Fitech swap on my 1972 K20
I have not done much to my K20 in a while, I had been researching fuel injection for a while and after my brother put a 6.0 LS in his 54 International, I knew it was time to bite the bullet and modernize my old carbureted small block.
.................._____ __________//___{\____ /__---____//____/__---/ .....(O). ..................(O). BUILD THREAD K20 http://67-72chevytrucks.com/vboard/s...d.php?t=651601 pages 2-4 ![]() |
Re: Fitech swap on my 1972 K20
I figured I would show some pics of the current set up before the swap
Currently I'm running a 750 double pump mechanical secoundary, dart aluminum heads , headers , flat top pistons , and a 274 comp cam
Some pics of the new system I went with the tumbled finish in stead of the black, it's rated for up to 600 hp
More pics
This is the most up to date status, I'm currently waiting on the fuel command center to arrive from summit
Subscribed! I have been thinking about how nice this would be myself.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Also going this route.
I'm in!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
How's it going?
Sorry it's been a while fellas , I got a little busy with my school work, but here's some more pics
Inlet fuel filter
Fuel command center
Hopefully today after wireing we will fire the old girl up
#15 |
I just got it going and took it for a ride , the thing runs like a raped ape
#16 |
It's a self learning system, the more it runs the better it runs !
#17 |
Cool.
Is your gas tank in the cab? If so, where'd you run your vent line from the command center?
#18 |
![]() Join Date: Apr 2008
Have you noticed any better mileage?
#19 |
I have not gone for a true road trip yet because of all the snow and salt we just got, but when the weather gets better I will let u know
#20 |
![]() Join Date: May 2003
Hmmmmm......
![]() ![]() I just looked up that Fuel Command Center and that is a slick set-up. You leave your exsisting low PSI pump in place and feed the FCC from it. It's a sump with a high PSI EFI pump inside, and you feed the feul injection with that. Nice & easy !!!! Thanks, now I have to spend more money !!!! "LOL" Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 Last edited by CUSTOM/10; 02-12-2016 at 01:18 PM. |
#21 |
Well fellas I'm into this deep so I figured I would treat the old girl a new set of slanted top value covers
#22 |
#23 |
#24 |
Second Chance Program
Is your fitech setup still running good? Any adjustments that you have had to make?
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
#25 |
Yes yes , the system is running swell, I am very pleased with the product, still to this day I have rarely seen any one not be happy with the system
