1970 GMC probably a '72 engine, 350, Q jet, auto tranny. Just replaced the mechanical fuel pump. It still dies at 13 to 15 minutes, and it will have to cool down for at least an hour, then do it again. Any help would be appreciated.
![]() Join Date: Jan 2002
Re: engine dies in 15 minutes
What does it have to cool down for an hour? Will it not restart or?
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
It will turn over, but not fire. I've checked the gas cap, no vacuum in the tank. Just replaced the fuel pump, I can pull on the throttle and squirt fuel in the carb.
Do you have an HEI distributor? Almost sounds like the control module or something is bad and when it gets heated up, it's causing the truck to die. Another thought I had was the motor is running too rich and maybe flooding itself out? Are your spark plugs wet?
![]() Join Date: Dec 2015
Sounds like it could be a plugged fuel filter to me
Just had the same thing on my 67 GMC. It had the points distributor on it. After it ran for a while, 10-15 min it would die, then not start again, Wait an hour and it would fire up and again after 10-15 min it would do the same thing again. I went through EVERYTHING and finally put a new HEI distributor in it and it runs perfect now, no issues in 2 months.
The HEI modules can get flaky when hot - if you have a spare distributor, that'd be my guess. My first guess was tank venting, but you said no vacuum, so HEI it is!
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
Thanks for the ideas, I'll get back to it next weekend.
Had a 1990 Suburban do the same thing. Just needed new cap/rotor, plugs, and wires. Ran perfect after that. Check that distributor too.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
Something else, there is a short rubber hose below the tank, if its getting old and rotted it can collapse and restrict fuel flow, that includes any rubber line between the tank and pump, make sure its actual fuel line that is reinforced and not non reinforced rubber hose...
Check the filter like previously mentioned, try and back flow it with some air and see if there are any fine white chards of material in it, if there is that is the pickup sock deteriorating, time to replace the pickup screen.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
+1 on ignition related components failing after heating up. Not too long ago, I purchased 64 Corvair and installed all new ignition parts. A mile or so down the road and it stop dead in its tracks. I decided to replace the points, condenser and ignition coil again...all was well the second time around. So, BOOB (Bad Out Of Box) parts are not uncommon.
If it is the old points and condenser distributor, sounds like the coil is breaking down. To test it, remove it, then shake it, If it makes a sloshing noise replace it.
Could be the same for HEI.
2005 GMC K2500HD D/A 1993 GMC K1500 2011 Subaru Legacy. 2013 Subaru Outback 1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot. ![]() |
Thanks for the ideas, I'll check them out.
![]() Join Date: Feb 2010
Check that the fuel tank is venting. If you remove the gas cap and the problem goes away, then that's what it is.
71 Blazer 4X4 (unmolested, all original (including paint) 74,000 mile barn find) 67 Camaro RS SS (unmolested, all original (including paint) 81,000 mile barn find) Keith Riel |
#15 |
I would bet its the coil.
#16 |
Also, if you replaced the hei module recently and didn't use the dielectric grease,the module will fry to a crisp.... just sayin'
Ben ![]() |
#17 |
He said no vacuum in the tank in his initial description.
#18 |
fuel filter
#19 |
![]() ![]() Join Date: Feb 2009
Tank vent > fuel filter > distributor.................More likely distributor than fuel filter, but a filter is cheap and easy. If all that fails, I'd replace all fuel lines, including the vent line. If that fails, couldn't tell ya.
Don't know if that could be a fuel pump. Seems it would work or it doesn't.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#20 |
Just something to check, but is there any fuel coming out the "Weep Hole" by chance? might want to make sure you have no fuel getting into your oil pan also....
Ben ![]() |
#21 |
Hello to anyone reading this, I put a new coil in today and doubled my run time. Now it will run for about 30 minutes. I bought a remote starter, but haven't figured how to hook it up, the directions are for a more modern vehicle. Can a part store test my module for me?
#22 | |
![]() Join Date: May 2014
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
#23 |
![]() Join Date: Dec 2013
I still say it's a fuel issue , The dist ,coil,capacitor ,and anything else wouldn't continue to start multiple times and just run for 13-15 minutes ,It would have completely failed already .
Dirty fuel pick up in tank Fuel line between tank and hardline under cab collapsing / cracked Inline fuel filter Bronze fuel filter in carb it starts ,runs until crud in fuel line restricts flow .Won't restart ,wait an hour fuel flows back clearing line and restarts .Dies if 13-15 minutes . Why no pictures ? a good look at the condition of the rest of the engine/fuel lines and ignition could let someone give a further diagnosis .have you tried starting it once it dies using carb cleaner to see if it will fire even for a few seconds ? ![]() |
#24 |
I just red back thru your threads ,You've been dealing with this issue since 6/2012 ? Take it to your local mechanic .
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=528601 http://67-72chevytrucks.com/vboard/s...d.php?t=529028 http://67-72chevytrucks.com/vboard/s...d.php?t=534240 Last edited by Grumpy old man; 02-21-2016 at 11:54 AM. |
#25 |
"I bought a remote starter, but haven't figured how to hook it up, the directions are for a more modern vehicle".
If you bought the Actron Remote Starter I believe it is in the instructions (Figure 5) - (see attached pdf) Re using the remote starter I found it more convenient to just install a permanent 12 gauge wire from that "S" lug on the solenoid up to an insulated lug (really just a 1/4"-20 x 1" bolt through a chunk of plastic) mounted on the inside passenger side fender well next to the factory distribution block - then you can hook up the remote starter wires - one to that bolt and the other to your positive on the battery - without having to thread the leads through the headers and into the cramped space around the solenoid where it is easy to short against the positive cable. Always turn your key to the run position before activating a remote starter (as advised in most repair manuals).. |
