Old 02-03-2016, 11:01 PM   #426
Bomp
Bomp's Avatar
Re: My suburban's Twisted Little Sister
Interesting configuration on the back floor section.
Can't wait to see it all together, like the direction, Im just having a hard time fully understanding the whole enchilada.
Dig those beaded panels. Totally envious.
Bomp is offline   Reply With Quote
Old 02-04-2016, 09:57 PM   #427
65sub
65sub's Avatar
Thanks Bomp. I didn't mean to keep my plan a secret, and trust me I do have a plan. The area above the gas tank is for the air tank and compressors. Then the floor with a hinged access panel will go above that. The rear doors will be changed from an upper and lower tailgates to just the upper gate lengthened about 8 inches.
We had short day today but we did make some gas tank straps and mounting brackets. Then since we will be moving on to the firewall soon we dug out the bare block and transmission case to use for mock up
Dale
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 02-04-2016, 09:59 PM   #428
pimpston65
pimpston65's Avatar
finally the V12 is back!!!!
pimpston65 is offline   Reply With Quote
Old 02-05-2016, 12:39 AM   #429
62stepside longbox
62stepside longbox's Avatar
This is where it really starts to get interesting
V12 power
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 02-05-2016, 04:27 PM   #430
lower50's
lower50's's Avatar
So cool I forgot your using a jag V12
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 02-08-2016, 08:32 PM   #431
65sub
65sub's Avatar
V12 power
Yes guys the V12 makes an appearance but just for mock up at the moment.
Our first attempt at installing the motor ran into a few obstacles. The oil pan hit the motor mounts, the cam cover hit the firewall and the transmission hit the tunnel. So out comes the cut off wheels.
Dale
Old 02-08-2016, 08:39 PM   #432
Trixxterr
Mmm, nice. Looks like some massaging is goin to be in order. I don't think it's going to run right in that position. Lol.
Trixxterr is offline   Reply With Quote
Old 02-08-2016, 08:45 PM   #433
65sub
65sub's Avatar
We started cutting just a little from the firewall above the transmission. We soon realized we needed more more space. Then we cut a larger opening up to the wire gutter.
Dale
Old 02-08-2016, 10:01 PM   #434
Bomp
Bomp's Avatar
Thats more like it.
Motor/trans in, level. Build truck around it.
I like it.
Old 02-09-2016, 09:22 AM   #435
lower50's
lower50's's Avatar
Sounds familiar: motor, trans, cut body to fit. That looks so cool sitting there.
1951 MG TD
Old 02-09-2016, 08:09 PM   #436
Advanced Design
Advanced Design's Avatar
I always love the newbie question of...Can I fit xxxxx engine in such and such vehicle....and from now on I can answer....sure you can if you can do this....and send them here.
Such cool and skillfully determined fab work 65!
Advanced Design is offline   Reply With Quote
Old 02-10-2016, 10:25 PM   #437
piratexpress1369a
piratexpress1369a's Avatar
thats cool ..is the motor sitting on the rack and pinon
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 02-11-2016, 10:38 PM   #438
65sub
65sub's Avatar
Thanks Trixxter. We did have to cut a bit to get the motor level.
Thats more like it.
I like it.
Thanks Bomp. Sounds simple doesn't it.
Thanks lower. Kinda like doing a diesel build.
Thanks Doug. Can I .... is a question that never gets asked. Should I ... but never can I ...
Thanks Pirate. The motor is sitting just behind the rack high enough for the harmonic dampener to clear.
To make the motor mounts we started by making bracket to bolt to the block. Next we bolted stock chevy motor mounts to the bracket. Then we bolted them to the block
Dale
Old 02-11-2016, 10:45 PM   #439
62stepside longbox
Nice work dale
Old 02-13-2016, 02:02 AM   #440
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Lots of progress... I've been really busy (and stressed ) at work, and busy with family stuff, but I check in whenever i have a chance to see whats happening. I love checking in on your build!
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
Old 02-13-2016, 11:11 PM   #441
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Awesome build. I know all about getting a monster motor to fit. Lot of tunnel work.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 02-16-2016, 05:46 AM   #442
ibrown50
ibrown50's Avatar
Here you go Dale
They're 8" wide and 14" long, stamped from 1.4mm (from memory), ones a bit rusty but will clean up fine, done on the original Abbey Panels tooling.
And below in their natural habitat
Getting old sucks.............but it sure beats the alternative
ibrown50 is offline   Reply With Quote
Old 02-17-2016, 10:40 PM   #443
65sub
65sub's Avatar
Nice work dale
Thanks Nik
Hi John. Working on your truck will take care of any stress. At least it does for me
Thanks Chizzler. If you can make that big diesel fit then I should be able to get my motor in.
Originally Posted by ibrown50 View Post
Here you go Dale
Attachment 1499829
Attachment 1499830
Attachment 1499831
Thanks Ian those are very cool.
Yesterday we got the motor mount frame brackets welded in. Next time the motor comes out we'll box them in. Today we removed the passenger side of the firewall to get ready to install a new one.
Dale
Old 02-17-2016, 11:29 PM   #444
65sub
65sub's Avatar
When we cut out the firewall we found more rust that we had to remove. Then when we cut that out we found an apartment complex for rodents above the kick panel vents. And since we had lots of access we cut off the bottom of the kick panel. We finished today tacking in a patch panel on the front of the vent box.
Dale
Old 02-18-2016, 12:07 AM   #445
lower50's
lower50's's Avatar
Nice job Dale. Stupid mice. Whats the story with the yellow '68? quad cab?
1951 MG TD
Old 02-18-2016, 11:43 AM   #446
62stepside longbox
Looks good dale, I was wondering as well about the yellow truck
Old 02-18-2016, 09:50 PM   #447
65sub
65sub's Avatar
Thanks guys. The yellow truck is a 67. Originally from California I found it as an abandoned project in a barn 1/4 mile down the road. It has a 327 with a 700r4.' We stretched the cab 27" and made the extended cab rear doors. Then we cut 27" out of the front of the box. Now I'm just waiting for the snow to melt.
Today we got the patch panel welded
Dale
Old 02-19-2016, 01:36 PM   #448
piratexpress1369a
Looking good stay at it
63
Old 02-22-2016, 09:24 PM   #449
65sub
65sub's Avatar
Thanks Pirate
Friday we replaced the section that we cut out of the kick panel. Today we started by patching one of the holes for the heater intake.Then we made panels for the toe board and firewall and got them tacked in place
Dale
Old 02-23-2016, 03:35 AM   #450
Grizz1963
Grizz1963's Avatar
Like quite a few builds on here, you continue to be my touchstone of sanity.
I am on week two of a seven week classroom training course in haematological anti-coagulation and find myself looking in on threads with much envy.
I guess this will pass and I will be able to pay my mortgage and buy bits for my engine and do my truck further.
Thank you as always for posting up and sharing.
There..........
I feel better.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
