02-11-2016, 05:41 PM | #1 |
thoughts on this pic of #1 piston
Decided to take head off and replace some gaskets
I did wire wheel it first Thoughts?? |
02-11-2016, 07:05 PM | #2 |
Re: thoughts on this pic of #1 piston
burnt piston NOT GOOD
02-11-2016, 08:17 PM | #3 |
Paperweight
02-12-2016, 09:08 AM | #4 |
What does number 6 look like
02-12-2016, 01:59 PM | #5 |
Not good.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
02-12-2016, 02:41 PM | #6 |
All others look good
Replaced some gaskets including head gasket.. All u can do for now is seal it up, button it up and drive it till new engine |
02-12-2016, 11:16 PM | #7 |
Looks like detonation damage.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
02-13-2016, 03:09 AM | #8 |
Yea that isn't going to work at all. The top ring is blown out and compassion is going to just go no where but in the pan. If that thing doesn't smoke or use oil I will be shocked.
02-13-2016, 03:12 AM | #9 |
02-13-2016, 04:03 PM | #10 |
I haven't messed with gm inlines for awhile. can he push the piston /rod ass. up and replace the piston?
02-13-2016, 05:54 PM | #11 |
He could, but I do wonder how bad the cylinder wall is damaged.
02-13-2016, 06:12 PM | #12 |
Inside cylinder looks fine
Can't be without it long enough to replace the piston.. I am looking for 1 for a replacement But can't imagine changing it unless I plan on re ringing it tho |
02-13-2016, 07:18 PM | #13 |
And a re-ring means honing the cylinder as well so the new rings will seat properly.
02-13-2016, 08:42 PM | #14 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
I was thinking "PING Damage" as well...Fix that and that thing might surprise you how long it will last, especially with the timing retarded a bit...? Timing and/or bad gas and high compression...?
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
02-13-2016, 10:56 PM | #15 |
I may have got lucky but I had a 67 with a six in it and I replaced one piston only with new rings on the one piston and the truck ran fine for two years and was still running when I sold it. The old sixes are pretty forgiving and are not a high rpm race engine.
69 Chevy 4x4 383 Power |
02-14-2016, 03:03 PM | #16 |
Timing set at 4*
Some have suggested to up that..to what tho?? If I can get its smoking to a minimum then it can wait till another engine But graces is that it's at the front so I guess I can lift it up enough to get that one out and replace it maybe Anyone got a couple good used to get rid of?? Pay it forward possibly?? |
02-14-2016, 04:02 PM | #17 |
Compression test
#6-145 #5-150 #4-160 #3-140 #2-140 #1-30..oil in-60 So now need piston and it will be straight till new engine!! |
02-14-2016, 04:24 PM | #18 |
What would I have to take off to simply tilt the motor up enough to get pan off and get to rod bolts?
Probably change some gaskets n 2 piece seal while I'm at it |
