01-30-2016, 11:13 AM | #51 |
Re: SA 56 build
Glad you're back at it.
Looks good. Kim |
02-08-2016, 02:28 PM | #52 |
Re: SA 56 build
Fantastic Build. I have a 55 Task Force and a Series 3 Jag front lying on the floor (arrived last night). I notice you don't seem to have had to notch the top of the frame rail to clear the top A arm mount. Did you move the rails in? I am trying to decide if it I should soft mount or hard mount. As the rails are so wide it does not look like I raise it much more using soft mounts. Have you any profile photos showing how your stance looks?
Sorry for so many questions, but your dash conversion. I assume the main dash shape is fairly symmetrical and once you diced it it all went back together fairly well? Appreciate any comments. Thanks Blair |
02-08-2016, 10:27 PM | #53 | |
Re: SA 56 build
I'll put a profile shot up later this evening. It look low at the moment as I don't have any shocked in. I have it supported with square tube bolted where the shocks mount. A friend helped with the dash. It took a few more cuts than I expected as the dash isn't as symmetrical as it looks at first glance.
Nev Need a bigger garage so I can keep more cool cars alive My build, a long way to go. http://67-72chevytrucks.com/vboard/s...d.php?t=595909 |
02-09-2016, 04:43 AM | #54 |
Re: SA 56 build
Here you go Blair, I am not sure what the final ride height will be.
As mentioned it doesn't have shocks fitted.
02-09-2016, 04:51 PM | #55 |
Re: SA 56 build
Thanks Nev,
Do you know what height the centre of the cross member is off the floor as it currently sits? Looks good if you can get it to sit as it is when finished. I need to strip the top A arm off and sit under the chassis to see if I can get it to clear. If you did not move your rails then it must work :-) Blair |
02-09-2016, 06:37 PM | #56 |
Re: SA 56 build
Nev, good to see some updates again!
Nice work on the inner fenders!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
02-09-2016, 10:34 PM | #57 |
Re: SA 56 build
Thanks, just gotta keep chipping away to keep progressing.
02-09-2016, 10:37 PM | #58 | |
Re: SA 56 build
02-10-2016, 05:01 AM | #59 | |
Re: SA 56 build
02-10-2016, 05:05 AM | #60 |
Re: SA 56 build
Blair, I am not sure if this photo will help but have a look anyway.
If you need any further information just ask and I will assist where I can. You can see there is not much clearance, but there is clearance .
02-10-2016, 04:14 PM | #61 |
Re: SA 56 build
Excellent. Travelling this week, but looking forward to having a measure up when I get home. Thanks for your help. Blair
02-18-2016, 03:45 AM | #62 |
Re: SA 56 build
Nev, just read your thread, I had started an online computer support company, going great. Then the Google B!+(h banned my business. Long story short lost boo koo bucks. So I'm starting over again. Thought I would share this "Life Sucks and then You Live!" Didn't mean to Hi-jack this thread, I was just getting started on a 57 GMC C-4 496 BBC. No I'm on perma hold. Maybe be able to get rolling by the end of the year, great to see the LH drive to RH drive. I Spent about a month in Manchester several years back driving on the wrong side of the road cause me a lot of fear and discord. Keep on keepin on. Nut Case
Been there, wrecked that |
02-18-2016, 07:05 AM | #63 | |
Re: SA 56 build
Good luck with the 57. I look forward to seeing some updates when you get back into it. You know even though my 56 had to stop for a while due to my job situation (i.e. lack of a job ) I ended up getting a couple of great opportunities I never would have been exposed to. Now I think I am in a better position from a life perspective and as a result I can get back into my build (even though I am very busy now). I know what you mean about driving on the other side of the road. My wife and I spent 3 months in the US (best vacation ever) and it was a little daunting driving on the other side of the road for the first few days.
03-12-2016, 03:24 PM | #64 |
Re: SA 56 build
Hi Nev
Getting closer to grabbing the cutting wheel and getting stuck in on mine. The photo was great thanks. Did you notch the cross member of the frame? I meet a guy in Hamilton last week who had his very low and had cut the frame away. Looking at the wheel in the arch it looks like you have used the original centre line? Or did you sneak it forward a little. Regards Blair |
03-15-2016, 05:48 AM | #65 |
Re: SA 56 build
Sorry I took so long to get back to you Blair.
Now I have a job it is taking up lots more time (probably a good thing as those bills don't stop) Here are some more photos of the front end. To be honest I don't remember if we notched the frame, it was so long ago. I do remember we kept the wheel base as per standard. Looking toward front on drivers side Looking from above (driver side) i.e. Right hand side Driver side looking toward the rear Driver side Just ask if you need any more photos.
03-15-2016, 06:10 PM | #66 |
Re: SA 56 build
Sorry to break in Nev68!
@ BlairNZ: There are a few who uses Jaguar IFS and IRS. I have it done too, from page 7 on my build. About the same as Nev68 has done this. My IFS is 3/4" more to the front, to get the wheel better alined, but I have a '59, don't know if that makes a different. The more you know, the better you get
04-04-2016, 10:53 PM | #67 |
Re: SA 56 build
Great info guys I to are working on xj front and rear ifs into 55 long bed. I plan on doing a bolt in so will post pics when I have the body off the frame in a few weeks.
04-26-2016, 04:11 PM | #68 |
Re: SA 56 build
Nice work please keep the photos coming truck looks GR8.
Nev believe it or not there are a few here in the USA that convert their rydes to right hand drive too. Here's one example I took pics of recently here in my city Los Angeles.
I'm not tail-gating, I'm drafting. http://67-72chevytrucks.com/vboard/s...d.php?t=432758 Last edited by BC Toy chest; 04-26-2016 at 04:19 PM. |
04-26-2016, 11:28 PM | #69 |
Re: SA 56 build
What do they use to convert to Rh drive? Jag or something else?
I have a Lh drive 68 Camaro that I don't mind driving on the Lh side of the road, not sure I would be a good passenger though.
