Help end the fight between me and dad
Last week I bought a new shop truck an old body style 07 crew cab. This truck was hit in the back and I replaced the rear end and the springs too. Anyone very cozy with this type truck knows that the front drivers spring bolt has to be cut to be removed and normally I put the bolt in backwards and put the nut on the inside.
Well The crew not only has a gas tank shield on the bottom but the spring pocket is made differently inside the frame. Dad wants me to just weld the head of the bolt to the pocket and call it good so he can ride. I tell him it is not safe and I won't be doing that, he says why not? It can't come out if you weld it. I said it is not safe all I could say I couldn't come with a reason other than it wasn't safe. Now you must know bought this truck on a parts only title so it is a shop truck only[I'll put my D-tags on it] and won't be sold to anyone. It is bad enough that he won't even consider the time in the shop to fix a couple of dents and the bed is a different color but I told him I would not budge on this one item.So what do you think am I over reacting or does it seem crazy to just weld the bolt head to the frame pocket. He still says it can't go nowhere I still say it isn't safe. Any help or advise? Now you must know I've been building truck for almost 30 years I'm 49 he is 86 |
Re: Help end the fight between me and dad
stand your ground. safety is important.
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's 1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's 1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's 1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's |
Well I came up with the answers to why I feel it is unsafe, they have to do with shear double shear and other engineering things. That bolt does more than locate it also clamps I just need to make him see that. He gets something in his mind and there is no changing it. Jim
blood type; Retumbo
Tell him to go back to working on his Farmall tractors and leave the modern stuff to us modern guys. Then run and avoid the flying objects
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
If the bolt isn't tightened on the bracket it will work forward and back and the weld will fail from fatique eventually.
