#26 |
Re: $400.00 2004 1500 4x4 rclb 4.3v6 build. 5.3 swap.
today i serviced the transmission with new filter and fluid. also installed a new aluminum trans pan with drain plug. also serviced the rear diff with new fluid and installed a new aluminum cover with drain plug in it as well.
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's 1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's 1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's 1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's |
#27 |
Master Hater
Hope you changed the frame mounts.....
1997 C1500 ECSB 4.3/NV3500 8.5 3.42 "This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors |
#28 |
??? i guess you are referring to the motor mounts/frame mounts? that is a given in the 4.3 to 5.3 swap as the 5.3 wont come near bolting in otherwise.... ??? i think anyone doing a motor swap is inclined that motor mounts/frame mounts likely wont work from one series of engine/4.3 to the next 5.3.
#29 |
What wiring changes did you have to make for the 5.3 to work?
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
#30 |
all i had to do was add injector wires, coil wires, cam sensor wires, and re pigtailed the knock sensor wires. it was not hard at all. the rest of the v6 sensors and pigtails worked fine on the v8
#31 |
Thanks! I have a 4.3 in my regular cab, daily driver. Gets worse gas mileage that my 5.3 truck had before. Gonna run this buzzin half dozen til it quits (hopefully a long time), but been thinking would replace with 5.3 when the time comes.
#32 |
i like my truck alot more now with the 5.3 lol
