Old 02-02-2016, 04:41 PM   #1
Sweet Willy
Sweet Willy's Avatar
Need a softer ride in my stock 80 c10
I have a stock 80 c10 that rides way to rough for me. Any recommendations for soft riding shocks. My truck is just a driver. No hauling at all.
Thanks.
I don't have a bucket list but my "F....it" list is a mile long.
http://67-72chevytrucks.com/vboard/a...1&d=1411272730
Sweet Willy is offline   Reply With Quote
Old 02-03-2016, 09:34 PM   #2
akart
Re: Need a softer ride in my stock 80 c10
I have a K20 '74 1 ton frame and suspension and '84 3/4 ton running gear. Felt like the axles were bolted to the frame. Tried some Koni shocks, 150.00 for the set and not much better. Switched to Rancho 9000 adjustable shocks and Wow what a difference. Got them set at the lowest setting. About 100.00 per shock but well worth it. Live in Alaska w/lots of rough dirt roads.
akart is offline   Reply With Quote
Old 02-03-2016, 11:06 PM   #3
durty harry
durty harry's Avatar
A buddy put a set of Monroe senatracs on his 80 short bed and WOW that truck rides like a dream
Scott
82 step side aka " Bouncy "
73 GMC
Long bed Vortec 5.7
durty harry is offline   Reply With Quote
Old 02-03-2016, 11:24 PM   #4
cadillac_al
Willy, does your truck have some kind or large replacement shocks on it? maybe some heavy springs in the rear? If it had the old rusty stock shocks on it, it should ride like a marshmallow. Just about every C10 I have ever rode in rides very similar to my 70's Cadillacs. I have Monroe Sensa-tracs on a couple Caddys and they should ride soft enough. I usually carry a load in my K15 just to make the ride tolerable.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 02-03-2016, 11:30 PM   #5
Sweet Willy
I guess I'll give the Monroes a try. If I can afford them. : )
Old 02-04-2016, 12:36 PM   #6
MikeB
MikeB's Avatar
Yeah, unless your truck has some kind of super HD shocks, new ones won't soften the ride.
My base 82 C10 has a fairly decent ride with stock suspension and new KYB GR-2 shocks. Last year I bought a set of 4 for around $100 and got a $40 rebate from KYB!
I see where RockAuto sells Monro-Matic Plus shocks for less than $20 each. I'd guess those are anything but HD.
On another note, what kind of tires do you have, and how much air pressure do you run?
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is online now   Reply With Quote
Old 02-04-2016, 02:09 PM   #7
tucsonjwt
I bought a 2000 Silverado 1/2 ton new and it had a very bouncy ride. I installed Edelbrock IAS shocks and Velvet Ride rear shackles. I don't think Velvet Ride is in business any longer, but other companies make shackles with rubber bushings like them. The Edelbrock shocks helped a lot, the Velver Ride shackles helped some. The improvement was most noticeable on washboard roads. Both products are very pricey. Edelbrock may be out of the shock business, but Summit has some on their website for cheap.
http://www.sulastic.com/truck-shackle-suspension-sa-06
http://www.summitracing.com/search/p...onotube-shocks
tucsonjwt is offline   Reply With Quote
Old 02-05-2016, 12:06 AM   #8
Sweet Willy
I used to say that I had proof I was an idiot because I had quit smoking for 9 years and started up again. Now for the latest. I was driving to O'rielly's today and remembered I had aired up my tires to 32 psi. I thought why did I do that since I don't haul and I don't tow anything with my truck. When I got to O'rielly's I asked the clerk if I could borrow a tire gauge because I wanted to lower the pressure in my tires. He then went out to my truck and did it for me. Nice kid. That's when I found out I needed a new tire gauge. One tire was 32 psi, another was 36 psi, another was 40 psi and the last one was almost 45 psi. When I drove home I found out I don't need shocks.
