Old 02-28-2016, 10:30 PM   #1
Gregski
Gregski's Avatar
Would you use a wire wheel on cylinder heads, head gasket surface?
got some used iron cylinder heads from a junkyard and wonder if I can use a wire wheel on them to clean up the head gasket surface
Gregski is offline   Reply With Quote
Old 02-28-2016, 10:37 PM   #2
65standard
65standard's Avatar
Re: Would you use a wire wheel on cylinder heads, head gasket surface?
I wouldn't on aluminum heads. Alloy too soft.
Iron heads should be okay
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 02-29-2016, 12:29 AM   #3
barry1982
I have cleaned cast iron heads/block surfaces many times with a wire wheel. Works great! I imagine you will be spinning the wheel with a disc grinder? Be careful near the edges, and ports. If you get too close to an edge, the wheel "bites" hard jerking the tool in your hands and can even take off a little metal.
barry1982 is offline   Reply With Quote
Old 02-29-2016, 12:31 AM   #4
lkfldredneck
Should be alright to use on iron. After cleaning up id check for cracks with a en electro magnet and some crack powder (No, not that crack!). Could save you a whole lotta pain in the future.
If you want them looking good till the first fire id suggest a resurface. Mine looked amazing when i resurfaced the heads on my 94
I went all out on those heads though, Im doubting your going to.
Hot tank dipped, pressure steam washed, bead blasted, pressure steam washed again, 3 angle cut valve seats, brass valve guides, ground valves, resurfaced, port and polished to match the intake, new valve o-rings, umbrella seals, and spring shims. a lot of work into the heads for little gain. That was all done in my dads shop (which happened to be a professional engine building shop, at the time)
lkfldredneck is offline   Reply With Quote
Old 02-29-2016, 01:41 AM   #5
snaptoo
yes on iron and some of 3m roloc scuff pads really do well here!
snaptoo is offline   Reply With Quote
Old 02-29-2016, 09:01 AM   #6
enaberif
Use the brass ones and you will be fine. Just make sure you cover up any and all ports where small pieces can fall into lol.
Roloc discs are $$$ and not worth it in my opinion.
enaberif is offline   Reply With Quote
Old 02-29-2016, 10:13 PM   #7
Gregski
Gregski's Avatar
well decided to go for it on these Vortec GM heads part # 12558062 from a 99 Suburban, and I like the results, good enuff fer me, used a 4" wheel on an angle grinder for the gasket surface, and put no pressure on it just the weight of the tool, then used a cup brush on a drill for the valves and chambers
Old 02-29-2016, 10:33 PM   #8
lkfldredneck
They look good for a quick job. Hope you buy good gaskets after that haha
Old 02-29-2016, 10:34 PM   #9
Gregski
Gregski's Avatar
GM 10105117 should do the trick
Old 02-29-2016, 10:48 PM   #10
enaberif
Do yourself a favor and spend some extra time and port match the ports to your gaskets and ensure that the surfaces for the intake manifold are dead flat.
