Old 09-27-2015, 09:15 PM   #1
Snocap
Left front turn signal and indicator Dead
I've been lurking for some time... but finally have a challenge.
Issue: the Left Front turn signal and the dash cluster indicator for the left signals don't light up. The left rear turn signal flashes okay, though slower than the right side (signifying no draw from the left front).
I've verified the left front light and housing are fine by using the left side to feed power to it at the connector through the radiator support flange. I've also verified the left side dash light filament is good and have replaced the dash signal light socket.
The left front signal works fine on emergency! Don't know if it is normal but when emergency blinker is on, the emergencies will stop when braking.
Any ideas of what else to check, verify? VOM at the ready. TIA
All in the Family
1970 CST20 with dump articulated bed
Snocap is offline   Reply With Quote
Old 09-27-2015, 09:23 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Left front turn signal and indicator Dead
Wish I could help with your problem, but..... at least I can answer this part. Yes, it is normal on these trucks.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 09-27-2015, 09:37 PM   #3
Snocap
^Mike^
All in the Family
Old 09-28-2015, 01:41 AM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Left front turn signal and indicator Dead
Yes the emergency lights will quit blinking if the brake pedal is applied.
Now for the turn signal.
With key on front bulb out take a test light and see if you can get it to light up by touching one of the connectors in the housing. It should blink just like the bulbs. If not take the connection loose at the core support and try it there. If you get power there it's between the connector and light housing.
If you don't get it there go to up under the dash at the column check the wire for turn signal there. Just keep back tracking until you find power.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 09-28-2015, 07:04 AM   #5
hamjet
hamjet's Avatar
Also, the case of the front turn signals have to ground to the grill. while the nonworking turn signal is on, take a screwdriver or something sharp and wedge it between the grill and turn signal case to make good ground and see if it lights. it happened to mine..
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 09-28-2015, 09:11 AM   #6
TNTsigns
TNTsigns's Avatar
If none of the above work. Check the turn signal switch under the steering wheel. The switch will not make proper contact due to dust or light corrosion. It is a pain to remove the steering wheel. I have had to do that on several of my trucks in the past.
TNTsigns is offline   Reply With Quote
Old 09-29-2015, 01:33 AM   #7
Snocap
Well still tracing the wire. No power at the engine side of firewall except when emergencies are active. Since emergencies are active I'm thinking that the issue is the switch itself as the same wire is used for both.
All in the Family
Old 10-13-2015, 07:10 PM   #8
Snocap
It's the switch, turn signal. So guess we will be pulling the SW. I may be able to bend the contact. We will see.
All in the Family
Old 10-13-2015, 11:04 PM   #9
Poky67C10
Just following this. I'm kinda in the same boat with my front turn signals
Poky67C10 is offline   Reply With Quote
Old 10-14-2015, 12:40 AM   #10
Snocap
After tracing the wires I found no power to the entire wire. So took her on a drive. And suddenly I had intermittent good connection signified by the turn signal indicator. So after I got back from my drive I lightly pressed the lever and was able to replicate the now working lights. Hope this helps someone else. I will likely not pull the steering wheel for a week or so. News at 11.
All in the Family
Old 02-17-2016, 12:29 AM   #11
74baggedbug
Any updates experiencing the same thing now
74baggedbug is offline   Reply With Quote
Old 02-17-2016, 01:45 AM   #12
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here is how to test your turn signal switch without pulling the steering wheel.
http://67-72chevytrucks.com/vboard/s...d.php?t=695511
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-17-2016, 01:48 AM   #13
74baggedbug
Started tracing down wires and found a bad connection under the dash.. Fixed now thanks
Old 02-17-2016, 10:53 AM   #14
snipescastle2
snipescastle2's Avatar
Talking Re: Left front turn signal and indicator Dead
Look at your steering column "half Moon" connector, those sometimes work loose and might be a culprit, also mice have a tendency to chew through wires, might have a broken connection.
Ben
snipescastle2 is offline   Reply With Quote
Old 02-17-2016, 11:33 AM   #15
Snocap
Sorry as have no update. Have had too much work on house Etc. Mine is definitely in the switch, just need to pull it. Glad you found your bad wire.
All in the Family
Old 02-17-2016, 11:35 AM   #16
custom10nut
custom10nut's Avatar
In addition to all the rest of the advice, check all your wires for breaks. I've had wires break, but the outer shell stays intact. Also, check any connection for corrosion. Here is SC, the humidity reeks havoc on wiring. My truck has been sitting for a while, so I'm having the same issues that you're having.
custom10nut is offline   Reply With Quote
turn signal indicator, turn signal issues, turn signals
