02-26-2016, 04:10 PM | #351 |
Re: 8 lug wheels - what's on YOUR truck?
02-26-2016, 05:28 PM | #352 |
Rolling on 16.5 x 9.50 Firestones
05-20-2016, 11:17 AM | #353 |
Do you have the floater hub coming through the rear wheels?if so how well did the rear caps fit over?
05-20-2016, 02:01 PM | #354 |
05-20-2016, 10:44 PM | #355 |
BlahBlahBlah
Mine ....
05-21-2016, 07:21 AM | #356 |
17 X 9" custom built to hold the Chevy hubcap....
Almost done with all the welding, then off to powdercoat! -G
1972 K5 - 502BBC/4L80E/Magnum205/Mog-9s/5.26s/38" BFG KM2s Find me on INSTAGRAM @MIGHTASWELLK5 '72 K5 - Greg's "Might As Well" Build |
05-21-2016, 09:35 AM | #357 |
Moto Metal 20 x 9
05-21-2016, 11:44 AM | #358 |
Those are the best looking wheels for these trucks. I wish they were not so hard to find in 16"!
1971 Cheyenne Big Block Longhorn |
05-21-2016, 12:15 PM | #359 |
05-21-2016, 06:57 PM | #360 |
Just like Big O's, 9.5x16.5 firestone 8 lug originals
05-22-2016, 12:50 AM | #361 |
Here is a tip to the people with alot of money to make a lot of money , make a adapter from a 16.5 rim adapted to a 17 inch tire, i think you will clean up. there is a lot of nice rims going to waste, wishing you all the best
05-22-2016, 04:19 AM | #362 |
16 x 7 MB Razers
235-85-16 tyre's
Chris '69 C-20 '04 Jeep TJ |
05-22-2016, 07:39 AM | #363 | |
I really like the look of factory white steel wheels with hubcaps, but there are very few good choices in 16.5" sizes these days. I cut out the centers from some 16.5" factory wheels and figured out how to mount them to a 17" hoop... Now I've got a lot of modern tire choices, but with the "look" of a stock wheel. -G
05-23-2016, 05:34 PM | #364 |
CG...What do you use to polish those wheels? Looks like the same as mine but I just cannot get them to polish.
1969 Chevy K20 Longbed |
05-23-2016, 07:18 PM | #365 |
BlahBlahBlah
I got the mags from board member cleszkie, they were nice and shiny when I got them. You might shoot him a PM.
06-01-2016, 06:27 PM | #366 | |
I Just Put The Same Wheels On My Truck, Can You PLEASE Tell Me What Size Lug Nuts You Used , The 14x1.5 are to tight Please Help Me Out Here Thank You. I Need The Right Lugs To Be Able To Put On The Center Caps ? |
06-01-2016, 06:52 PM | #367 |
06-01-2016, 07:09 PM | #368 | |
9/16" http://www.ebay.com/itm/32-LUG-NUTS-...9WD1vm&vxp=mtr 1/2" http://www.ebay.com/itm/32-LUG-NUTS-...VWD11e&vxp=mtr |
06-02-2016, 01:45 AM | #369 | |
Thank You Harley03joe Front REAR |
06-02-2016, 01:50 AM | #370 | |
So First Owner 9/16 Your So Right Thanks Again Bro Joe CHEVROLET/GMC TRUCK/VAN/SUV - 1/2 TON BLAZER, JIMMY, SUB FULL 71-91 5X127.0 1/2-RH NUT 78.1 1/2 TON BLAZER, JIMMY, SUB FULL 71-91 6X139.7 7/16-RH NUT 108 1/2 TON BLAZER, JIMMY, SUBURBAN 92-on 6X139.7 14mmX1.5 NUT 78.3 TAHOE, YUKON 2X4 92-99 5X127.0 14mmX1.5 NUT 1/2 TON BLAZER, JIMMY, SUBURBAN 00-on 6X139.7 14mmX1.5 NUT 78.3 1/2 TON TRUCK ALL MODELS 2X4 67-87 5X127.0 1/2-RH NUT 78.3 1/2 TON TRUCK ALL MODELS 2X4 88-98 5X127.0 14mmX1.5 NUT 78.3 1/2 TON TRUCK ALL MODELS 4X4 67-87 6X139.7 7/16-RH NUT 108 1/2 TON TRUCK ALL MODELS 4X4 88-98 6X139.7 14mmX1.5 NUT 78.3 1/2 TON TRUCKS 2X4 & 4X4 99-on 6X139.7 14mmX1.5 NUT 78.3 3/4 TON TRUCK 2X4 & 4X4 67-on 6X139.7 1/2 or 14mm NUT 100.7 3/4 & 1 TON C20, C30, K20, K30 65-87 8X165 9/16" NUT C2500-K3500 1 TON & HD 2X4 & 4X4 88-04 8X165 14X1.5 NUT ASTRO/SAFARI 5-Mar 6X139.7 14mmX1.5 NUT 78.3 AVALANCHE 1500, 2WD, 4WD 6-Feb 6X139.7 14mmX1.5 NUT 78.3 AVALANCHE 2500, 4WD 02-on 8X165 14mmX1.5 NUT 125 COLORADO, CANYON 04-on 6X139.7 12mmX1.5 NUT 100.7 COLORADO 15-on 6X120 14mmX1.5 NUT 66.9 CYCLONE, TYPHOON ALL 