Old 03-02-2016, 01:10 AM   #51
DakotaKid
Re: LS engine swap into 1966 c10; fuel tank install
there is a Bosch Pump out there that is OEM that is sometimes called the Bosch "porsche" pump cause it was OEM in some model porched that required 75-100PSI fuel pressure. i have had many friends use them in EFI setups and "Hot Rod Garage" just used oneon their new Camaro LS swap project. OEM quality and Durability. Called a Bosch 444 pump i believe.
Current Project : 1962 Chevy SWB Fleetside
Others, 1958 Edsel Villager Station Wagon
1926 Ford Model T Roadster Hotrod
www.suedescarclub.com
DakotaKid is offline   Reply With Quote
Old 03-02-2016, 01:03 PM   #52
crakarjax
crakarjax's Avatar
Thanks, good info http://realstreetperformance.com/Fue...ison-Test.html
And I'll be checking out that capless filler! I wonder if they wear out though, and if so if they can be repaired?
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
