Old 02-01-2016, 03:02 AM   #126
3drburb
Re: What did you do to your Suburban Today?
Originally Posted by Average Joe View Post
Forgive my ignorance, but in what way does it drive better? Is it smoother, corner better, or track straiter? Are you running a rear sway bar?
Thanks for any insight- Brian
All of the above.
A little background on the suspension. Bagged all around with 2.5 drop spindles with front and rear sway bars.
All of the additions made it handle better than stock, but sometimes it could get a little loose around curves or when caught in a little grove in the roads and when the roads are wet and the truck was lowered a lot.
When we lower these trucks to much the rear end will pull to the drivers side because of the stock pan hard bar being bolted to the axle and the driver side frame.
It would get a little scary sometimes, more so when I am running my narrower winter wheels and tires.
So yes, this keeps the track straighter which helps everything (sway bars) to work so much better.
I highly recommend adding a long one if you are bagged or very low.
I hope this answers your questions.
3drburb is offline   Reply With Quote
Old 02-01-2016, 04:23 PM   #127
4shongo
Installed a new Pioneer radio (with Bluetooth), new chrome center vent (real easy to change while radio is out of the way), remounted wiper delay switch to better location under the dash. I'm ready for cruising season to start!!!
4shongo is offline   Reply With Quote
Old 02-01-2016, 08:50 PM   #128
Average Joe
Average Joe's Avatar
Thanks 3drburb! That is a great explanation.
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 02-01-2016, 10:09 PM   #129
3drburb
You are welcome.
Btw the bar cost $129 at Summit Racing with free shipping.
Old 02-02-2016, 12:04 AM   #130
LuckyScott
LuckyScott's Avatar
When I installed the drop kit on my Sub it came with the longer bar. Glad I installed it.
LuckyScott is offline   Reply With Quote
Old 02-02-2016, 05:50 PM   #131
reichdav
reichdav's Avatar
Talking Re: What did you do to your Suburban Today?
Finally got the steering column "guts" back together (again). Replaced the signal parts and upper bearing a second time after pinching the purple wire on first replacement and darn near burning up the 'burb. Also replaced the headlight switch (I hate that design). Pretty much the same as the '57 I restored. Spent more than an hour vacuuming. There's a lot of carpet in the 'burb compared to either of my pickups.
reichdav is offline   Reply With Quote
Old 02-14-2016, 05:36 PM   #132
1968k20
1968k20's Avatar
Almost got stuck, but had fun doing it!
1968k20 is offline   Reply With Quote
Old 02-14-2016, 09:00 PM   #133
Average Joe
Cool. Is that lake Almanore?
Old 02-14-2016, 09:04 PM   #134
Average Joe
Gotta have tunes! Wiper delay is on my list of future mods.
Old 02-14-2016, 10:24 PM   #135
1968k20
1968k20's Avatar
Yes it is lake Almanor!
Old 02-22-2016, 01:12 AM   #136
BK72BURB_3/4Ton4x4
BK72BURB_3/4Ton4x4's Avatar
Remflex Header Gaskets and Extreme Bend Tow Hooks
Tired of blowing through header gaskets so decided to give these Remflex gaskets a try. Also bolted up the pair of extreme tow hooks I picked up from another board member a while ago
BK72BURB_3/4Ton4x4 is offline   Reply With Quote
Old 02-22-2016, 01:53 PM   #137
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Those tow hooks!
68SWB4x4 is offline   Reply With Quote
Old 02-22-2016, 04:48 PM   #138
BK72BURB_3/4Ton4x4
Rear Extreme Bend Tow Hooks
I just sourced a set of these for the back, need to do some drilling and reinforcement but they are a perfect complement to the front hooks!
Old 03-07-2016, 09:30 AM   #139
highwinger
highwinger's Avatar
Last week, my low beams went out...again. I had already replaced the dimmer switch so I picked up a couple headlights. During the troubleshooting, I found one of the tabs broke off the headlight, but the it was really a poor connection at the dimmer causing intermittent lights.
