02-21-2016, 01:59 PM | #1 |
A different antenna question
On cars, like Camaros, if you got an FM radio the car would ship with a fixed-length antenna. Due to the way FM works, apparently the frequency modulation works best that way.
So if you see your millionth Camaro with an FM radio check the antenna, now you know if it was originally equipped with one. Problem is I've seen FM radios in our trucks but I've never seen a fixed-mast antenna on a truck. Did they not use it? Or is it just a detail that most people who add FM don't correct so that I've never seen it done right (including me)? Put more simply, did the factory use a fixed-mast antenna if you ordered the FM radio?
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
02-21-2016, 02:07 PM | #2 |
Re: A different antenna question
Here's a link to a recent thread where we discussed this. The key is the 31" mast length which is optimal for FM reception.
http://67-72chevytrucks.com/vboard/s...d.php?t=694682 Jim |
02-21-2016, 02:15 PM | #3 |
I saw that, but I came away from that thread knowing a fixed mast antenna is best for FM but still unsure if the factory ever shipped trucks with them.
It talks about using a car repro one, but people disagree on whether or not they ever shipped them on FM trucks 67-72, at least as I read it. So I still don't know if the factory ever did it... I do, however, see one person said this, but there's no corroboration or explanation. If true, it answers the question: "71's with AM FM radios did have fixed masks, AM had telescoping."
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible Last edited by davepl; 02-21-2016 at 02:35 PM. |
02-21-2016, 02:45 PM | #4 |
when I originally bought my 70 c10 it had the original AM radio and a fixed antenna. When I switched over to an FM radio I used all the stock antenna equipment and just plugged directly into the new radio.
02-21-2016, 04:01 PM | #5 |
Sorry for hijack, but for correctness, AM equipped trucks should have expandable antennas?
The lid is stuck on my jar of anti seize |
02-21-2016, 05:30 PM | #6 | |
Poll is a great way to get these kind of answers: http://67-72chevytrucks.com/vboard/s...d.php?t=695051
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 02-21-2016 at 05:55 PM. |
02-21-2016, 06:07 PM | #7 |
My 70 had a fixed length antenna with a AM radio from the factory
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
02-22-2016, 09:40 AM | #8 |
Pretty much all my trucks have come with fixed mast antenna, whether AM or AM/FM. I have mostly had 70-72s and those are what I am remembering most. That was the standard antenna and the spring one was an accessory. Most of those you see were added on after the original broke or bent. I put spring mounted antennae on anything I had that needed one for the unbreakable feature. They were very popular. In fact, there were replacement masts made to slip over the stub of a broken antenna so you didn't have to mess with mounting/cable/etc.
For trucks with campers, GM offered a fender mount. My all original '71 Custom Camper came with AM radio/31" solid mast and it rubbed on the front of the camper overhang. In fact, it sat flexed forward. If they came with telescoping mast you could just lower it, no need for special antenna drilled into fender
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 02-22-2016 at 09:47 AM. |
