Old 02-26-2016, 09:28 AM   #76
Chance48
Re: 1948 Chev extended cab with attitude
Loving it.....you prep all your sheet metal with tiger paws? You ever use ospho? I was gonna send my cab to be blasted but I'm thinking I'll clean it up by hand and use some ospho. I believe that will do the trick while saving me a lot of headache. Then I'll be able to do it in sections as you are. And I'm thinking primer then filler. I know that's a topic to be debated, but I like the filler over epoxy idea. Scuff it with some 60-80 grit without going through it.
Really like the contoured front bed apron. That's the kinda touches that make the difference.
Chance
SHAKE N BAKE BABY, SHAKE N BAKE....
http://67-72chevytrucks.com/vboard/s...d.php?t=686729
Chance48 is offline   Reply With Quote
Old 02-26-2016, 12:13 PM   #77
Big Daddy Bear
Big Daddy Bear's Avatar
Originally Posted by alaska gasser View Post
I found some other build pictures that showed 2 1/2 to 3 inch taller bed sides, but I didn't like them. They looked too tall to me so I settled on the 2 inches.
Yes, I agree, it could be easy to get too much!! So, that is why I am interested in seeing yours from the side when you eventually get it settled with the door in place.
I am a ways out before I get to that point, so wanted to tag in so I could follow and see where yours ends up!
No bolt or nut in the world will remain tight if you turn it to liquid!!!
Big Daddy Bear is offline   Reply With Quote
Old 03-14-2016, 12:18 AM   #78
alaska gasser
alaska gasser's Avatar
I'm not a rancher, but I brought a whole bunch of horses home yesterday.
This is exactly what I saw in my head when I opened the hood and saw this.
I just wish the truck was ready to drop it in.
http://67-72chevytrucks.com/vboard/s...d.php?t=592642 '48 Chev extended cab with attitude
http://67-72chevytrucks.com/vboard/s...d.php?t=592769 My daughter's '46 International PU
alaska gasser is offline   Reply With Quote
Old 03-14-2016, 06:43 AM   #79
dug224
dug224's Avatar
Beautiful engine!
dug224 is offline   Reply With Quote
Old 03-14-2016, 11:37 AM   #80
elpound
elpound's Avatar
Love it!
elpound is offline   Reply With Quote
Old 03-14-2016, 09:57 PM   #81
youngrodder
youngrodder's Avatar
Nice engine Eugene...Looks very nice.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 03-15-2016, 11:02 AM   #82
ptc
ptc's Avatar
That has got to be the best looking motor GM ever put out. Somebody was really thinking of 'style' back in those days. The finned covers really are perfect on it!
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 03-17-2016, 08:55 PM   #83
alaska gasser
I agree. Last fall, I considered putting the 383 SBC blower motor in that I had in my Thames panel, but just couldn't do it.
Old 03-21-2016, 01:18 PM   #84
alaska gasser
It's been a busy weekend.
I finished boxing the back of the frame.
I got the new rear sill and installed it. I raised the floor 2 inches
I made my own mounts for the rear sill, so the factory ones were removed and used as front bed mounts.
Behind the right rear tire I cut an access hole to reach the fuel connections.
I got the upper rolls welded on the bed.
There is a factory gap at the top of the stake pocket.
It had to go away.
And then I added a teardrop end cap
The front stake pockets are just squared off from the factory, so that had to be remedied also.
The curve at the front of the bed continued into the rolls at the edges.
Back to the shop and continue weldin and grindin.
Old 03-21-2016, 02:34 PM   #85
roushinator
roushinator's Avatar
Awesome work!
Ryan...
1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain
http://67-72chevytrucks.com/vboard/s...11#post5532411
roushinator is offline   Reply With Quote
Old 03-22-2016, 03:17 PM   #86
ptc
ptc's Avatar
Coming along real nice!
Old 04-06-2016, 12:12 AM   #87
Big Daddy Bear
Looking good!!
