Old 01-24-2016, 09:23 PM   #1
kitsbeach
kitsbeach's Avatar
Do you think CPP shipped me the wrong spindles..??
Do you guys think CPP might have shipped me the wrong spindles.?
My truck is a 1967 C-10 (6-lug)
You can see in this picture the outside measurements where the ball joints and A-arms would attach is roughly 8 and 1/2 inches (it is actually more like 8 inches because the ball joint surface is recessed).
Name:  Photo 2016-01-24, 1 53 57 PM.jpg
The CPP spindles I ordered are their "Modular Drop Spindles" part# CP30106-2 for a 1963-70 although there is no part number on the casting.
You can see in the photo of the new spindle that the outside measurement is more like 9 inches.
Name:  Photo 2016-01-24, 1 54 09 PM.jpg
And one more picture so you guys can see them both side to side.
Name:  Photo 2016-01-24, 1 50 58 PM.jpg
Does anybody have any ideas.?
Is this normal for the new spindle to be 1/2" taller.?
I'm pretty sure my truck is original (but you never know).
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
1980 C20 Long to short & static drop "Square One"
kitsbeach is offline   Reply With Quote
Old 01-25-2016, 12:50 AM   #2
'68 Newtricks
'68 Newtricks's Avatar
Re: Do you think CPP shipped me the wrong spindles..??
I would put them on and see if they work, but make sure the ball joints are correct for your year. If not, it may be for the 73-87 ball joints. Sorry, my stuff in the newer stuff so I'm of no help
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 01-25-2016, 12:58 AM   #3
kitsbeach
kitsbeach's Avatar
I checked the ball joints and they fit into the spindles and seem to be the right taper (I believe the only difference in ball joints is the taper).
My ball joints are part number2 #101-10037 and #101-10036 which are listed as correct for 1963-1970.
So it looks to me that the spindles are machined right for 1967 ball joints but they measure different than my factory ones.?
Should I proceed.?
I guess the A-arms would be an extra 1/2 apart, does that mean anything or change any alignment measurements.?
Kitsbeach (Ken)
Old 01-25-2016, 01:03 AM   #4
kitsbeach
kitsbeach's Avatar
I just googled "tall spindles" and it seems like a taller spindle is a good idea for handling and tire wear, so maybe CPP adds a little bit on purpose.?
Kitsbeach (Ken)
Old 01-25-2016, 02:25 AM   #5
68bowtie
68bowtie's Avatar
i'm no expert, but this would leave your upper a-arm sitting higher by 1/2", but the lower a-arm and spring wouldn't change. the spindle angle may change very slightly, but i assume an alignment would fix that. i would not sweat it if the ball joints all fit right. i would not think there would be any conflict with the front rim/tire and the upper a-arm, but that might be something to check.
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Thank you all so far you are angels!!
Old 01-25-2016, 11:00 AM   #6
'68 Newtricks
Run 'em and get us an after pic!
'68 C10 SWB
'85 K30 Blazer
Old 01-25-2016, 11:16 AM   #7
steelhorse
steelhorse's Avatar
Most likely it was done on purpose to help camber.
steelhorse is offline   Reply With Quote
Old 01-25-2016, 11:46 AM   #8
kitsbeach
kitsbeach's Avatar
Thanks guys for the responses. I think I will try to phone CPP and see what they say.
There are quite a few stories of faulty machining, although these look machined close to the casting. It may be that post-1967 castings were a bit taller and they use the same castings for all years (and just machine for the different ball joints).
I'll post up what I find and, yes, will post pictures.
Kitsbeach (Ken)
Old 01-25-2016, 11:49 AM   #9
kitsbeach
kitsbeach's Avatar
Here's a shot with just the rear lowered…
Can't wait to get rid of those old 6-lug front wheels and see my steelies all around.
Kitsbeach (Ken)
Old 01-25-2016, 07:20 PM   #10
57larry
CPP never makes mistakes, just ask them
57larry is offline   Reply With Quote
Old 01-25-2016, 07:44 PM   #11
kitsbeach
kitsbeach's Avatar
Ya I bet..!!
Kitsbeach (Ken)
Old 01-26-2016, 03:20 AM   #12
Z10
Z10's Avatar
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 01-26-2016, 09:27 AM   #13
abraham.hd
Lolol
abraham.hd is offline   Reply With Quote
Old 01-26-2016, 11:50 AM   #14
PowerdbyChevy79
PowerdbyChevy79's Avatar
are they drop spindles?
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 01-27-2016, 03:23 AM   #15
kitsbeach
kitsbeach's Avatar
Yes they are 2" modular drop spindles from CPP.
Kitsbeach (Ken)
Old 03-30-2016, 01:12 AM   #16
hotrod1
56 - autocross
hotrod1's Avatar
Did you ever find out the story with the spindles and the size difference?
hotrod1 is offline   Reply With Quote
Old 03-30-2016, 05:16 PM   #17
kitsbeach
kitsbeach's Avatar
I still haven't got them installed (been busy) but have one side done and they look ok.
Maybe they changed over the years and CPP sells one universal size for 67-72..??
Anyway I will find out once I get the alignment done but for now do not know.
Kitsbeach (Ken)
Old 03-30-2016, 10:04 PM   #18
Z10
Z10's Avatar
One word " McGaughys"
http://www.mcgaughystore.com
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 04-14-2016, 02:51 PM   #19
kitsbeach
kitsbeach's Avatar
Just was reading an article in Car Craft magazine about installing drop spindles onto a Camaro and they said the spindle manufacturer purposely made teh spindles taller to help with castor or camber (I can't remember which).
Kitsbeach (Ken)
