Old 02-01-2016, 08:11 PM   #151
Cape Codder
Cape Codder's Avatar
Re: Shucks First Build
Could be the combination of the way the light hits it and that stripe drawing your eye.
Cape Codder is offline   Reply With Quote
Old 04-24-2016, 02:13 PM   #152
Shucks
Shucks's Avatar
Came across some more money and bought some more parts. I'm just trying to put it together so I can drive the truck this summer. I'll worry about paint later. Rebuilt my entire steering column though, do feel accomplished about that.
C H E V R O L E T
Check out my build thread!
Shucks First Build
Shucks is offline   Reply With Quote
Old 04-25-2016, 12:41 AM   #153
Shucks
Shucks's Avatar
C H E V R O L E T
Shucks First Build
Old 04-25-2016, 11:50 AM   #154
aggie91
I'm just glad to be here!
aggie91's Avatar
Progress looks good.
Nothing wrong with driving it for the summer.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 04-25-2016, 11:59 AM   #155
truckfan
truckfan's Avatar
was that you I saw the other day on K-10 coming back from JOCO? i was in my 77 454 and you were in an extended cab 92-98 Chevy.
1981 Chevy C30 440 Holmes 42K one owner miles
truckfan is offline   Reply With Quote
Old 04-25-2016, 11:04 PM   #156
Shucks
Shucks's Avatar
That was me! I noticed it was you, and I love your pickup. Wish mine was that far along.
C H E V R O L E T
Shucks First Build
Old 04-26-2016, 01:20 AM   #157
Jrgunn5150
Nice work! I'm a little behind you, but like you, just hoping to be able to drive it this summer, looks great!
J.R.
Link to Daryl's build, http://67-72chevytrucks.com/vboard/s...10#post8443010
Link to my Youtube channel with build info, https://www.youtube.com/thedrivewayengineer
Jrgunn5150 is offline   Reply With Quote
Old 04-26-2016, 08:37 AM   #158
truckfan
truckfan's Avatar
you will get there. you took on a big task. mine was mostly done when I bought it.
my son is Braden Smith who has class with your buddy Jadan Johnson.
Old 04-26-2016, 02:04 PM   #159
Shucks
Shucks's Avatar
Cool man, I never knew him personally but I know the name.
But yes I took on a task I didn't realize what I was going to get myself into. Glad I did it but man it gets tough, exhausting, irritating, exciting and very very expensive..
C H E V R O L E T
Shucks First Build
Old 04-27-2016, 07:21 AM   #160
WE B CRUZN
WE B CRUZN's Avatar
Nice work you will be on the road in no time. The dash cover from LMC that you used is it padded or molded plastic?
WE B CRUZN is offline   Reply With Quote
Old 04-27-2016, 07:54 AM   #161
Shucks
Shucks's Avatar
Molded plastic
C H E V R O L E T
Shucks First Build
Old 04-30-2016, 10:59 PM   #162
Shucks
Shucks's Avatar
Put a fuel regulator in.
C H E V R O L E T
Shucks First Build
Old 05-01-2016, 07:13 AM   #163
Cape Codder
Good to see you back at it and looking good inside there. I don't like the looks of the fuel reg. You have a mech. pump that really doesn't need a regulator and you have a lot of extra rubber fuel line under pressure in front of the headers a leak could spray them with gas. If you look at factory systems on these trucks everything after the pump is hard line and mounted to the motor. The rubber line going into the pump is not under pressure. Modern pressurized fuel line is different and uses different clamps also. I notice a lot of modern vehicles going up in flames when wrecked also.
Old 05-01-2016, 10:32 AM   #164
Shucks
Shucks's Avatar
I was told by several different people that a regulator would be for my benefit. Without it the truck was running really rich. Im not sure what else I would do.
C H E V R O L E T
Shucks First Build
Old 05-01-2016, 11:23 AM   #165
Cape Codder
If you have to much fuel pressure it would not aloww your floats to close the fuel inlet and you would have gas overflowing from the carb. If that is not the problem the fuel mixture is adjusted with carb tuning. Pressure regulators are usually used when you have an electric high volume pump overpower carb floats. You may need to rejet your carb or adjust you mixture screws.
Old 05-01-2016, 12:54 PM   #166
Shucks
Shucks's Avatar
Maybe I'll try that. I figured if I set a lower pressure it could fix some situations. Maybe not. I'll try some new jets. My old Holly had 65s and it ran without problems. I believe the quick fuel stock has 68s. I'll look into that.
C H E V R O L E T
Shucks First Build
Old 01-26-2017, 01:14 PM   #167
Shucks
Shucks's Avatar
Hey I'm back, its been a minute.
So I'm in the process of building a budget on a 5.3, which I have and a 4l60e. My only question is will the fuel tank I put in my truck work with a little modification for the LS? I have yet to see this fuel tank used on any LS swaps and I already have a fuel door cut out in my bed wood and don't want to move it for any reason. Any answers? OR should I just finish the truck then do the LS swap when I finish? I need others opinions because I keep going in circles.
Not much has been done since I'm at the point where the finishing stuff is super expensive. Wheels, Tires and Paint...
C H E V R O L E T
Shucks First Build
Old 01-26-2017, 01:49 PM   #168
daddyjeep
daddyjeep's Avatar
You may be able to install an in tank fuel pump into that tank, if not just run an external fuel pump. The engine shouldn't care how the fuel gets to it as long as it is the correct pressure.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 01-26-2017, 03:51 PM   #169
aggie91
aggie91's Avatar
If you are keeping the tank, use a Bosch 044 (or similar) external pump with a filter before the pump.
Karl
The LST Challenge:
Old 01-27-2017, 07:49 AM   #170
LT7A
Hey Shucks, if you get the chance, go back and fix your picture links from the start of your build. I'd like to see the whole story but it gets a bit tedious trying to follow along when the pics are dead. Good luck to ya.
Old 01-27-2017, 08:12 AM   #171
Shucks
Shucks's Avatar
Wow that sucks, I didn't realize they were gone. Hope I didn't lose those, I've got several from the beginning if I can't figure that out
Old 01-28-2017, 11:39 AM   #172
LT7A
Cool man. It'd be cool to follow along from the beginning. Maybe you need to renew your membership at photoshack? I'm no expert on that stuff, but that appears to be the host of the early pics.
Old 01-28-2017, 01:45 PM   #173
Shucks
Shucks's Avatar
I updated my subscription with them with no luck. I emailed them to see what I need to do. In the meantime, heres a summary of the pictures that aren't there.
The photos that are missing basically is the engine build it looks like. The rest of the photos start back up on page 3 I believe.
C H E V R O L E T
Shucks First Build
Old 01-30-2017, 10:53 PM   #174
Shucks
Shucks's Avatar
Here's a little video of it
C H E V R O L E T
Shucks First Build
Old 02-04-2017, 02:57 PM   #175
Shucks
Shucks's Avatar
Back to the body work. This is the last patch I have to do then it's on to the body. Painting the truck myself, Its decided, LS is going to wait till I'm done.
I pull the cover off this when I need motivation
C H E V R O L E T
Shucks First Build
