Old 01-27-2016, 09:41 PM   #1
68c10owner
68c10owner's Avatar
5.3LS behind 85 4spd manual?
A friend of mine is picking up a 85 3/4 ton 4wd that is a factory 4spd manual and wants to install a 5.3 LS. Is there adaptors available so he can reuse the original 4spd transmission?
Anthony
68c10owner is offline   Reply With Quote
Old 01-27-2016, 11:17 PM   #2
mongocanfly
mongocanfly's Avatar
Re: 5.3LS behind 85 4spd manual?
I used Advance adapters on mine. Youll need adapter bellhousing and the clutch pressure plate flywheel setup to make it all work. Get ready...it ain't cheap to do.
Old 01-27-2016, 11:23 PM   #3
68c10owner
68c10owner's Avatar
I'll pass it on to him. He might decide on something else. I told him I would ask because I didnt know what was available.
Anthony
Old 01-28-2016, 07:50 AM   #4
Keith Seymore
Keith Seymore's Avatar
If it is the RPO M20 SM465 4 speed it is not a "high performance/racing" transmission: it will have three forward gears and a 6.56:1 creeper low gear.
He might want something else if he is going for "sporty".
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-28-2016, 08:24 AM   #5
68c10owner
68c10owner's Avatar
It's a long bed 3/4 ton 4wd. Don't believe he is going for "sporty". I think more reliable with better power is what he wants but don't think he wants to spend a lot of money on adaptors.
Anthony
Old 01-28-2016, 12:45 PM   #6
slotard
Given the same rear end, I'd expect better highway mileage with an overdrive automatic than a 465. In a 3/4 I'd go 4L80E (or a 6L80/6L90). Or an NV4500 or NV5600 if he wants to keep it stick.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 01-31-2016, 12:42 AM   #7
Zoomad75
K5Camper
Zoomad75's Avatar
You don't have to get a complete advanced adapters setup to run the old school manual trans behind the 5.3.
Follow this link as it has a good bit of info to follow and save bucks from going with the AA stuff.
http://67-72chevytrucks.com/vboard/s...d.php?t=421258
The main issue is the thickness of the flywheel on the gen 3/4 stuff differs from the gen 1 setup. Getting the flywheel they list is a little thicker to take up the difference by making the flywheel surface in the same position as the gen 1 clutch would be in. Meaning, you use the stock bellhousing and clutch. Just make sure to get the LS2 pilot bearing.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
