Old 02-13-2016, 08:08 PM   #1
jason999
Adjustable Proportioning Valve Help
Hello,
My 66 C10 has a front end, and rear axel from a 1981 Long bed Chevrolet. The brake system came from the donor truck, but the booster was replaced and I'm not sure it was the same as stock. It has the original combination valve.
So, I have disc front brakes and drum rear.
I rebuilt the rear brakes and replaced the drums.
The problem is that my back brakes lock up before the front, when I brake hard. I am thinking that my old truck is lighter in the rear than the donor truck.
I have decided to add an adjustable proportioning valve to lower the line pressure to the rear.
Can anyone recommend a specific proportioning valve for my application? Any help would be appreciated.
Thanks,
Jason
jason999 is offline   Reply With Quote
Old 02-14-2016, 08:47 PM   #2
PGSigns
PGSigns's Avatar
Re: Adjustable Proportioning Valve Help
We have used these for years on drag cars to set the brake balance. A short piece of line and a couple of fittings after the stock valve would allow you to adjust just the rear. http://www.summitracing.com/parts/wi...8419/overview/ They also make a valve that would replace your stock one and let you tune the front rear split.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
