#51 |
Re: A boy and his 1972 fleetside restoration
Wow ,its looking great ,look forward to more .
#52 | |
1971 c20 LWB Fleet 2wd 'working' Add-on AC & Working heat/defrost manual transmission w/ Power steering & power brakes Family owned since 1971 ![]() ____________________________________ “Life is rough so you gotta be tough” - Johnny Cash |
#53 |
![]() Join Date: Apr 2008
Truck is looking great. Keep up the hard work and keep us posted.
#54 |
![]() Join Date: Sep 2005
Well, I was going to recommend that you keep the patina........ never mind!!
#55 |
I am definitely keeping the tool box section of the truck. I found a pretty good door on the parts board, and am working on repairing the bottom of the with a quarter section from a catalog. I thought the door was pretty cool as well as very useful to keep my tools, straps and other stuff out of the bed.
This has definitely been a fun and challenging project, but I am looking forward to being done so I can drive it around and show it off. |
#56 |
So I managed to get the passenger side door and fender on with minimal trouble. The paint lines lined up exactly even though we did not paint them at the same time. I also installed a cargo light I pulled a few years ago from the junk yard. I taped the area and marked it to ensure that I didn't scratch the paint as well to get it leveled and centered.
#57 |
Looks great and I like the cargo light .
#58 |
So I reupholstered the seat and added heating elements for those cold winter mornings. I was able to save the foam core, but needed new padding. I purchased cotton batting at a fabric store and sprayed the whole thing with fire retardant. Once I finished the seat I scotch guarded the fabric.
#59 |
And the finished seat
#60 |
Just finished the new brakes. After seeing the grooves in the front discs I decided they needed to be replaced. Judging by the cracks in the rear brake liner and how stiff they were, I am not sure the rear brakes even worked so I rebuilt them and got new drums.
#61 |
So as I was doing the brakes I decided to replace the wheel bearings with new Timken ones and that was quite an adventure. The first set they sold me turned out to be for a half ton because they were way too small for the 3/4ton. The shop ended up figuring out that the Dana 60 full floating rear end was the heavier one and ordered the ones for a 1 ton. While they were a bit more expensive, I shouldn't have to do them for quite a long time.
#62 |
Wow, that is really coming along well!
I want to see you fix up the tool box door. I love the idea of extra tool space. In fact, I am such a tool nut, I probably need a utility bed! ![]() |
#63 |
Love your work and great to see you've kept it a 3/4 ton.
John 69 c20, 396, th400, dana60, ps, ac |
#64 |
Great progress!
#65 |
![]() Join Date: Jul 2015
Awesome! Wish I was as far along as you!
#66 |
As part of the wiring of the truck I wanted to make a 7pin trailer harness. I used a camper wiring harness that came with the truck as an example. I cut the ends off of the old intermediate and tail light harness since I had new ones. I used a semi trailer wire and soldered it to the pig tails. I think this is definitely better than cutting up my new harnesses. I also am going to add my period correct variable resistor and the brake controller that came with the truck.
#67 |
Long over due update to bed blasting and prepwork
#68 |
I ended up taking a lower bed corner and modifying it for repairing the toolbox lower section. I then used a spot welder to weld the panel in place using the box insert for alignment.
#69 |
The paint is done on the bed and all of the lines match with the cab even though we painted everything at different times.
#70 |
It looks great!
Further, is that a lwb? If so, you have my increased compliments. |
#71 |
![]() Join Date: Aug 2013
Very impressive progress. Nice truck.
1968 C10 292/3 spd - sold 1969 K10 350/3 spd/205 - sold 1971 K5 350/4 spd/ 205 - sold 1970 K20 350/350/205 - sold 1969 K20 396/400/205 - work in process |
#72 |
All about them K’s
![]() Join Date: Jun 2014
Any more details on what you did to repair the tool box opening? I was gonna modify a rocker panel to repair the bottom of the opening.
Progress looks great!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
Tags |
1972 c20, restoration |
