Old 02-13-2016, 11:11 PM   #1
jimmq
jimmq's Avatar
K20 power steering swap
I need to get the old manual steering off my 1972 K20 and convert to power. I have been striking out to find a 71-72 setup. Can I use a setup (pump, brackets,pulleys,box) off a 73-88 K20 p/u or suburban? Will a box for a K10 work?
jimmq is offline   Reply With Quote
Old 02-13-2016, 11:25 PM   #2
70cst
70cst's Avatar
Re: K20 power steering swap
ttt
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 02-14-2016, 12:17 PM   #3
Livrat
Member #1049
Livrat's Avatar
The steering box itself from 71-87 4X4 (1/2 ton or 3/4 ton) will bolt on to your frame, the thing to keep in mind is in 1980 GM switched the hose fittings in the steering box from an "inverted flare" to an "O-ring".
As far as all of the rest fitting (pulleys, brackets etc) will depend on what setup your truck currently has, if you have the factory "short" water pump setup (alternator on drivers side) you will need to find the power steering pump, hoses, pulleys and brackets off of 68-72 trucks, these parts do not matter if off of a 2WD or 4X4.
If your truck has the "long" water pump setup (alternator up top towards the passenger side) then you can use everything off of the 73- early 80's. (GM switched to serpentine some time in the early to mid 80's).
Livrat is offline   Reply With Quote
Old 02-14-2016, 02:21 PM   #4
jimmq
jimmq's Avatar
Thank you, that shed a lot of light on things. I just put a new water pump on so I guess I need to at least find pulleys and brackets for a 68-72 power steering pump.
Old 02-17-2016, 07:40 PM   #5
mike16
didnt the Hydraulc fittings go metric at some point too?
mike16 is offline   Reply With Quote
Old 02-17-2016, 08:28 PM   #6
swamp rat
swamp rat's Avatar
This thread and the links within will address adapter fittings.
http://67-72chevytrucks.com/vboard/s...g+hose+adapter
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
