Old 01-30-2016, 06:42 PM   #351
Mrturner1
Re: Starting my engine build
Pulled a rookie move, I'm makin a mad dash to hardware store for engine stand bolts
Mrturner1 is offline   Reply With Quote
Old 01-30-2016, 06:43 PM   #352
Mrturner1
More pics
Old 01-30-2016, 06:44 PM   #353
Mrturner1
What a mess
Old 01-30-2016, 06:46 PM   #354
swamp rat
swamp rat's Avatar
LOL! Glad ya got it out, double or triple up on the flat washers for the engine stand bolts,
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-30-2016, 07:32 PM   #355
Mrturner1
That was all so stressful that I started to wish I hadn't gone this far, and I lost track of the fun part, but now looking at the engine on the stand I wouldn't do it any other way. Fun factor is back! And it's obvious now that building the engine, getting torque ratings correct, sanding and painting, all look so much easier this way.
Thank you guys who gave me a nudge in the right direction, and for checking in constantly and answering questions. Definitely would not have gone for such a big bite, and certainly wouldn't have been able to chew it if I had without you guys' help
Thanks Matt
Old 01-30-2016, 07:33 PM   #356
Mrturner1
Engine out
Old 01-30-2016, 08:18 PM   #357
Mrturner1
Is there a way to clean inside where the crank and rods are?
Old 01-30-2016, 09:17 PM   #358
GRX
GRX's Avatar
Why, is it dirty in there? No sense spreading it around if you are not going to totally disassemble. Treat that thing like an open wound. When not working on it, bag up immediately.
GRX is offline   Reply With Quote
Old 01-30-2016, 10:00 PM   #359
toolboxchev
I used a case of carb cleaner after wire brushing the outside of the block, and razor blades only on the head and gasket surfaces.
Watch that thing when you put the heads on it will want to roll over from the extra weight. Clean Oily rags in the piston holes when not working on it.
Your shop space looks well organized that plays a key role in a successful rebuild.
toolboxchev is offline   Reply With Quote
Old 01-30-2016, 10:01 PM   #360
Grumpy old man
Grumpy old man's Avatar
Glad you didn't get squished taking it out . It will be worth all the work in the end . Now you'll hate to hear it but many of us old guys pull them in an hour and a half . But look how much info and experience your getting from all the guys in here .Have fun be safe and we'll all be watching ...
Old 01-30-2016, 10:36 PM   #361
swamp rat
swamp rat's Avatar
Last time i rebuilt my engine i rented the cherry picker for 4 hours, had the picker back to them within 1 hour 20 minutes, 30 minutes was travel time and i had the engine fluids drained and wiring unhooked prior to getting the picker. I cannot move that fast anymore.
Man just be careful with that 3 wheeler..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-30-2016, 11:03 PM   #362
Mrturner1
What do you guys make of this? Looks like a big weld bead?
Old 01-30-2016, 11:27 PM   #363
geezer#99
geezer#99's Avatar
Someone was welding up a nice crack in the block!!
geezer#99 is online now   Reply With Quote
Old 01-31-2016, 12:38 AM   #364
Mrturner1
This makes me nervous, am I wasting my time
Old 01-31-2016, 12:53 AM   #365
Captainfab
60-66 Nut
Is there coolant leaking past or around the weld? When your truck was running did you need to add coolant every so often? If not, then I wouldn't worry about it.
Old 01-31-2016, 01:01 AM   #366
geezer#99
geezer#99's Avatar
Maybe, maybe not!!
Depends how it was fixed.
A simple gouge out of the crack and a quick weld can cause warping problems.
Proper method would have been to heat the block up before any welding was done and then a slow cooling off.
If it was done wrong then any higher horsepower mods you make to the motor could stress it enough to come apart.
Could be a flip of the coin.
Some may say different but I'd look for a replacement.
You're torn down enough now to make a block swap easy.
Let's wait and see what others chime in to do.
Old 01-31-2016, 02:55 AM   #367
Mrturner1
Wrong gasket....
Old 01-31-2016, 08:41 AM   #368
Grumpy old man
Well....... By the looks of it from what I see in that picture that engine hasn't been apart in a long time and has already had a hard life . Post up a 1/2 dozen pictures of everything on that block inside and out pictures of the cylinders and the oil pump,crank, rods also a picture of the inside of the oil pan .
We can get a much better idea of whats going on with the whole thing ! it looks like your thinking of starting to bolt it back together without cleaning and painting it ?
Here's a little 250 6 I just dropped into a short bed frame for my stockish farm truck build ,Yours should be looking this good OR better before you even consider dropping it back in .
http://
Even if you have to get a new short block your not going to lose money doing it the right way ,Lift your foot up off that imaginary gas pedal your stomping on wanting it done and save time and money doing it the right way. or bolt the greasy thing back together and possibly have wasted all your time and money for all the parts you just bought when you stand on it the first time and a rod finds it way thru your crack welded greasy block ? Why ?
Old 01-31-2016, 12:16 PM   #369
Redline novdog
Redline novdog's Avatar
I'd say that block was out in the freezing weather with out antifreeze. If my memory serves me right that is where they crack with frozen water in them.
Looks to be a good repair. That would make an excellent first motor freshen up job! If goes badly you can learn from it and not worry about trashing an expensive block!!
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 01-31-2016, 12:50 PM   #370
GRX
GRX's Avatar
Big "ouch" on the weld. That is a common freeze crack. As said, if it does not leak you are probably good. Have seen many engines run for years that way. Even so it will always be in the back of your mind.
Old 01-31-2016, 01:41 PM   #371
toolboxchev
That is the reason why you have pulled the block. I like to know what it is exactly "What I Have."
Regardless of what you decide to do at this point you will know:
A. How hard it has been pushed in the past
B. How hard you can push it in the future.
Realizing its a little heart breaking you can now plan you build more accordingly. Blocks are fairly inexpensive.
Old 01-31-2016, 02:05 PM   #372
Mrturner1
http://
Nope definitely not done cleaning yet, I'm with ya on doin it right. I have had that imaginary gas pedal hammered for a while now and it's time to slow it down a bit. My thinking was, clean the mating surfaces of the block and oil pan and get that sealed up, that way I could really lay on the sanding and scraping and not worry about paint and metal debris working its way into the rotating assembly.
Old 01-31-2016, 03:35 PM   #373
davepl
davepl's Avatar
That bead spooks me, but it probably shouldn't, given that it probably wasn't done last week, so it's lasted this long... it'll probably last a lot longer. If it was a recent repair, I'd be more concerned.
Given it's down in the water jacket I wonder if it froze? Almost like they drained the coolant, let it freeze, but didn't pull the drain plugs. Doesn't matter in the end I guess!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-31-2016, 07:32 PM   #374
Mrturner1
I think since it has held this long I'll take my chances. IF it does have an issue when I drive it, what parts could be ruined by the welds failure
Old 02-01-2016, 01:33 AM   #375
Mrturner1
I have a wire wheel for my drill, and some razors and scrapers. Is there anything else to use that can take the old paint off the block? My drill is battery powered so it's not as fast but it is helpful
