02-02-2016, 08:19 AM | #1 |
Threadlock
I am putting my truck back together. I am assuming to use the blue stuff on all bolts. Door Hinges, door hardware, fender bolts, hood hinges. Thoughts
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
02-02-2016, 09:10 AM | #2 |
Re: Threadlock
Building mine, I'm only doing it on the flex plate. Every. Other. Bolt, gets anti seize.
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
02-02-2016, 09:59 AM | #3 |
Re: Threadlock
I've never used threadlocker on body parts fasteners, but I try to use OEM-type bolts, nuts, and screws like these: http://www.lawsonproducts.com/Body-B...e/AT100160.lpc
I do like the anti-seize suggestion in the post above.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
02-02-2016, 10:34 AM | #4 |
Re: Threadlock
If you had to drive on the roads like I have here, you would threadlock everything. Maybe even use aircraft bolts with the safety wires. (Spot welding is optional). It's amazing what I find loose that normally is never an issue.
"Off the grid and on the seven day weekend plan" "One person cannot know everything, but between all of us, there isn't much we don't know." |
02-02-2016, 12:44 PM | #5 |
Re: Threadlock
I am using all original bolts, thanks for the update. The doors are complete and I was going to go out tonight and take every bolt off and threadlock them one by one.
Thanks Chris
02-02-2016, 03:03 PM | #6 |
Re: Threadlock
I would research this on the threadlock website. They list the various types of threadlock and where each one should be used.
I had trouble with a crank pulley being thrown off twice (possibly due to a bad harmonic balancer.) I used the recommended threadlock for that application (had to buy it online). I think I also used it on my valve cover bolts. I would probably use it wherever the threadlock website recommends. |
02-02-2016, 09:59 PM | #7 |
Re: Threadlock
One place to NOT use threadlock is the exhaust system.
The bolts will break off or round off the bolt heads. Use antiseize on exhaust components. And new hardware torqued properly. Otherwise, I fully agree with doing research on what flavor threadlock is applicable to what you are doing.
