Old 02-17-2016, 01:43 PM   #26
solidaxel
solidaxel's Avatar
Re: Removing cab/bed
Had to wait 30 years for the Ruz Lancia to grow tall enough
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-17-2016, 04:10 PM   #27
paintman
I did mine by myself just set up some cribbing with 2x12's running across them. I just kept jacking up (slowly), on the timber to raise either the front or back of cab, then stacked patio pavers under the timber.
[/URL]
Once I got it up high enough I rolled the chassis out and then rolled the cab dolly in. Took about an hour.....
[/URL]
[/URL]
paintman is offline   Reply With Quote
Old 02-17-2016, 04:56 PM   #28
pvienneau
pvienneau's Avatar
hoist and straps - my garage was built with 9 foot ceiling so it works out good to get it off with the chain hoist. I also used a 1000 lb come along.
Pat
1949 unmolested Indy Farm Deluxe AD
1949 Standard 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=581544
pvienneau is offline   Reply With Quote
Old 02-17-2016, 05:33 PM   #29
dsraven
I have done the "Hanks Garage" method. works good if you have a second guy (or wife) who can put the shims in under the blocks while you lift. or use another member between the cross pieces to lift with a floor jack and shim yourself (easier on the back and probably safer) one side then the other side until high enough.
some time back I acquired an old hospital bed from a govt auction. cheap. I took an old metal door and screwed to the top where the bed used to be and then I had a mobile workbench with a flat top. it is adjustable hydraulically for height. I used that parked stationary under on side of the cab which I had set up like the "hanks garage" photo with 2x4's sideways under the cab. then lifted the table so it took that side of the cab off the frame rails. I had previously laid 2x4's lengthwise on the table as well, with some old broom sticks (or dowelling) under the 2x4's to act as rollers. then I went to the other side of the cab and lifted it by hand while pushing the cab onto the bed (which rolled easily across the table due to the dowels under the 2x4 rails). after a few trips to move the dowelling the cab was positioned on the table. the original "hanks garage" 2x4's came in handy when it was time to let the hand held part of the cab down because that is a spot for the cab to sit on while you go to move the dowels. of course it would be easy if you had a bunch of guys but I work alone 98% of the time so one learns to adapt. just an idea I thought someone else could use if in a pinch or trying to do something on the cheap without storing some monstrosity of a lift till "next time".
Old 02-18-2016, 11:50 AM   #30
_Ogre
_Ogre's Avatar
so plant your tree now folks
as long as it took for me to get truk done, i could have planted a few to make a gantry hoist
shop air compressor timer
