02-18-2016, 12:53 PM | #276 |
Re: A 15 year old's project. Rusty 62 stepside
the cab supports are $17 each from LMC .
you can go to there online catalog and see a picture of them on there . here are some pictures of the bottom of the cab , on one of the 65 C-10 's that im building now . this is my friend J.B.'s truck cab . it is the better one of the two . |
02-18-2016, 01:32 PM | #277 |
Tailgate looks good Nik. You're right the only way to learn is to do it yourself. And if it's not right do it again. We have to redo stuff plenty out in the shop.
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
02-18-2016, 05:48 PM | #278 |
Thanks for the pics Jim
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
02-18-2016, 06:02 PM | #279 |
Re: A 16 year old's project. Rusty 62 stepside
Thanks for the compliments dale
02-18-2016, 09:03 PM | #280 |
Having some troubles with my carb. Any advise?
Video: http://youtu.be/K9Ab9QcJN4w
02-19-2016, 06:20 AM | #281 |
At a minimum, rebuild the carb. It is probably gummed up inside, valves sticking some, and those leakey gaskets..... I am not an expert with them, but those old 1bbl carbs are pretty easy to rebuild. Check around were the throttle rod(?) runs into the caarb and make sure the hole is not to wallowed out as then you may need another carb.
02-19-2016, 04:20 PM | #282 | |
Glad to see you're taking the time to do it right, even if it means backtracking on previous progress. That's what the really good builders do. I think you'll feel a lot better about the end product.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
02-19-2016, 04:44 PM | #283 |
Thanks, yes I'm very glad that I redid it and took the time to plan it out the second time.
02-19-2016, 04:55 PM | #284 |
Just took the welds down. I'm glad that I took the time to make the panel even and flush. The seem is super smooth and I can't even feel the seam when I run my finger across it.
02-19-2016, 04:57 PM | #285 |
02
02-19-2016, 04:59 PM | #286 |
03
02-19-2016, 08:36 PM | #287 |
the tail gate looks much better this time !!
02-19-2016, 09:58 PM | #288 |
Looking good dude
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
02-19-2016, 11:13 PM | #289 |
Thanks Jim, yes I agree it looks much better
Thanks rusty
02-20-2016, 12:52 AM | #290 |
Just finished the fan base. Lots of filing and sanding resulted in the the areas replaced with fibreglass looking like they were meant to be. Then threw some paint on. I'll put it all back together tomorrow and put in the new switch.
Oh yeah I also ordered new rear cab supports and they should be here tomorrow or Sunday.
02-20-2016, 04:08 AM | #291 |
Got the fan all assembled and the new switch wired up
02-20-2016, 11:43 AM | #292 |
Nice job bud!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
02-20-2016, 06:35 PM | #293 |
02-20-2016, 06:40 PM | #294 |
Got busy this morning and patched the rust in the lower front cab pillar.
02-20-2016, 06:43 PM | #295 |
Then I started to work on the rocker panel. I got this one for free from someone that messed it up. For some reason they cut out the front section of it
02-20-2016, 06:46 PM | #296 |
After some welding and grinding I got it right
02-20-2016, 06:48 PM | #297 |
Rocker all fitted and welded in
02-20-2016, 06:50 PM | #298 |
02
02-20-2016, 11:11 PM | #299 |
And here's a video of the dash fan to finish off the day
http://youtu.be/9_VBrqC5SzU
02-21-2016, 02:24 AM | #300 |
That dash fan is sweet! Nice patch repairing.
