Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-06-2016, 05:09 PM   #1
Ont67shortbox
HP/TQ and ET/MPH predictions on new combo
Can you guys give me a ball park on the following combo,I will try and give as much detail as I can,if I forgot something let me know..
.030 over 427 BBC (433)
factory crank and rods resized with ARP bolts
Balanced
SRP 158830 forged pistons approx. 12-1
Comp solid lifter cam 11-693-8
262 @.050
.652/.652 lift
ic 106/lc 110
Dart Pro 1 heads 310 cc
2.25/1.88
Hooker 2 inch headers
Edelbrock vic sq port intake
Holley 850 HP dualpump/dual feed
MSD dist and pro coil Taylor 409 wires
rebuilt 350 turbo trans
full manual forward pattern
TCI 3600 10 inch convertor
built 9 inch Ford 31 spline axles
strange center with 4.86 gears
shift probably around 6800/ 67 chev short box approx. 3900w/driver,Thanks
Ont67shortbox is offline   Reply With Quote
Old 02-06-2016, 06:46 PM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: HP/TQ and ET/MPH predictions on new combo
Assiming it has been tuned and has a correct fuel curve,, you should have no problem making 650+ and a mid/high 10 if you have traction,, that could be a BIG "IF". It will require stickeys and a well tuned suspension to get there.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 02-06-2016, 07:25 PM   #3
Ont67shortbox
Forgot to add trailing arm suspension with 30x11 slicks,this is strickly a race vehicle in the Nostalgia class,not streeted any more
Old 02-07-2016, 11:42 AM   #4
regan wilson
regan wilson's Avatar
I'm with Marv on that one. 650hp and mid to high (probably 10.80 .90 ish) optimal conditions. You need a little more convertor though.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
I was Dragtruck when Dragtruck wasn't Cool!
regan wilson is offline   Reply With Quote
Old 02-07-2016, 11:46 AM   #5
regan wilson
When I say more convertor. I mean a dyno sheet sent to the TC builder.
Old 02-07-2016, 02:31 PM   #6
71Dragtruck
71Dragtruck's Avatar
I'm going to be a dream crusher and say mid 11's.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 02-07-2016, 08:33 PM   #7
Ont67shortbox
cam works from 3000-7200
Old 02-07-2016, 08:57 PM   #8
regan wilson
My junk ran 11.17 @ 117mph in 1989. That was with an old 468 with LS6 pistons (11.5 to 1) closed chamber square port heads Comp cams solid lifter cam .637 lift (cb 310). There are two of those cams from Comp I had the better one. lol. Anyhow the lobe center was 110 and I had it setup at 104. These old trucks are heavy and anything but aerodynamic. You need torque!
It ran 10.30 at 130 on the spray!
Old 02-09-2016, 12:22 PM   #9
Ont67shortbox
Yes I realize that, but since it is a Nostalgia class,454s didn't come out in 67,thats why it has a 427,have to make the best of what I have to work with and there is a .675 restriction on lift
Old 02-17-2016, 02:03 PM   #10
68c10owner
68c10owner's Avatar
Have the heads flowed and then speak to Mike Jones or Chris Straub for a camshaft. Are you limited to a flat tappet? If not I would go roller.
I agree about the converter, it needs more and I agree with having the engine dynoed to get the correct converter.
You may also want to spin it a little higher to get the power and run more gear.
Anthony
68c10owner is offline   Reply With Quote
Old 02-17-2016, 07:11 PM   #11
Ont67shortbox
the .652 lift is a roller.i was planning on shifting around 6800,and it has a 4.86 gear,you think I should go higher on both,the 4.86 was a compromise between some events at an 1/8th mile track and some 1/4
Old 02-17-2016, 07:23 PM   #12
68c10owner
68c10owner's Avatar
I guess it depends on what you are trying to do. 6800rpms from a 427 with those heads isn't a lot. It's going to take some rpm to run fast in a heavy truck. The extra gear will help get it moving. It's all about the combo. I don't know what those heads flow but I'll bet you could use a little more exhaust duration.
Anthony
Old 07-03-2016, 04:46 AM   #13
moggey01
Do they have a duration spec? You can cheat the lower lift with some duration. .937 lifter will help and higher ratio rockers .
moggey01 is offline   Reply With Quote
