Old 02-26-2016, 08:12 PM   #1
hey its me
Look what I found. This truck is such a hack job.
I guess I never bothered to look at the shocks since I planned on replacing them soon anyways.. Who knows how long I've been driving around like this lol
hey its me is offline   Reply With Quote
Old 02-26-2016, 08:22 PM   #2
bbbc10
Diggin The SquareLife
Re: Look what I found. This truck is such a hack job.
What makes this a hack job?
bbbc10 is offline   Reply With Quote
Old 02-26-2016, 08:26 PM   #3
71swb4x4
71swb4x4's Avatar
Exactly the same thing I thought.
Yes, that's not great. But it could have happened to anyone of us at any time.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-26-2016, 08:26 PM   #4
slotard
I doubt it mounted to the bed factory
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 02-26-2016, 09:00 PM   #5
enaberif
You can see the normal mount hole further behind the shock.
enaberif is offline   Reply With Quote
Old 02-26-2016, 09:07 PM   #6
daddyjeep
daddyjeep's Avatar
It's kinda hard to tell by the pic, but it does look like it's mounted to the bed floor.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 02-26-2016, 09:08 PM   #7
bbbc10
Ok and? This is nothing new to our year trucks man....
Old 02-26-2016, 09:47 PM   #8
68Timber
I know the pieces fit
68Timber's Avatar
I think it's just broke free. It looks like it's rubbing the bottom of the bed.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 02-26-2016, 10:04 PM   #9
Front Range
Front Range's Avatar
Looks like he's dealing with several issues at once on that truck and it's just frustration boiling up. Hang in there and take one at a time, you'll get it buttoned up eventually.
If it makes you feel any better I imagine most guys here have endured fixing up some dumb crap done by previous owners.
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you.
Front Range is offline   Reply With Quote
Old 02-26-2016, 10:31 PM   #10
Rubble
Ha, no kidding!! Other than some of my first trucks in early 80s,I don't think I've had any of mine in last 20 years or so that I didn't have to fix dumb crap done by PO. But in the same breath,I'm a cheap sob too,so most of the trucks I've picked up for free or very cheap too.Its a challenge that way too...
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 02-26-2016, 11:25 PM   #11
cheepin
Not hack. Just broken off the frame. Common problem on the rear shocks.
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14,
cheepin is offline   Reply With Quote
Old 02-26-2016, 11:26 PM   #12
hey its me
That about sums it up. After soldering hacked wires that were twisted together, fixing the heater hoses which were routed wrong, discovering a stripped stud on the p/s pump, then noticing the shock dangling there, just in one day.. that's why I say hack job lol. It is a pretty nice looking truck on the outside though. Slowly fixing things. It will get there. Feel free to recommend some decent shocks, as I'll be buying some soon. Are there any at the parts store (napa/O'reilys) worth buying? Looking to make this a decent handling truck that can tow.
Thanks- Ian
Old 02-27-2016, 12:01 AM   #13
slotard
If you're willing to spend the money I'd go for Bilsteins. They're around $100 each, online Napa doesn't list em but OReilly does. There are reasonable cheaper options too, but I'm in the buy once cry once camp.
1973 C20, 350/350
Old 02-29-2016, 12:49 AM   #14
barry1982
You do have to be careful.... and sometimes lucky when picking up an old truck. And yes, there are "Hacks" out there. I bought an 85 a few years back, and decided to check the brakes first thing. Had a hard time pulling the rear drums off. Discovered the rear axle seals were leaking, and the gear oil caused the brake linings to swell. Rather than repair the seals/brakes properly, the previous owner forced the shoes "tighter" (probably with a large c clamp) and tack welded them to the backing plate! That's what I call a "Hack"!
barry1982 is offline   Reply With Quote
Old 02-29-2016, 01:22 AM   #15
Matt Man
Matt Man's Avatar
I had a "70" el camino with a 72 front clip that had the worst brakes that I have ever felt, after poking around under the dash, their was a bungee cord holding up the brake pedal... I was speechless... and angry.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 02-29-2016, 01:40 AM   #16
Scott76
How about the 1/4-20 bolt in the motor mount on my new (to me) truck, or the exhaust 'mounted' with bailing wire, etc,etc. The list goes on and on. Hacks are everywhere, it's up to guys like us to make them right.
Scott76 is offline   Reply With Quote
Old 02-29-2016, 03:44 AM   #17
andrewmp6
That looks factory next to the hack jobs i have seen in the mini truck world,Or the favorite one was a donk they welded scrap metal on top the cast iron spindle for a lift.
Old 02-29-2016, 12:05 PM   #18
Front Range
Damn....
Old 03-01-2016, 02:34 AM   #19
andrewmp6
Google s10 forum hack jobs and have nightmares trust me lol.
