Old 02-15-2016, 07:44 AM   #101
NC_John
NC_John's Avatar
Re: FITECH EFI 600 Basic and Command center intall with pics, factory tank
Originally Posted by steveo3318 View Post
The supplied line is more than adequate for the high pressure side. I literally put 220 lbs jumping trying to pull them apart. But to each his on. I love my system. The only problem I have seen is my low pressure gauge was leaking fuel inside of it and then leaking fuel out on top of the command center. We are only talking a drop an hr. I had an oil filled gauge I replaced it with which stopped the needle bounce anyway.
Well, since I had to put the command center over on the driver side, I only had enough of the hose they supplied to run the supply side. I guess I could've used that hose on the pressure side and got some cheaper hose for the supply but I plumbed the supply first. The hardest part about this install is dealing with my OCD and mounting everything in a way/place I am happy with. I'm still trying to figure out a way to run the fuel lines under the front of the truck that I like. This would have been so much cleaner if there was room around the battery somewhere.
I usually end up getting aeroquip lines made for stuff like this so just did my best estimate of lengths and ordered some pre made.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 02-15-2016, 07:46 AM   #102
NC_John
NC_John's Avatar
Originally Posted by diceman50 View Post
Here you go Ben. I used dish soap on this one. Can't say it worked any better than the others, but it did work at least as well. Research continues.
https://www.youtube.com/watch?v=xkUt...m-upload_owner
I used a heat gun and silicone spray. Wasn't easy but worked.
1970 C-10 LWB "Blu"
Old 02-15-2016, 08:12 AM   #103
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I used regular fuel hose to the FCC - low pressure.
The kit included line is for the high pressure side.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 02-15-2016, 08:16 AM   #104
steveo3318
steveo3318's Avatar
Yep. I bought 6 foot of regular low pressure to the command center. So is your up and running? How do you like it?
1967 c10 3OTT with R10 overdrive.
385 Stroker, 373 posi
FITECH EFI, Vintage air, York 210 OBA,
4/6 drop with riddler 20x8 and 20x10
1957 S5T Leslie Supertyfon train horns and EMD bell
"No bolt left unturned"
steveo3318 is offline   Reply With Quote
Old 02-15-2016, 11:07 AM   #105
NC_John
NC_John's Avatar
I plugged the return port with that little plug.
Even though that plug looks a lot smaller, the threads were the same size.
I also only got one filter
I checked the ports on the way out the door this morning and you are correct- the small plug fits in the one port on the rear (passenger side rear corner). I didn't realize that was the designated fuel return until I was reading through the documentation again. I had my carburetor fuel line going to that corner so had already decided in my head that that was going to remain the fuel inlet.
I am going to route my fuel line the same way as the original so I guess I will use the passenger side front port as my inlet. I don't want to run any fuel lines over any of the exhaust.
1970 C-10 LWB "Blu"
Old 02-15-2016, 11:09 AM   #106
NC_John
NC_John's Avatar
I could switch it but will go the aeroquip style lines sooner or later anyway so I'll leave it as it is for now. I'm going to end up going the same style lines on the low pressure side later as well.
thanks guys.
1970 C-10 LWB "Blu"
Old 02-15-2016, 11:47 AM   #107
steveo3318
steveo3318's Avatar
Glad you got her figured out
Old 02-15-2016, 12:44 PM   #108
NC_John
NC_John's Avatar
Thanks Steve. I plan on getting back on it this weekend and hopefully finishing it off.
BTW- those train horns and bell are freaking awesome. I would have way too much fun with that.
1970 C-10 LWB "Blu"
Old 02-15-2016, 06:04 PM   #109
LostMy65
LostMy65's Avatar
http://Www.67-72chevytrucks.com/vboa...20#post7487220
Old 02-15-2016, 06:08 PM   #110
steveo3318
steveo3318's Avatar
Awesome. You will love it. And yes the train horns are a blast lol
Old 02-15-2016, 10:10 PM   #111
LostMy65
LostMy65's Avatar
One thing I noticed that maybe okay, or maybe I have something wired wrong - but I don't think so.
But even with the key off, as soon as I plugged in the Handheld Controller it lit up. Should the Handheld Controller turn off when I turn off the key?
Old 02-15-2016, 10:32 PM   #112
steveo3318
steveo3318's Avatar
No the handheld goes to sleep it's perfectly ok. It goes to sleep 90 seconds after the key is turned off and you have to push the button to light it up even after starting. I like this in case I would rather not have it on. It won't drain the battery. I also had this concern and tech support told me this.
