Old 02-19-2016, 09:39 AM   #176
oldman3
oldman3's Avatar
Re: Project U S Army Sargent Slam
Looks super...Jim
oldman3 is offline   Reply With Quote
Old 02-20-2016, 01:07 AM   #177
fredscarryall
fredscarryall's Avatar
Capped my front frame rails today. Had to cut them a little further back then I really wanted to. The previous owner didn't cut the frame rail very straight to begin with, but it won't hurt anything. First pic is before
fredscarryall is offline   Reply With Quote
Old 02-20-2016, 01:08 AM   #178
fredscarryall
After. Just have to do the radiator support bracket.i think I am going to use a L bracket on each side.then weld the bottom to the frame and bolt the top to the radiator support.
Old 02-24-2016, 11:34 PM   #179
fredscarryall
Bought premade brackets at the hardware today fot the radiator support. Just had to cut them down a bit.
Old 02-24-2016, 11:36 PM   #180
fredscarryall
Marked the inner fenders so I could use the plasma.
Old 02-24-2016, 11:37 PM   #181
fredscarryall
After the cut
Old 02-24-2016, 11:39 PM   #182
fredscarryall
Drilled holes for bolts in radiator support and mounted it back up
Old 02-24-2016, 11:50 PM   #183
fredscarryall
Welded and painted the brackets to the frame and bolted the upper bracket to the radiator support. The welds are solid I will clean them up when I strip the frame to powder coat it.To me it turns out a lot cleaner this way and you don't have any cross braces getting in you way. The brackets are also ovaled out so they have some adjustability.
Old 02-26-2016, 03:52 PM   #184
HUSSEY
HUSSEY's Avatar
Looking great, looking forward to a video of that beast rolling on the street!
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 03-05-2016, 01:20 AM   #185
fredscarryall
Got a 47-48 fuel inlet tube, grommet and gas cap today.
Old 03-05-2016, 01:21 AM   #186
fredscarryall
Used the plasma to cut a 2 3/4 home for the filler grommet.
Old 03-05-2016, 01:22 AM   #187
fredscarryall
Grommet fit perfectly
Old 03-05-2016, 01:23 AM   #188
fredscarryall
Filler neck installed
Old 03-05-2016, 01:26 AM   #189
fredscarryall
Top view. Just need to get a longer filler hose
Old 03-07-2016, 03:18 AM   #190
deejaaa1
that is looking so good!
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years.
96 ECLB 2500, 6.5 diesel, auto, gone.
Originally Posted by gottattooz View Post
...68 Chevy Shortbed... guy clearcoated..and...threw glitter all over it...like he was feeding chickens!!!...
deejaaa1 is offline   Reply With Quote
Old 03-17-2016, 11:02 PM   #191
fredscarryall
Took about 5 hours to get all the belts and brackets to line up. I had to be the one to run power steering and a/c on a blown motor. Still don't like the angle of the power steering fill neck.so I need to get a shorter belt. Next is plumbing the radiator hoses, fuel pump and fuel line. Then I will fire it up again and set the timing.
Old 03-17-2016, 11:21 PM   #192
mud.man.rj
mud.man.rj's Avatar
Wild thang..
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 03-23-2016, 01:37 AM   #193
fredscarryall
Mounted the upper radiator hose. The space was so limited near the water neck because of the blower I had to use a flexible stainless radiator hose.
Old 03-23-2016, 01:42 AM   #194
fredscarryall
Couldn't use the billet radiator clamps on the Lower radiator hose because of the limited belt room. Hope they hold, I have never used radiator hoses like these before.
Old 03-23-2016, 01:44 AM   #195
fredscarryall
Overflow tank
Old 03-23-2016, 10:01 AM   #196
Sim6
Sim6's Avatar
Man, looking good!
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies
53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793
http://67-72chevytrucks.com/vboard/s...d.php?t=771679
Sim6 is offline   Reply With Quote
Old 03-25-2016, 12:25 AM   #197
fredscarryall
Got the fuel line and the pre and post filters installed
Old 03-25-2016, 12:28 AM   #198
fredscarryall
To the tank. Had to plug off 2 of the 4 lines going into the tank. Only needed the vent and the pick up tube.
Old 03-25-2016, 12:38 AM   #199
fredscarryall
Going to run the battery in the bed. Just need to install the battery shut off on the side of the bed. Need to pass tech because I am planning on doing a little racing at the local drag track
Old 03-25-2016, 06:12 AM   #200
dug224
dug224's Avatar
Great build. Love the wheels and speed in which you are building!! dug
dug224 is offline   Reply With Quote
