibility. Especially if the filler neck connection unbolts like it shows in the picture.
Wouldn't it be great to have all these parts on a shelf so you could just grab one and test fit, instead of guessing based on measurements and pictures? |
#913 | |
![]() Join Date: Mar 2007
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#914 |
I don't think it was on this Burb Marc. I didn't remember removing any body bolts in this area. To confirm, I checked out the original floor and crossmember. There are no witness marks showing a mount.
#915 | |
Marc
#916 |
No problem Marc. I looked yesterday before I took the crossmember out. Glad you mentioned it just in case I needed it.
Another option for the fuel tank is this one for a 65 Burb a friend is building. Going to test fit it in addition to a couple of others. And will evaluate the 69 Mustang with this type of fill too. |
#917 | |
Simple? What's simple?
![]() Join Date: Apr 2007
I suspect, since your engine is about 1" further back than mine, you should be good to go without modifications ![]()
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) |
#918 | |
I just came across another fuel tank option dwcsr linked us to on one of his builds. Didn't remember this one. 68 Camaro tank. Looks like a good option. |
#919 |
Hi A.D. I 've been searching for a tank for my truck too. Lots of options available but I couldn't find any that worked for me so I decided to build my own. I bought a sheet of stainless steel and then all the hardware from Tanks Inc. Probably a more expensive route but it will fit. If you find a tank that fits you could move the fill location with parts from Tanks Inc.
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
#920 | |
Hope you post up your tank build as I would like to follow that! |
#921 |
Well, after lots of measuring, thinking and research I am 99% sure of going with the 68 Camaro fuel injection Tank from Tanks.
Next I wanted to make sure the rear fenders and running boards would fit again with this new chassis. Before I mounted the rear fender I still had 6 or 7 Reaper71 inspired flanged nuts to locate, drill for and install. Another thing I learned on here was to turn the wire speed up on overhead welding from a comment one of the guys mentioned somewhere. I did and what a difference in the weld quality. Anyway, the wheel centers nicely.... yeah, ugly shop rollers. |
#922 |
Install the running boards....I learned there was a difference on my brackets and the left front one was at an angle pointing forward that didn't want to match up with the running board. Hmmm...right front is the same so I swapped them side to side. That worked.
Anyway, mounting the running boards to see if the truck really needs the rear bracket. The 4 link arms mount to the outside of the frame right where the bracket went. And before I mount the left board I rediscovered the center mount on the left board was trashed. |
#923 |
The swag press brake was really handy for this. Using 16 gauge steel I ended up fabricating one from 3 pieces, left side, top and right side. The piece was too narrow for the press brake to make it from one piece.
Old saw horses and 2x boards sure make a handy cutting bench. |
#924 |
Drilled holes and slotted to use the square shank mounting bolts. Of course I did a lot of in place fitting before drilling and plug welding in place.
This took most of two Saturdays as we've been spending a lot of time with the Grandsons coming over. Prayers answered and God is good! |
#925 |
Nice fab work Doug! I will have to do the same with a couple running board mounts too.
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 ![]() |