Old 04-06-2016, 10:01 PM   #88
youngrodder
Looking good Eugene
Marc
Old 04-07-2016, 05:40 AM   #89
dug224
dug224's Avatar
The attention to detail continues to impress and is a great motivator. thx dug
Old 04-16-2016, 11:21 PM   #90
richards72chevy
richards72chevy's Avatar
I really like the modifications.Reminds me of the vehicles that were in rodders journal magazine.
richards72chevy is offline   Reply With Quote
Old 04-19-2016, 09:52 PM   #91
alaska gasser
It has been a productive couple weeks.
To make the tailgate 2 inches taller, I found a tube the same diameter as the old bottom round and added a 1/4 inch rod in between.
I then added sheet metal to both sides to box it in.
I added hidden latches.
Created the top of the Drivers window / door.
Cut off the end of the drivers side dash and welded it to the door.
Got it molded in and finished up.
Got the drivers inner window frame made.
Now I'm in the process of finishing the bodywork and primer on the tailgate and both inner door window frames. This was the last major fabrication left on the project. Now it's time to start finishing......oh everything.
Old 04-20-2016, 01:29 PM   #92
ptc
ptc's Avatar
.................. This was the last major fabrication left on the project. Now it's time to start finishing......oh everything.
Your project is Looking good! ---- The rough-in stage is almost as long (or longer than) the finishing stage and then comes FINAL ASSEMBLY! .... I am saving all my "TO-DO" lists that I have made up for myself so I can look back on everything someday.... Its about 22 pages so far! Ill have a phone book by the time Im done!!!
Old 04-20-2016, 02:49 PM   #93
II_Slow
II_Slow's Avatar
The first thing that comes to mind is "ambitious SOB"! Great job on that thing, doing everything your way. I'm normally not a fan of stretching, chopping, etc. on the early trucks but for some reason your proportions seem to suit me. I love that W-series engine and what you've done with it, and it's certainly period correct. And I really like how you brought the dash and doors together, and reworked the steps and gaps on the cab to bed. Sort of inspirational to see what can be done with metal once you commit to doing it. Just get it really close in metal, dress it up with a little filler. Keep it up!
1955 SB Stepside 3100 big window cab on a 99 Ram 2500 Frame w/ 12-V Cummins diesel power and
47RH AOD transmission
http://67-72chevytrucks.com/vboard/s...d.php?t=640042
II_Slow is offline   Reply With Quote
Old 04-20-2016, 09:42 PM   #94
youngrodder
Looks good Eugene.
Keep at it.
Marc
Old 04-21-2016, 06:59 AM   #95
dug224
dug224's Avatar
Love the tailgate solution..
Old 05-29-2016, 06:27 PM   #96
alaska gasser
I've been busy cleaning up a lot of loose ends. Also, the metal work and body work on both doors is done and they are ready for primer. I pushed the truck outside in preparation for the final sandblasting of the door jambs, back of the cab and the bed sides as they are 16 gauge.
Let the blasting begin.
The race is on as I want to take it to a large show on August 7th and we hope to leave state the end of September.
Old 05-30-2016, 11:34 PM   #97
elpound
elpound's Avatar
Sure is looking awesome!
Old 06-09-2016, 10:31 PM   #98
alaska gasser
The cab, front fenders and hood are blasted and bodywork continues.
Meanwhile I finished the bodywork on the doors and got them in primer.
Once in primer I wanted to see how different they are from a stock one now.
Best guess, I have around 165 hours in each door at this point. I'm a little concerned that if someone runs into me, the insurance company will hand me a stock door and figure they are done.
Old 06-10-2016, 06:01 PM   #99
Advanced Design
Advanced Design's Avatar
Yes, that is a lot of time investment the insurance company likely won't consider....
A very cool truck being created!
Advanced Design is offline   Reply With Quote
Old 06-14-2016, 12:55 AM   #100
alaska gasser
I am doubting being able to make the Aug. 7th together date due to the amount of bodywork still to go and drying times between all the primer / paint coats. Even so, when I dug out my front pan, I remembered Chevy screwed up on the design and I can't stand it. I was going to leave it for now , but just couldn't do it.
No clue why they left the big flat spot on the end of the passenger side. Made a quick pattern of the driver's side, found some metal the right thickness, welded it on and voila. Honest, it was welded all the way around after the photo.
Lookin like it should have from the factory.
