Front end travel limiters and shock relocation
I changed the front coils on my truck recently to a custom spring from coil spring specialties. It sits a lot lower than it used to. I only have an inch of travel in the front shock before its bottomed out now. Does someone make a relocation bracket that will work with the stock style shock(stud upper mount). I just bought new QA1 single adjustables and don't really want to buy another set of shocks.
And now when I launch the truck I have so much upward travel the alignment is way out of wack when the truck is all the way up in the air. What have yall done for travel limiters on the front end?
70 longbed 496/th400/Ford 9" |
![]() Join Date: Mar 2008
Re: Front end travel limiters and shock relocation
If you look at post 198 in my storytime thread my old front end is pictured. Its kinda simple but effective. I used 3/4 all thread with a nut welded to the top of the upper control arm. The all thread will make contact on the crossmember as a stop. You just cut it to length and use a jam nut on top. Its good for limiting around four inches of upward travel. Make sure you buy hardened all thread.
NHRA Super Street 469C It only runs 10.90 at 156 mph I was Dragtruck when Dragtruck wasn't Cool! |
It's Better With Nitro
I ran into a similar situation many years ago. I fabricated a new upper shock mount bracket and located it at the top of the frame rail. If I would've waited another year, a few aftermarket suppliers started offering them.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
I decided to order another set of coil springs with another 1.5" of ride height after I realized my control arms are scraping and I can't get it on and off the trailer without dragging badly. Combined with the other two issues I think I'll start with a taller spring