I've also been having troubles with my electric fan switch...again. While I was testing the switch vs temp, I noticed one fan didn't come on at all. So, I ended replacing one of them too. The new fan switch seems to be working better...who knows for how long
highwinger is offline   Reply With Quote
Old 03-08-2016, 08:33 PM   #140
04sshd
04sshd's Avatar
Cleaned up the interior a bit
1968 Chevy C-10 Suburban - 350/350
1969 Chevy C-10 Panel Delivery - 454/400
1972 GMC K1500 Jimmy - 350/350/np205
1978 Chevy Corvette Silver 25th Anniversary
reddit.com/r/chevyc10 <-Join it!
04sshd is offline   Reply With Quote
Old 03-14-2016, 08:05 AM   #141
highwinger
highwinger's Avatar
It's that time of year...Saturday, I spent a couple hours and a couple gallons of gas recharging the AC. Unfortunately, I think this is may have to happen again before the year is out. It's the first time I successfully did it myself though, so that's a personal accomplishment. It was blowing 40deg this morning on the way to work.
Sunday, I got a load of sod to beautify suburban-ia. Poor kids at Home Depot couldn't believe I used the burb to haul sod. I like it because of its utility. I can use it like a truck, it is my daily driver, load the family for trip and/or put it in a car show.
Old 03-15-2016, 08:13 PM   #142
Dburger
Dburger's Avatar
Prepped the '72 "GMC"'s hood for paint:
dslr28 001 by FordTorino73, on Flickr
1967 Hood Work by FordTorino73, on Flickr
dslr22 032 by FordTorino73, on Flickr
1953 Suburban Carryall 3106, 1993 S10 4x4 ext cab
1958 Suburban Carryall 3116 ex school bus
1959 Apache 36, 1984 C30 3+3 DRW 6.2 4MT
1967 C10 fleetside LWB, 1969 Chevy Suburban C10
1972 GMC Suburban C10
1972 Chevy Suburban C10 clam shell/tailgate
Dburger is offline   Reply With Quote
Old 03-15-2016, 08:38 PM   #143
1968k20
1968k20's Avatar
How bout pics of your carryalls?!?
1977 Chevrolet K10 SWB Project 350/4spd/np205
1977 Chevrolet K20 LWB 350/350/203
1991 4Runner 22RE 5 SPD
Yanmar Tractor 3 Cyl Diesel
Old 03-15-2016, 09:52 PM   #144
Dburger
Dburger's Avatar
http://67-72chevytrucks.com/vboard/s...postcount=2689
I have two 383 strokers and eventually, one will go into this '72 GMC. For now, it's sitting outside without a hood.
Old 03-17-2016, 05:03 PM   #145
Dburger
Dburger's Avatar
More hood prep today.
More 1967 Hood Work by FordTorino73, on Flickr
Old 03-18-2016, 11:51 PM   #146
1968k20
1968k20's Avatar
I brought Paloma home today (67 GMC)! She's the one on the left. Cupcake is the other one.
Old 03-19-2016, 01:32 PM   #147
HO455
HO455's Avatar
Love the old school brush guard on Cupcake.
RIP Bob Parks.
Old 03-19-2016, 02:09 PM   #148
1968k20
1968k20's Avatar
That brush guard on cupcake was given to me by the original owner!! He payed $40 for it in 71!
Old 03-19-2016, 04:16 PM   #149
HO455
HO455's Avatar
Too cool! I couldn't resist. I had to look up how much that would be today. $231. A pretty good deal even if you didn't know it would last 45 plus years.
RIP Bob Parks.
Old 03-22-2016, 04:07 PM   #150
RedRoad
RedRoad's Avatar
Polished and detailed some old hubcaps. Hope they dont pop off the rims when I hit a bump!
RedRoad is offline   Reply With Quote
