Old 02-15-2016, 06:40 PM   #1
1972k5blazer
Swap from ac to none ac ?
Someone point me to a good answer I ve read a bunch of threads but get a little confused . My truck is a 71 all the ac stuff is there but I think I'd like to swap it out for a none ac inside heater box and use the ac delete firewall box I ve seen on here . I seen where there is a difference in the fire wall holes between none ac and ac but will a none ac box bolt right up to the firewall behind my glovebox and the ac delete plate bolt to the outside firewall and not have to cut or weld on the firewall to mate it up ? Thanks
1972k5blazer is offline   Reply With Quote
Old 02-15-2016, 06:43 PM   #2
Bigdav160
Bigdav160's Avatar
Re: Swap from ac to none ac ?
An A/C truck as the heater core on the inside of the truck and the blower motor under the hood
A non-A/C has the heater core and blower motor under the hood.
Using a delete plate you'll lose A/C and heater functions without going to an aftermarket system.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-15-2016, 06:47 PM   #3
1972k5blazer
Okay I guess I was hoping this one I thought I read you could still use heater Name:  image.jpg
Old 02-15-2016, 07:01 PM   #4
1972k5blazer
I think I understand it now this delete cover is intended to use your inside ac box with it so your heater core stays inside the cab is that correct ? Thanks
Old 02-15-2016, 08:06 PM   #5
Bigdav160
Bigdav160's Avatar
That looks like it would do the trick
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 02-15-2016, 09:05 PM   #6
F.A.A.benny
Originally Posted by 1972k5blazer View Post
Okay I guess I was hoping this one I thought I read you could still use heater Attachment 1499585
Yea, that cover will allow you to keep your heater. You only need to remove the out ac box
F.A.A.benny is offline   Reply With Quote
Old 02-15-2016, 10:15 PM   #7
1972k5blazer
Okay thanks ! Thinking about doing away with all the ac stuff on the truck and going this route