Old 02-15-2016, 10:33 PM   #113
LostMy65
LostMy65's Avatar
Cool, Thanks.
Old 02-20-2016, 11:05 PM   #114
NC_John
NC_John's Avatar
Got enough of the install finished that I could fire her up tonight.
http://vid780.photobucket.com/albums...pslakfjjc1.mp4
Definitely have tweaking to do- it is really rich. So much so that I hope it doesn't take out the O2 sensor before I get it straightened out. I'm going to set my idle and go through the parameters again. I might have the cam setting wrong and it's giving the unit a real time trying to manage things.
It's great to have her running again. The throttle response seems really quick so I can't wait to take it for a drive tomorrow.
1970 C-10 LWB "Blu"
Old 02-20-2016, 11:31 PM   #115
LostMy65
LostMy65's Avatar
I might be mistaken, but I don't think the Target AFR should be bouncing around like that.
I seem to remember mine staying at 13.6.
Old 02-21-2016, 08:27 AM   #116
NC_John
NC_John's Avatar
I did a bit more reading and I saw I have to mechanically set my idle, then let the ecu adjust to it. I'll see what that does. I also have to revisit my cam selection. I got it running a bit late after a long day and didn't even run it again after I shot that first start video. It ran so I called it a win and shut things down.
1970 C-10 LWB "Blu"
Old 02-21-2016, 12:07 PM   #117
LostMy65
LostMy65's Avatar
It might be a good idea to go through each section and click 'Send to ECU'.
Old 02-21-2016, 06:48 PM   #118
coopdog
coopdog's Avatar
.................._____
__________//___{\____
/__---____//____/__---/
.....(O). ..................(O).
BUILD THREAD K20 http://67-72chevytrucks.com/vboard/s...d.php?t=651601 pages 2-4
coopdog is offline   Reply With Quote
Old 02-21-2016, 09:29 PM   #119
NC_John
NC_John's Avatar
Went through all my settings again and saved them individually. Set my idle. The target AFR has calmed down and is stable. The idle speed seems to hunt around a fair bit.
Went for a test drive, and as is the general consensus, wow. I feel like I picked up 100 hp. I am throttle steering the truck in first and second. I actually scared myself a couple times. The only issue is it seems to be hesitant to come down from rpm when the load is removed (clutching or decelerating). I have to give the throttle a blip for it to come down. I'll have to make sure the linkage isn't binding.
I noticed I can get in and out of the garage without using the throttle if I am easy with the clutch. I used to have to play with the throttle like crazy with the carb to keep it from stalling.
More work to do and I still want to tighten things up but pretty pleased in the big jump in power and crazy throttle response.
1970 C-10 LWB "Blu"
Old 02-21-2016, 10:19 PM   #120
LostMy65
LostMy65's Avatar
Yeah, mine seem to be slow dropping rpms.
Mine was related to linkage.
I originally had the linkage in the middle hole. Then I saw a video where Ken (Fitech) recommended using the upper most hole. That did the trick for me.
Old 02-22-2016, 07:42 AM   #121
NC_John
NC_John's Avatar
Ok, cool. Thanks.
I was just reading in car craft how the new hot rods are set up intentionally to drop rpm slow for emissions and was hoping that wasn't the case with this- slowing down decal to help keep the O2 sensor clean or something crazy like that.
1970 C-10 LWB "Blu"
Old 02-22-2016, 09:03 AM   #122
steveo3318
steveo3318's Avatar
There is a parameter that must be adjusted if you want it to come off idle faster. Actually two. Mine is a standard and was really really slow to come off idle. After I changed them it acts like a carb now. Comes off throttle with the pedal not being slowly let down. It's not linkage trust me. I will find the parameters this afternoon and explain if y'all want
Old 02-22-2016, 09:10 AM   #123
NC_John
NC_John's Avatar
Yes please! That would really help out.
1970 C-10 LWB "Blu"
Old 02-22-2016, 10:28 AM   #124
LostMy65
LostMy65's Avatar
Originally Posted by nc_john View Post
yes please! That would really help out.
x2
Old 02-22-2016, 10:57 AM   #125
NC_John
NC_John's Avatar
Originally Posted by coopdog View Post
looks good- here is mine. I tightened up some more of the wiring after the pic. I want to stretch out and rerun the water temp sensor down to the frame and around the long way to hide it. One of the most difficult parts of the install was making it all look nice. You can see the high pressure AN-06 line I used for my command center to EFI lines. I'm going to use the same on the fuel pump to cc later. I still have to run my (not a return line!) vent line back to the tank.
1970 C-10 LWB "Blu"
