12-15-2014, 10:44 PM | #26 |
Re: Project Simple Green - Lucille - 1967 C10 Porterbuilt/AccuAir
Sub'd.
-j-rod '06 3500 LWB CC 4wd, 8.1 Allison |
12-16-2014, 11:08 AM | #27 | |
Kelley 1967 C10 LWB Fleetside - Original 283, Muncie 3-Speed on Column -Porterbuilt Stage 1 Front / Stage 2 Rear Accuair E-Level iLevel - GM Transit 22s w/ '52 caps Project Simple Green the build of Lucille - http://67-72chevytrucks.com/vboard/s...d.php?t=650871 |
12-16-2014, 11:30 AM | #28 |
List of parts either refurbed, replaced, serviced while at Shop #1 (my buddy's place with the old scissor lift):
Motor rebuilt (.060 over, Comp Cams Thumper Cam, Edelbrock Intake, Holley 4-Barrel, Headman Headers) Rear Diff Serviced (open, 3.73 and staying that way) Shifter Linkage/Bushings Refurbed New Clutch and all associated parts New U-Joints New Driveshaft Bearing Front Manual Drum to Power Disc Conversion Installed Rear Drums Rebuilt Front upper and lower Control Arms Refurbed Heater Core Replaced New Radiator New Alternator (100 amp if i remember correctly) 2.5" Lowering Spindles 22 GM Transit Wheels and 265/30r22 tires The Ol' 3-Speed, 283 (well now a 292) ass shot! Vitals: Here it is when I got it back to my folk's place. Came home about 15 miles with headers dumped through about 2 feet of pipe! Where the rest of the work is going to happen:
12-16-2014, 12:01 PM | #29 |
Appears to have been a workhorse back in the day. Won't be needing the spare or overload spring anymore.
Time to get to the rear suspension! Porterbuilt Stage 2 Basic (bolt-in notch, adjustable panhard bar, bags, cups, rear crossmember). Too sweet of a view, always good to step back and soak up a little sense of accomplishment (yeah taking the bed off is a milestone!). Removing Old Rivets with an Air Chisel (best method by far IMO). Thanks to Porterbuilt for designing things such that they re-use old rivet holes!
Kelley 1967 C10 LWB Fleetside - Original 283, Muncie 3-Speed on Column -Porterbuilt Stage 1 Front / Stage 2 Rear Accuair E-Level iLevel - GM Transit 22s w/ '52 caps Project Simple Green the build of Lucille - http://67-72chevytrucks.com/vboard/s...d.php?t=650871 Last edited by sixSEVENcTEN; 12-16-2014 at 12:14 PM. Reason: added one more underbody pic |
12-16-2014, 12:17 PM | #30 |
01-11-2015, 12:54 AM | #31 |
Show us some more..!!
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" |
01-11-2015, 02:37 PM | #32 |
I'll watch as well
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
01-11-2015, 07:59 PM | #33 |
hurry, I'm having withdrawals...
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
01-19-2015, 04:50 PM | #34 |
Notch and Crossmember Installed (minus lower shock mount and Panhard Bar):
Rear Bag Installation: Due to the fittings that came with my PBFab/AccuAir package I had to modify the cups slightly. BEFORE Porterbuilt Tank/Compressor Mount: AFTER Porterbuilt Tank/Compressor Mount: (Temp Rear Air Plumbing sticking through in this shot. Hard to find a quick-connect schrader valve set-up. GET A COUPLE FROM AMAZON.com in advance and save yourself from some local begging which is what my Friday afternoon consisted of) Rear Done (Minus Lower Shock Bar): Stage 2 Getting DOWWWWN! No bump stops, cheating a little!! I dont mind showing off my Year of Manufacturer Plate. SCDMV was awesome to deal with. I literally had the lady at the DMV on the phone while I was browsing eBay deciding which vintage plates I could use. I'd say "what about this?" and she'd yay or nay it. Pretty cool process.
01-19-2015, 05:26 PM | #35 |
Front Bag Installation:
Just remove the u-bolts holding the inner shaft of the lower control arm, made it really easy. Go ahead and remove the lower bump stops, they will contact the bag! Got them off pretty easily with the air chisel after drilling the spot welds. Shock mounted: Front Aired Out: Ready to go get the exhaust on!
01-19-2015, 07:06 PM | #36 |
Love it! I'm interested to see the headers you used that I think you said fit horribly?
01-20-2015, 11:56 AM | #37 |
IN! love the mint green patina!
01-20-2015, 12:05 PM | #38 |
He really does..I've seen him do it!
* Call me NOT the website number* Justin Novick (773) 303-8251 Sales/Support Entropy Radiator / Engineered Cooling Products "The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com |
01-23-2015, 12:58 PM | #39 | |
01-23-2015, 01:00 PM | #40 | |
02-21-2016, 03:40 PM | #41 |
. Sharp looking truck - any updates? . . |
02-21-2016, 08:18 PM | #42 |
Watching....got family in Statesville and Mooresville.
Tags |
accuair, c10, patina, porterbuilt |
