#2626 |
![]() Join Date: Aug 2014
Re: Restoring Rusty
and now time for some glamour shots of this sexy beast lowered and wearing her new earings
#2627 |
Re: Restoring Rusty
Well, well, well.
Three snaps in Z formation! I thought you would never ask. ... I'll tell you tomorrow |
#2628 |
Re: Restoring Rusty
Truck looks great in those "glamour" shots.
#2629 |
Re: Restoring Rusty
ha ha, thanks, I love how the proposed landfill site in the background gives purpose to the juxtaposed primary subject as it blends in and out of the overcast playing and teasing the eye with the shadows... its the best I could do ok! jk
#2630 |
Re: Restoring Rusty
looking good.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years. 96 ECLB 2500, 6.5 diesel, auto, gone. |
#2631 |
Re: Restoring Rusty
Looking good, keep the posts coming. I love how fast Summit packages show up. cant wait to see what ya got.
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
#2632 |
Re: Restoring Rusty
It tomorrow already ,where you at and what you got ? LOL
#2633 |
Re: Restoring Rusty
if you recall not too long ago we lowered Rusty and so I figured we would freshen up its suspension so for $165 bucks we picked up this BellTech kit.
Why did we pick this brand as opposed to anything else. 1. The Gabriel shocks you can get from your local parts house did not come in a shorter than stock version, not that I could see anyway. 2. Turns out BellTech is a California company so I wanted to give the local boyz some love. Their website seemed legit, they appear to like / specialize in trucks. Belltech Nitro Drop 2 Shocks Belltech's Nitro Drop 2 is our entry level shock absorber. Designed to be more than just a replacement solution to your OEM shocks. NITRO DROP 2 Notes SN23: Fits Vehicles with 2"-4" Front Lowering SN45: Fits Vehicles with 4"-6" Rear Lowering Installation Instructions |
#2634 |
Re: Restoring Rusty - Rear Shocks
so we decided to work backwards and do the rear ones first, the rear shocks are longer here are some numbers for you all
we did not have to raise the truck on jack stands or nothin, we did it with it just parked in the garage eye hole to eye hole with the truck sitting normal on the ground the distance was 17 1/4 inches once removed the old rear shocks compressed were 13 3/4 inches and 23 inches fully extended the new rear shocks were 12 inches compressed and 18 1/4 fully extended Please Note all new shocks came with a new top bolt |
#2635 |
Re: Restoring Rusty
then it was time to do the front shocks, this proved a bit more difficult probably because I have long tube headers on my truck, so on the passenger side we had to remove the header to get it out of the way to free the shock for the frame, otherwise we had no clearance
numbers for the front as the crow flies eye hole to eye hole from top to bottom was 11 1/2 inches old shock collapsed was 9 1/2 inches and 14 7/8 fully extended the new shock weighed in at also 9 1/2 inches collapsed and 14 1/4 extended |
#2636 |
Re: Restoring Rusty
my daddy taught me to never reuse gaskets especially colapsable exhaust manifold / header ones, so we ran out and got some thicker ones this time which meant we needed a bit longer header bolts 7/8ths vs 3/4, so we got those too. Our headers have a nice 1/4 thick flange
#2637 |
Re: Restoring Rusty
I used the same rear shocks on my 93 truck ,have the fronts but have not changed them yet .
#2638 |
Re: Restoring Rusty
we fandangled the header collector gasket as well so we taught the gal at NAPA something new (her words not mine) when we had to buy a new set of those too, do you see how the Hot Rodding game is played yet?
Honestly all this difficulty could have been avoided had I not been running an X pipe but I want to be cool so I have an X pipe on my exhaust, ha ha |
#2639 |
Re: Restoring Rusty
#2640 |
Re: Restoring Rusty
at this time we were Pot Committed sort of speak to the exhaust and remembered that center rear brake rubber line that just loved to hug the passenger side tailpipe so after [ahem] exhausting all options we decided to eliminate the over the rear axle sweeping tailpipes in favor of some short turn downs, ok 45% bendies as the official turn downs only come in 2 1/4 ID Inside Diameter and we needed 2 1/4 OD Outside Diameter so that they would slide inside our Turbo mufflers
Note: we had to notch the muffler ends in order to be able to squeeze down on these tailpipes to keep them from falling out ... and Problem = Solution I like 'em, tell me what you all think? |
#2641 |
Re: Restoring Rusty
All that work and you didn't buy new lower shock bolts? Sorely disappointed Gregski.
#2642 |
Re: Restoring Rusty
Going to go with the Rear End Defense on this one your honor. [ahem] As you can see the rear axle has gotten zero love so far, so when I clean it, paint it, and service it, [lie] I will replace those bolts then [/lie]
#2643 |
Re: Restoring Rusty
My 93 truck does currently have headers ,not usually a fan of them but they are not leaking yet so Im gonna run em. All my other toys have stock manifolds .My 72 truck had headers on it when I bought it and they leaved no matter what so I got rid of them ,plus they were really beat up.
#2644 |
I know the pieces fit
Re: Restoring Rusty
Are the turndowns on backwards? It looks like the end with the tag is flared.
#2645 |
Re: Restoring Rusty
so turn outs, lol
#2646 |
Re: Restoring Rusty
Thanks, on Wednesday it stopped raining so I even drove the truck to work. It started easily, ran great, sounded good, no exhaust leaks that I could tell, handled adequately, as I sat there strapped with my brand new three point harness seat belt, gripping the brand new steering wheel, I couldn't help but smile...
#2647 | |
Re: Restoring Rusty
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
#2648 |
Re: Restoring Rusty - Two Steps Forward One Step Back
Uh oh, red font this can't be good.
In this quarterly edition of Two Steps Forward One Step Back (TSFOSB) we discuss Rusty's last temper tantrum. As you may recall my truck had a tough up bringing spending majority of the last 40 years working hard on a farm, so he struggles with the good life. Maybe having a three car garage all to himself is too much of a life style change. Maybe having his oily deposits wiped off the floor weekly is not for him. But does that give him the right to fling his hood open at speed on the highway whilst in the middle lane behind a semi, and in front of a hummer? That's right my life flashed before my eyes driving home from work that Wednesday night, luckily no one was hurt, and the damage was limited to that of Rusty and Rusty alone, as the hood won't open now after I vehemently slammed it shut on the interstate. Does this change my feelings for this green machine? No, if anything I think I just passed a paternity test as this exact thing happened to my dad and me 30 years ago, in my fathers beloved Datsun 1200, anyone care to guess the color of that machine? |
#2649 |
Re: Restoring Rusty
Ouch.
Rich Weyand 1978 K10 RCSB DD. |
#2650 |
Moderator
![]() Join Date: Oct 2008
Re: Restoring Rusty
Geez. If She's going to do that kinda stuff put some hood pins on.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
