Old 02-22-2016, 06:56 PM   #351
chewychevy67
Re: 67 GMC super custom build
The passenger side is complete except the wiring and switch. I finished the mechanism for the driver side as well. Here is the pass seat and the console mounted. the pass seat is a little bit higher now than the console cause of the 1" I raised it for the power tracks but should be ok. I cant raise the console because the Velcro strap wouldn't line up to keep it open but probably wouldn't anyway.
chewychevy67 is offline   Reply With Quote
Old 02-22-2016, 08:48 PM   #352
chewychevy67
I think I'm going to lower the seat frame so that the seats sit level. The more I look at it the more I don't like them offset.
Old 02-23-2016, 01:41 AM   #353
71Sleeper
71Sleeper's Avatar
I agree the seats need to be level. Just another example of how you look at every detail of your build. Always tuning in just to see what you have come up with new. Great work!
71Sleeper is offline   Reply With Quote
Old 02-23-2016, 09:32 PM   #354
chewychevy67
Taking 1 1/4" out of the seat frame.
Old 02-23-2016, 10:07 PM   #355
chewychevy67
Moched up. Now you wont see the seat from the back window. I am glad I did this.
Old 02-25-2016, 02:37 PM   #356
chewychevy67
All tacked together
Old 02-25-2016, 04:36 PM   #357
chewychevy67
I may try to use my mosified cst horn button from my other wheel on my telescopic wheel. This may not be possible but it would look nice.
Old 03-01-2016, 03:41 PM   #358
chewychevy67
Here is a picture of the power seat switches i'll be using. it is hard to find a 2 way power seat switch. wow everything out there is a 6 way. from gm they had to come from a limo.Also I am toying with the idea of adding heated seats. I would be putting a new modern set up in the truck. 1966 Cadillac had heated seats optional and here is what the switch looks like. I am trying to have one made by someone with a cnc machine. If he can make it I will probably do it and mount the switch on the bottom of the dash beside the a/c vent. may just do driver seat but unsure.
Old 03-04-2016, 05:53 PM   #359
chewychevy67
James did an awesome job finishing up the seat frame. He lifted the back under the console so the stock jack can still be removed when needed. The seats sit nice now and the full use of the tilt telescopic wheel can be used!
Old 03-08-2016, 12:40 PM   #360
chewychevy67
This switch bezel is exactly the same as the seat heat switch. Here is where they will mount. Just it will be flush with the bottom of the dash so all you would see is the words. I think if the modern harness will work with these switches I will do this mod.
Old 03-18-2016, 05:23 PM   #361
chewychevy67
I made a filler strip to cover the tracks and mount my seat switch to for the passenger seat. Here is how it looks. not sure if I should polish up the aluminum, Paint it or cover it with the same color vinyl as the seat. the cars always had a surround on the edges of the seat that was polished aluminum so I might go that route.
Old 03-18-2016, 05:26 PM   #362
chewychevy67
the foam work on the bottom of those seats looks awfull. I may get the upholster guy to fix that when I bring them to get my seat heat pads in them.
Old 03-18-2016, 07:31 PM   #363
chewychevy67
And the driver side.
Old 03-23-2016, 05:31 PM   #364
chewychevy67
Got my seat heaters going now just to get the pads in the seats. Work perfect with the old style metal under dash switches.
Old 03-23-2016, 07:26 PM   #365
chewychevy67
Picked this up today for a decent price to. Guide matic. It auto dims your headlights. Why not I guess. It is cadillac period correct as well
Old 03-31-2016, 11:20 AM   #366
Farm Shop
Farm Shop's Avatar
I only skimmed the thread, but very cool build. My grandpa's '58 Caddy has auto dimming headlights and its pretty trick. Keep the pics coming.
1970 SWB 2wd C10, Vortec 454/80e, CPP 3/5, slotted mags, patina
1972 K20 Super Cheyenne, Short bed, EFI 396, NV4500, NP208
1970 GTO Judge, heads/cam LS1 & stalled 4L60e
Farm Shop is offline   Reply With Quote
Old 04-01-2016, 07:50 AM   #367
Tdrcreyn4
Tdrcreyn4's Avatar
Amazing work....subscribed
1968 C10 292/3 spd - sold
1969 K10 350/3 spd/205 - sold
1971 K5 350/4 spd/ 205 - sold
1970 K20 350/350/205 - sold
1969 K20 396/400/205 - work in process
Tdrcreyn4 is offline   Reply With Quote
Old 04-03-2016, 12:29 AM   #368
swamp rat
swamp rat's Avatar
Where did ya pick these up at? Thanks!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-03-2016, 09:52 AM   #369
chewychevy67
On Ebay. I just took the round rocker switch out and added my own of vintage flavor.
Old 04-03-2016, 04:12 PM   #370
chewychevy67
Got pictures of my new horn center piece today. Telescopic wasn't available in anything gmc so I traded the bow tie out. One with raised letters and one with engraved letters. They look sharp.
Old 04-05-2016, 10:28 AM   #371
chewychevy67
I got the guide matic dial and reostat mounted. The back dial is the guide matic and the front is twilight sentinel. I also got the dials a bit closer to the gauge bezel.
Old 04-05-2016, 10:43 AM   #372
duallyjams
duallyjams's Avatar
GMC is the Cadillac of trucks yours will the be top of the line. If you make a window sticker with all the options that will be a big window sticker for sure.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 04-18-2016, 10:43 PM   #373
chewychevy67
I got my horn center pieces tonight for my telescopic wheel. They look absolutely amazing!!
Old 04-19-2016, 11:40 AM   #374
duallyjams
duallyjams's Avatar
They both look amazing.
James
IG duallyjams
Old 04-19-2016, 01:03 PM   #375
chewychevy67
Thanks. I am super happy with these. Here is the full steering wheel.
