Old 02-01-2016, 09:55 PM   #1
Jraney
Bags on a 64
Hey folks I finally got a correct frame for my truck. Now I've got to figure out how or where to put the bags for the rear. The frame design has me a little concerned I won't be able to get the results I want. I want a comfortable ride height but when parked I want the rockers on the ground. Is this possible without breaking the bank. Money is an issue. So I need yalls best ideas. Thanks.
Jraney is offline   Reply With Quote
Old 02-02-2016, 07:47 AM   #2
PGSigns
PGSigns's Avatar
Re: Bags on a 64
If you plan to put the rockers on the ground you will need a good bit of fab skills and and a chunk of change. You can pancake the front crossmember and notch the frame in the front to get it down. The You can flip the trailing arm brackets and build your own notch for the back. That will get you close. You may have to raise the floor in the cab to make room for the trans as the engine may have to go up as you raise the cross member. You will need to raise the bed floor. Staying with the 15" wheels with a 225 70 tire will help get you down verses a tall wheel and tire combo. Both the projects section and the suspension section have more info on this task.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-02-2016, 10:46 AM   #3
LVPhotos
LVPhotos's Avatar
Re: Bags on a 64
Sometimes the cheapest way is not the best way. Z-ing the frame is for good fab/weld type. I started with rear bags on Schrader valves. Notching the frame and major work to front to get it down. The nose is typically 3 to four inches off ground with inner fenders.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 02-02-2016, 12:25 PM   #4
Jraney
Re: Bags on a 64
Hey thanks for the info. I was afraid my plans wouldn't work. I could do the fabrication I just don't want to wait that long. Oh well. Thanks anyhow.
Old 02-02-2016, 05:20 PM   #5
SCOTI
SCOTI's Avatar
Re: Bags on a 64
What was your plan?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-02-2016, 06:33 PM   #6
Jraney
Re: Bags on a 64
My thoughts were I could notch the rear and the front would be fine. I've never done anything lie this before and wasn't able to find good info with pics to see how it should be done correctly.
Old 02-02-2016, 08:18 PM   #7
PGSigns
PGSigns's Avatar
Re: Bags on a 64
What happens in the front is the cross member and the lower a arm cross shafts land pretty quickly. If you roll under your truck and measure from the cross member to the ground, the rockers to the ground and the frame at the same place you measure the rockers you will get a feel for the differances. That's where porterbuilts drop members come in. If you go look at there stuff and take a look at the way they bring the suspension up you will see what it takes to get the rockers on the ground.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 02-02-2016, 09:05 PM   #8
Jraney
Re: Bags on a 64
Thanks. I think for now I'm gonna replace the springs with bags for the better ride then in the future I may decide to go all the way with this.
Old 02-03-2016, 07:51 AM   #9
PGSigns
PGSigns's Avatar
Re: Bags on a 64
You may want to do some reading on bags. They dont always give a better ride. I have one on air and one on springs and will see how the air truck does when done. With the drop springs and good shocks the ride is pretty good. I drive mine every day.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 02-03-2016, 08:29 AM   #10
Jraney
Re: Bags on a 64
Ok. Thanks.
Old 02-03-2016, 01:02 PM   #11
SCOTI
SCOTI's Avatar
Re: Bags on a 64
Ride quality comes from optimum bag selection for each specific application. What rides great on one truck (say one utilizes drop spindles vs another that doesn't) may not work as well on another.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-03-2016, 02:34 PM   #12
Jraney
Re: Bags on a 64
How do I know what's best.
Old 02-03-2016, 03:54 PM   #13
SCOTI
SCOTI's Avatar
Re: Bags on a 64
You need to know the dimensions of the bags you're looking at & how much room you have to work with on your ride.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
