Old 01-26-2016, 01:13 PM   #1
gottattooz
gottattooz's Avatar
Are the frames the same?
I currently have a 68 short/wide. I have a line on a 72 blazer in rough shape. My plan is to buy the blazer, repair the body and swap it onto the 68 frame. My question being "is this a straight swap, or will I have to swap my drive train and suspension over to the blazer frame?"
- Josh
1967 Buick Special wagon
1968 Jeep Wagoneer
1958 Chevy Panel Truck
2017 Suzuki M109R
gottattooz is offline   Reply With Quote
Old 01-26-2016, 01:21 PM   #2
flashed
Re: Are the frames the same?
I think the truck frame is longer .
flashed is offline   Reply With Quote
Old 01-26-2016, 02:32 PM   #3
29od1
Blazer wheelbase is shorter so you'll have to shorten the frame. There are threads here on how to do it.
29od1 is offline   Reply With Quote
Old 01-26-2016, 02:44 PM   #4
gottattooz
gottattooz's Avatar
Awesome, so only minor adjustments, nothing major. Thanks.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 01-26-2016, 03:19 PM   #5
Wasted Income
Boosted Member
Wasted Income's Avatar
Is it a 2wd Blazer?
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 01-26-2016, 03:25 PM   #6
gottattooz
gottattooz's Avatar
4wd.
- Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 01-26-2016, 03:32 PM   #7
Wasted Income
Boosted Member
I am fairly certain the body mounts for the blazer tub are in different spots than the cab/bed mounts for the pickup. You'll probably need to measure where they are and cut them off the blazer frame and weld them to the truck frame...not a big deal if you're already cutting the frame to shorten for the 11" wheelbase difference.
Also, the 2wd truck frame is wider in the rear (coil springs) than the leaf spring 4x4 frame.
Turbo diesel
Old 01-26-2016, 04:13 PM   #8
snipescastle2
snipescastle2's Avatar
Talking Re: Are the frames the same?
The core support brackets have a larger hole in them, may have to use later core support bushings or buy the older brackets from LMC or cut some off an older frame.
Ben
snipescastle2 is offline   Reply With Quote