5X120.7 12mmX1.5 NUT 70.3 EL CAMINO, CABALLERO 64-81 5X120.7 7/16-RH NUT 70.3 EL CAMINO, CABALLERO 82-87 5X120.7 12mmX1.5 NUT 70.3 ENVOY 02-on 6X127 12mmX1.5 NUT 78.3 EQUINOX 2005-2009 5X115 12mmX1.5 NUT 70.3 EQUINOX 10-on 5X120 14mmX1.5 NUT 66.6 LUMINA APV 90-96 5X115 12mmX1.5 NUT 70.3 S-10, S-15 BLAZER, JIMMY, SONOMA 82-on 5X120.7 12mmX1.5 NUT - S-10, S-15 BLAZER, JIMMY, SONOMA 83-on 5X120.7 12mmX1.5 NUT - SAVANA 1500 01-on 5X127.0 14mmX1.5 NUT - SSR 04-on 6X127 12mmX1.5 NUT 78.3 TRACKER 98-on 5X139.7 12mmX1.25 NUT - TRAILBLAZER 02-on 6X127 12mmX1.5 NUT 78.3 TRAVERSE 09-on 6X132 14mmX1.5 NUT 74 UPLANDER 2005 5X115 12mmX1.5 NUT 70.3 UPLANDER 06-on 6x115 12mmX1.5 NUT 70.3 VAN G-SERIES 1/2 TON 71-96 5X127.0 1/2-RH NUT - VAN G-SERIES, 3/4 TON 96-97 6X139.7 14mmX1.5 NUT - VAN EXPRESS 1500 97-02 5X127 14mmX1.5 NUT 78.3 VAN EXPRESS 1500, SAVANA 03-on 6X139.7 14mmX1.5 NUT 78.3 VAN EXPRESS, SAVANA 2500, 3500, 97-on 8X165 14mm1.5 NUT 117 VENTURE 97- 5X115 12mmX1.5 NUT 70.3 SUBURBAN 2X4 & 4X4 65-87 8X165 9/16" NUT Last edited by Harley03joe; 06-02-2016 at 01:57 AM. |
06-02-2016, 01:56 AM | #371 | |
Joe Chevrolet / GMC Trucks & SUV Asrto Van 1985-2002 1/2" Asrto Van 2003-On 14mm x 1.50 Avalanche 2002-On 14mm x 1.50 Blazer 4X4 (6 Lug) 1971-1991 7/16" Blazer 2 W/D (5 Lug) 1971-1991 1/2" Blazer 1992-On 14mm x 1.50 C-10 1971-1988 1/2" C-1500 (5 Lug) 1971-1987 1/2" Canyon 2004-On 12mm x 1.50 Caballero & El Camino 1964-1981 7/16" Caballero & El Camino 1982-1987 12mm x 1.50 Chevy 3/4 Ton Van (5 Lug) 1960-1981 1/2" Colorado 2004-On 12mm x 1.50 Denali, Express Van, Savana Van 1996-On 14mm x 1.50 Envoy 1999-On 12mm x 1.50 Equinox 2005-On 12mm x 1.50 Jimmy (5 Lug) 1969-1970 7/16" Jimmy (5 Lug) 1971-1991 1/2" Jimmy (6 Lug) 1971-1991 7/16" Lumina Van 1989-On 12mm x 1.50 Luv 1972-1984 12mm x 1.50 Pickup (5 Lug) 1971-1987 1/2" Pickup (6 Lug) 1950-1987 7/16" Pickup (8 Lug) 1965-1987 1/2" or 9/16" Pickups (All) 1988-On 14mm x 1.50 S-10 Blazer 1983-On 12mm x 1.50 S-15, Sonoma & Jimmy 1983-On 12mm x 1.50 Safari 1985-2002 1/2" Safari 2003-On 14mm x 1.50 Savana, Suburban & Yukon (5 & 6 Lug) 1992-On 14mm x 1.50 SSR 2004-On 12mm x 1.50 Suburban (5 Lug) 1969-1970 1/2" Suburban (5 Lug) 1971-1991 7/16" Suburban (6 Lug) 1970-1991 7/16" Suburban (8 Lug) 1970-1991 9/16" Tahoe 1995-On 14mm x 1.50 Tracker 1989-On 12mm x 1.25 Trail Blazer 2002-On 12mm x 1.50 Uplander 2005-On 12mm x 1.50 Van 5 (Except Express) 1971-1996 1/2" Van 6 (Except Express) 1971-1996 7/16" Van 8 (Except Express) 1965-1996 1/2" or 9/16" Ventura MiniVan 1997-On 12mm x 1.50 3 of 9 |
06-02-2016, 10:07 AM | #372 |
Not sure what brand but their 16.5 inch rims.
1966 Chevelle True SS "father and son project" 1969 C60 "Toy Hauler" 1970 k20 "Big Red" 1970 C10 lwb "survivor"(Sold) 1971 k20 "Duramax build" |
06-02-2016, 03:07 PM | #373 |
[QUOTE=Project_Big_Red;7612722]Not sure what brand but their 16.5
That looks like the beginnings of a sweet truck. I gotta ask, did you recently buy it? Seem to recall one similar on cl a while ago. Anyway these accuride wheels are going on my 71 with some 245 70 16 bfg at's when I find some scew in valve stems. Thanks too some local board members I also have a full set of oe 16x6" rims also. I wouldn't mind finding a set of firestone transforce tires for them (tall and skinnys)
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
06-02-2016, 04:45 PM | #374 |
16" in stead of 16.5"
1970 C20 350/TH350, LB God Bless our Troops |
06-02-2016, 07:35 PM | #375 |
Stock 16.5x8.25
"A man's got to know his limitations" 1969 Chevy C20 Camper Special 1968 Chevy C-10 short/fleet 1970 GMC Jimmy 4x4 (SOLD) |
