Old 02-01-2016, 12:20 AM   #1
AASmedic
AASmedic's Avatar
Steering stabilizer mount
Does anyone know the measurement as to where the steering stabilizer bracket mounts on the tie rod of a 72 K20? I recently purchased the tie rod bracket and from an older thread I can see the approximate location but I was just wanting to know more exactly where it goes.
AASmedic is offline   Reply With Quote
Old 02-01-2016, 12:24 AM   #2
AASmedic
AASmedic's Avatar
Re: Steering stabilizer mount
this is the area I am talking about.
http://67-72chevytrucks.com/vboard/a...1&d=1357950989
Old 02-01-2016, 03:40 AM   #3
swamp rat
swamp rat's Avatar
Just crank the wheel moving the tie rod towards the stabilizer, then collapse the stabilizer and pull it out about 1/4"and bolt it up.
Or if you want after doing the above just put a permanent marker mark on the tie rod, then turn the other way and pull the stabilizer to full extend and mark the tie rod again, you should be able to split the difference.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-05-2016, 04:54 AM   #4
El Dorado Jim
do you still need a pic? or measurement?
El Dorado Jim is offline   Reply With Quote
Old 02-05-2016, 05:02 AM   #5
AASmedic
AASmedic's Avatar
Yes sir. That would be great!
Old 02-06-2016, 02:43 AM   #6
El Dorado Jim
hope I can post a pic, the measurement is from the mount on the axle to the mount on the tie rod, I only have the stabilizer on my '74 axles, my '72 doesn't have a stabilizer.. the measurement from center of bolt to center of bolt is 18 3/4"
Old 02-06-2016, 02:53 AM   #7
El Dorado Jim
