01-25-2016, 09:13 PM | #1 |
Electrical Assistance Please!
First of all I am posting here because there is more traffic across this board.
I have a 66 suburban I have two issues I am trying to solve. Well, with the truck anyways The first may or may not be specific to a suburban. The license plate light is out and I can not find out how to remove the globe so that I can get at the bulb. I remove the mounting screw and looked it all over for sign of how the globe can be removed. I tried to also just twist off the globe but it doesn't want to twist much at all. The is in pretty good condition so I don't want to be to rough with it. The second is my rear drivers blinker. All the tail light filaments work as they should accept this one. I have verified voltage at harness connection below the back end and at the light bulb housing and at the little spring loaded connection in the bulb mount. I know the ground is good because the running light filament is fine. My initial though was that the wire may have a high resistance connection, so i rigged a wire from the harness connection below the back end up to the taillight housing to rule out that section of wire. I had the same issue, an oscillating voltage from about 4-9(engine off) volts but the light bulb filament would not work. For ****s and giggles I put my wire rig to the other filament(running light) and it did not work either. I did ohm check the bulb filament to make sure they were good too. Right now, I am thinking that there is some sort of high resistance connection upstream of the under bed harness connection somewhere. But I wanted to know if someone with more electrical issues experience could impart some knowledge on me. Thanks in advance.
1971 Chevrolet C10(78 motor), Longbed, 69 Bed I think Quadrajet 4 barrel 7043208, Th350 tranny, No A/C Various components are lightly to highly modified depending on the number of beers consumed prior to modifications performed. |
01-25-2016, 09:53 PM | #2 |
Re: Electrical Assistance Please!
Does the driver's side brake light work?
Aaron 1964 K10 1964 C10 1965 Suburban 2005 Yukon |
01-25-2016, 10:38 PM | #3 |
01-25-2016, 11:32 PM | #4 |
Could be a loose or broken wire under the dash. The only thing you can do now is trace the wire under the dash to see if you can find anything.
01-26-2016, 01:10 AM | #5 |
60-66 Nut
You'll have to start checking for power in that wire, working your way back to the turn signal switch. It could also be in the turn signal switch.
01-26-2016, 07:37 PM | #6 | |
01-26-2016, 10:41 PM | #7 |
Clam shell. I can not get the picture to load from my phone.
Posted via Mobile Device |
01-26-2016, 11:58 PM | #8 |
Remove the entire light bucket and it should come apart a bit easier. The sheet metal is helping hold everything together.
01-28-2016, 02:12 AM | #9 |
looking at the picture , it looks like the bulb and socket pop out from the back side of it
