Old 02-28-2016, 06:04 PM   #1
gable74
gable74's Avatar
HVAC Questions
I got my new heater/AC controls because one of the levers on mine was broken. I started labeling everything and unhooking the cables, wiring, and vacuum lines and realized something odd. The cable that goes behind the glove box had a really sharp bend in it that wouldn't let the cable move freely. This (coincidentally) was the same cable the broken lever was connected to. So it would seem at some point someone either crossed up the cables or installed a cable much too short to function properly. I know thats not the question but it lead me to start looking at the rest of the setup to make sure it looked correct.
Then I realized after hooking everything back up and checking it out that the vacuum setup seemed odd. So here are the questions:
The top lever on the front of the AC/heater controls from left to right says
INSIDE - AIR - OUTSIDE - DEFROST
#1 When the top lever is all the way to the left (on the "INSIDE" mark) the vent on the passenger side opens. Shouldn't the vent open when the top lever is on "OUTSIDE" and not "INSIDE"?
#2 The vacuum switch on top of the heater/AC control only has (2) lines coming off of it on ports #2 and #3. Port #1 is blocked off. Is that correct?
#3 With the top lever all the way to the left I can hear a faint sound of a vacuum leak coming from that switch. It doesn't seem to affect anything and I can only hear when I am under the dash. Is that normal?
Thanks for any help or advice you can give.
Jimmie
1972 K-20 Custom Camper
1971 K2500 Custom Camper (Sold)
2014 GMC 2500HD DMAX
gable74 is offline   Reply With Quote
Old 02-29-2016, 12:40 AM   #2
Sklptrljay
Sklptrljay's Avatar
Re: HVAC Questions
http://67-72chevytrucks.com/vboard/s...d.php?t=689992
Check out this thread.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 02-29-2016, 01:28 AM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: HVAC Questions
The kick panel is open to let the air in the cab keep circulating to cool off the cab quicker.
The outside flapper is closed when it's all the way to the left. The one under the cowl. That's the one that lets outside air into the cab.
If you have the 3 vacuum ports then it need to look like the picture above.
No vacuum leak, if it's leaking you have a problem.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-29-2016, 03:39 PM   #4
gable74
gable74's Avatar
Re: HVAC Questions
Okay, thanks guys. That helps a lot. Does anyone have a part number or know where I can pick up a vacuum switch without having to buy the whole control assembly?
