#926 |
Re: 48 Burb, bagged, 5.3, 20 year wait
Nice work A/D!
I have been looking at the Swag press brake for a while. How do you like it? Ron
"In an insane world a sane man must appear insane" ~Spock~ |
#927 |
![]() Join Date: Jul 2012
Sid...Thank you for your kind words. If I need to make another I am going to make the small hole a little smaller. This will still work ok though I would like it a bit neater. Maybe someone out there sells reproductions? Took me about 6 hours in the shop to get it done.
Hey thanks Ron! The Swag press brake is a nice little unit. A downside is it won't bend to 90 degrees so I later ordered their top plate which allows bending beyond 90 degrees. The fingers make this one pretty versatile though I haven't had time to explore all it can do. Here is a little assembly thread I put together on assembling the Swag press brake http://67-72chevytrucks.com/vboard/s...d.php?t=657465 On an old subject this is the direction I plan to go on fuel fill. Found it on here in a Suburban build thread. |
#928 |
Nice fabwork Doug!
Those "little" things always take a lot of time!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#929 |
![]() Join Date: Mar 2007
Nice progress Doug. Looks cool to see some body parts bolted back on (even if it is only temporary).
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#930 |
So you have to reach inside the fender to put gas inside it? Ha!
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 ![]() |
#931 |
Kees...thanks, those little things do take lots of time. It took 12 hours to do the left rear fender and left running board install and about 20 minutes for the right side.
Hey Marc, put it together, take it apart...it did feel good to stand back and look at it for a bit. Now that I know it all fits I can take it apart again. Then on to the next item. Sid, thank you for giving me the best laugh I've had all week! I guess since I made the battery location almost unservicable I thought I would do the same with the gas fill too. ![]() |
#932 |
Glad you had a chuckle!
#933 |
SAVING ONE TRUCK AT A TIME
![]() Join Date: Feb 2010
Great work doug.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
#934 |
Great progress. Looks like gas filler will be top of the fender?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#935 |
Thanks Chizzler. I was happy it all fit.
Yes Lowers thank you, I plan to run the fuel fill up to the top of the left fender. The pic above is from a Burb build here. Always appreciate the encouragement and ideas guys. |
#936 |
Nice fab work on the running board mount Doug. Trick looks good with the fender back on even if it's only temporary.
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
#937 |
Great job....
#938 | |
![]() Join Date: May 2007
haha and here I was thinking you were going to stick the pump inside the rear fender to fill, like a hidden filler ![]()
#939 |
Thanks 65sub. My running board mount isn't much after following your cool build though I enjoyed making it. It was nice to see some body parts on, even temporarily.
Coach, thank you. Really enjoying your irs install! Joedoh, you know, maybe I could leave the fuel fill inside the fender, then try to find a full service station.... ![]() Guys, always appreciate the encouragement and ideas. Like ...I had the right front fender and inner installed a few weeks ago. You know how the inner bolts right to the toe board on the right side. My new floor needs drilling, so I center punched the holes in the inner fender to mark the floor for drilling. Took it back apart...and I can't see the punch marks. Will use a paint dot next time. Been getting a little shop time with the wife and a lot of weekend Grandson time. What a blessing. |
#940 |
Moving right along....keep at it. Looking great
#941 |
Good to hear from you Iceburgh and thanks. Figured you were hit with the same heavy snow our daughter down in Hanover was.
#942 |
We got 30" they got a little more south close to the MD line.
#943 |
After exploring a number of different alternatives for the fuel tank I decided to Contact Dwcsr (Dave) at Hollister Road Company for one of his tank and fill pipe packages. You can tell Dave is really knowledgable when he posts to share his projects or helps a member with their questions. I figured I would rely on someone who knows what they are doing, has done this before and provide some business to one of our vendors
Dave promptly replied to my inquiry, talked about a package, put a quote together, and made it really easy to do business. Plus he is a nice guy and really knows how to do this. His package includes the fill pipes and hoses so he sent me the below drawing to comparison measure to the Burb. Nice detail and I figured out the fill pipe will go up through the left fender about where the angle is at the two inch mark. Took some pictures and measurements on the Burb and sent them back to Dave. |
#944 |
I was amazed when a FedEx truck showed up today with the tank and parts from Tanks and Hollister Road Company. Wow, this tank is really nice! I used a tank from Spectra for my last build and there is no comparison to this one.
Like an excited little kid, I had to check the parts. Everything is here that was shipped from Tanks. Dave will be sending the fill pipe later. The tank fits nicely and next time I pull the body back off the frame, I will build an upper cradle to position the top of the tank and use the straps to hold it up. |
#945 |
The same FedEx truck had the Hooker exhaust manifolds from Amazon. I followed FarmerSid's lead on these and ordered them Thursday.
They fit! Left side has a lot of clearance and the right side top of frame rail will need 1/4" or so shaved off. While these look to be nice pieces, I was surprised to read in the instructions they can't be used for a new engine break in as the ceramic coating isn't cured yet. Hooker advises to use some other exhaust manifolds to break in the engine then install the new ones. They even give a break in process for the ceramic coating. |
#946 |
And I decided I was tired of not being able to see while grinding so I fixed that.
#947 |
nice pics and parts. I was going to order that face shield real soon. as for the headers, not sure what they mean by breaking in and LS engine that is a roller setup. also wasn't aware of breaking in ceramic learn something new everyday is good.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#948 |
Good looking parts Doug. I've never heard of a "break in " for ceramic coating either but I guess they would know best. I had mine coated by a local shop and just bolted them on and started driving.
#949 |
looks great! the motor install is probably my favorite part.
anyone else see this photo as upside down? I did until I saw the person in the distance haha
#950 |
Looking good Doug. I will have to remember the headers when the time comes...Oh you should buy stock in FedEx.
Marc
